1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jun 16, 2023 at 2:51 PM
    #701
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I don't think the 750 supports a 3rd axis
  2. Jun 16, 2023 at 4:14 PM
    #702
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    Indeed.
  3. Jun 16, 2023 at 5:11 PM
    #703
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Damnit. Well so much for in gear ignition correction.
    treyus30[QUOTED] likes this.
  4. Jun 16, 2023 at 6:02 PM
    #704
    treyus30
    Trey
    Mesa / AJ, AZ
    You could always replace the RPM axis with it I guess
  5. Jun 16, 2023 at 6:12 PM
    #705
    betterbuckleup
    Ian
    Concord, CA
    I need that axis for where I want the correction to happen though :/
  6. Jun 16, 2023 at 6:16 PM
    #706
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Couldn't you just do a generic correction table?
  7. Jun 16, 2023 at 6:41 PM
    #707
    betterbuckleup
    Ian
    Concord, CA
    That 3 axis is key though. I'm looking to retard the timing between 2000 to 3,000 RPM at ~2psi in 4th and 5th gear to start
    treyus30 likes this.
  8. Jun 17, 2023 at 6:48 PM
    #708
    garetcurry
    garetcurry Well-Known Member
  9. Jun 17, 2023 at 6:54 PM
    #709
    treyus30
    Trey
    Mesa / AJ, AZ
    betterbuckleup likes this.
  10. Jun 19, 2023 at 11:06 AM
    #710
    garetcurry
    Haha... yeah.
    Hit 14.5 psi last night. I'll be posting videos as I experience peak boost growth.
  11. Jun 19, 2023 at 11:09 AM
    #711
    Speedytech7
    What clutch are you using? After configuring spool assist my setup lights up so fast and hard to 10psi I'm blowing right through an Exedy Racing Stage 1
  12. Jun 19, 2023 at 11:20 AM
    #712
    treyus30
    Trey
    Mesa / AJ, AZ
    Are you capping it there? I wasn't going to go past 15 and I have everything set up to kill power above that
  13. Jun 19, 2023 at 11:55 AM
    #713
    betterbuckleup
    Ian
    Concord, CA
    I was wheeling this last weekend and was getting my ass kicked with the engine stalling. Due to the power draw of my winch, air compressor, and A/C. I would have to give it gas to keep it alive.
    I was wondering if it would be possible to wire up the electrical load switch function of the HT to the alternator sensing circuit somehow. That way I compensate for any kind of electrical load.
    I haven't looked into what the wiring looks like for that circuit and if it would even be possible, but it was just a thought I had.
    Anyone got any experience with the alternator sense circuit that could provide any insight?
  14. Jun 19, 2023 at 12:36 PM
    #714
    treyus30
    Trey
    Mesa / AJ, AZ
    You could probably do a voltage divider for a quick but imperfect fix. Drop 0-15V down to 0-5V and read the analog to say if it's under 12.8V->4.26V or something, trigger an idle up
  15. Jun 19, 2023 at 12:43 PM
    #715
    betterbuckleup
    Ian
    Concord, CA
    Hm ok. might try and mess with that in the meantime.
    Doesn't help that my idle is still all fucked up. After changing the table axis to target RPM instead of RPM, It's not much better. I've messed with the PID with little to no success. I think I'm gonna reach back out to Gabe and see if he has any input. I've still got that surging I had before and it's not a stable idle at all. It seems to have gotten worse with the summer temps increasing.
    I'm thinking about pulling the SC and moving the air temp sensor into one of the runners if that might help.
  16. Jun 19, 2023 at 12:45 PM
    #716
    treyus30
    Trey
    Mesa / AJ, AZ
    Mines still learning but it's been doing great if you want to just try importing the whole idle table.
    You may need to adjust your throttle screw a little if it wants to die after first upload (or you can increase the duty cycles by like 20% in the active regions).
  17. Jun 19, 2023 at 12:51 PM
    #717
    betterbuckleup
    Ian
    Concord, CA
    I'll try out your idle settings, but I already tried copying your PID settings and it seemed to make things worse as far as surging.
    Also don't you think things like your idle ignition correction tables would be different since I'm a 4cyl, not the 5vz?
  18. Jun 19, 2023 at 12:52 PM
    #718
    treyus30
    Trey
    Mesa / AJ, AZ
    Might want to go back to the base map PID then. I set these the way they are after I was already pretty close to correct DCs. I do recall slight adjustments that weren't thought out would cause surge/overshoot
    Ignition correction differences I'd think would be minor
    Speedytech7[OP] likes this.
  19. Jun 20, 2023 at 7:55 AM
    #719
    garetcurry
    Garet's Boost Safe Goals Considering Fuel Types Chart
    8-12 psi 93 Pump, night time up to 15-20 psi (makes me nervous)
    12-20 psi 93 Pump + Meth kit
    20+ psi E85
    15 psi on pump for the season, cap it there, yeah. I'm in the final break-in stages of the motor. I'm running a semi-synthetic for 400-500 miles, then I'm going to full synthetic. Will absolutely not go above 15 psi before switching to full synthetic.
    I wanted to do 30 psi but on E85. I'd run out of injector before getting there.
    I have to start critically looking at intake temperatures. I usually save the 12+ psi tuning pulls for night time when I can get some added safety cushion from colder air.
    Crappy video bonus:
    https://youtu.be/K4W5TtSpAAM
    unstpible and treyus30[QUOTED] like this.
  20. Jun 20, 2023 at 8:27 AM
    #720
    treyus30
    Trey
    Mesa / AJ, AZ
    Oh, I see you're built.
    I think you could probably send it at least to 20 on just 93. You're running a huge turbo which explains the longer spool time in your videos, which also should mean you're not generating a ton of heat with it yet either (and probably never will since you'll be so far from the surge line).
    I'm limited to 15 because that's where around the stock rods will crap out.
    I do wonder what the true pre-ignition conditions are on these engines are though.
    Something I had to put into words for myself: octane is solely for preventing pre-det, nothing else. Richer fuel lengthens burn time, as do lower intake temps, and vice versa. So a lean, hot mixture will burn the fastest and require the most timing retard but make more power because you don't have to start the combustion as far BTDC. Cooler mixes will require more advance and increase your chances of pinging to make similar power. Octane moves the needle of heat igniting the mix before the spark, so if you run an advanced, cold, rich mixture, you lose power but have added pre-ig safety. Do it too much and you have ping. But in fact, some ping (reverse force) is almost always present.
