1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jun 14, 2023 at 9:32 PM
    #681
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    So far so good with the idle.Thanks @treyus30. You've been a huge help.
    on another note, the ac1 and ACT wires don't do what they should. AC1 has no state change with the ac switch or any climate control combination I've tried. And the ACT wire gets a 5v change when the fan is switched on engine off. When engine is running, it's a constant 5v.
    Any other ideas?
    treyus30 likes this.
  2. Jun 14, 2023 at 9:36 PM
    #682
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'm not sure why your AC1 isn't triggering. I have always used super low voltages on that for the threshold. The ACT has a pull-up resistor to 5v on it so it's natural state is 5v, you pull it to ground with the ECU to turn off the AC system with the computer. Are you testing the AC1 wire with the HVAC actually on and the clutch operating. It only shows the AC as being on when the AC amp has engaged the mag clutch
  3. Jun 14, 2023 at 9:39 PM
    #683
    betterbuckleup
    Ian
    Concord, CA
    Yea I've been testing that wire to ground with the motor running. When I press in the AC button, I can hear the clutch engage and the idle is pulled down or stalled.
  4. Jun 14, 2023 at 9:42 PM
    #684
    Speedytech7
    Lemme look into it a bit more tomorrow. I can look at the wire diagram on alldata and see if there's something I'm missing that changed over the years.
  5. Jun 14, 2023 at 9:48 PM
    #685
    betterbuckleup
    Ian
    Concord, CA
    Yea lemme know if you see anything. I've been going off of this document for the wiring which seems to hold true, but outside of that I'm at a loss. Last resort would be to pull signal off of the mag clutch itself for the input.
    It's a 2000 3rz fed emissions
  6. Jun 14, 2023 at 9:50 PM
    #686
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Tell your tuner to PayPal me ;)
  7. Jun 14, 2023 at 9:55 PM
    #687
    Speedytech7
    Makes ya wonder don't it?
    Digiratus and treyus30[QUOTED] like this.
  8. Jun 14, 2023 at 9:57 PM
    #688
    Speedytech7
    I dig into the minutia of PID control and really started nailing the closed loop boost control. Man when you have spool assist dialed properly it lights up stupid fast.
  9. Jun 14, 2023 at 10:15 PM
    #689
    treyus30
    Trey
    Mesa / AJ, AZ
    You upped me then haha, need to refocus
  10. Jun 14, 2023 at 10:24 PM
    #690
    Speedytech7
    I stopped at a super solid and responsive 9psi today... Thing squats and takes off like crazy now. Amazed at the Chevy 63s not axle wrapping to shit with the 35s and 4.56s. Other than the soft off-road suspension handling it doesn't feel like driving a truck, reminds me of my IS300 but with way better spool time. I'm still excited to see your gauge unit tho so don't refocus too hard, the tunes ain't going anywhere haha.
    treyus30[QUOTED] likes this.
  11. Jun 15, 2023 at 4:47 PM
    #691
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I have a question about the voltage values displayed in the NSP software.
    When my ScanGauge is connected to the truck's OBDII port the voltage it displays pretty much matches what my multimeter shows at the battery posts. But this never agrees with what is displayed in the NSP software. NSP is always .5 volts lower than what a multimeter shows at the battery.
    This afternoon I connected my SG directly to the Haltech 2000 ecu. When the battery voltage is 14.25, the SG reads 13.6-13.7 and NSP is 13.75-13.8.
    To add some spice to this, I have the good fortune to be around and observe NSP connected to 2 other Tacomas. Now I realize they are different trucks with different charging systems, but both of those truck show they are running 14.2-14.3 volts in NSP.
    I am curious if you guys might have some insights on this topic.
  12. Jun 15, 2023 at 4:58 PM
    #692
    treyus30
    Trey
    Mesa / AJ, AZ
    Not sure, never cared tbh. But a due note is that a single diode's voltage drop is around 0.5V
  13. Jun 15, 2023 at 5:02 PM
    #693
    Speedytech7
    Neither Dan nor I has a second ecu leaching power off the same small wires.
  14. Jun 15, 2023 at 5:13 PM
    #694
    Digiratus
    Roaming the PNW
    The RedHead
    Do you care to explain that further. Like where might that diode be? Is it like Zane suggests, part of the OEM ECU?
    This makes some sense. I am unique compared to you guys.
  15. Jun 15, 2023 at 5:41 PM
    #695
    treyus30
    Trey
    Mesa / AJ, AZ
    I have no idea what your setup is. Are you PnP like me?
  16. Jun 15, 2023 at 6:15 PM
    #696
    Digiratus
    Roaming the PNW
    The RedHead
    Not sure what you mean by PnP. Plug 'N Play?
    I am running the Elite 2000 on an Extracab '02 4x4 v6 with an auto and the Magnuson SC at about 6 psi.
  17. Jun 15, 2023 at 6:23 PM
    #697
    treyus30
    Trey
    Mesa / AJ, AZ
    Ya Plug and play... Not really sure what's up with the differences. Is there a problem? 13-14V is healthy
  18. Jun 15, 2023 at 6:56 PM
    #698
    Digiratus
    Roaming the PNW
    The RedHead
    No, no problem. Mostly was just curious why there would be such a variation. Now that he said it, what Zane said makes a lot of sense.
  19. Jun 15, 2023 at 7:18 PM
    #699
    treyus30
    Trey
    Mesa / AJ, AZ
    Not sure there's a way to really know without seeing the whole wiring harness. VDrop from wire isn't all that high as some people display
    Digiratus[QUOTED] likes this.
  20. Jun 16, 2023 at 11:54 AM
    #700
    betterbuckleup
    Ian
    Concord, CA
    How do I add "in gear state" to my tuning table at the bottom like this? Can I even do that with the elite 750?
    I'm trying to add it to this table
    I've already got the ratios setup and gear detection by ratio turned on. speedo calibrated too
