1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jul 14, 2023 at 12:02 PM
    #801
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    When I was going through my trigger issues, that was a question that was brought up as a possible cause. Only reason I mentioned it
  2. Jul 14, 2023 at 12:39 PM
    #802
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    WOOOOO!
    Split the grounds and it went to 5k first try!
    I'll play with trigger V's but now I have some new cells to tune!
  3. Jul 14, 2023 at 1:08 PM
    #803
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nice! Glad that fixed it for you! Was it the same as mine, like 6" into the factory loom from the ECU connectors?
  4. Jul 14, 2023 at 2:52 PM
    #804
    Jon64l
    Jon
    Me too! I was getting worried i needed a new engine harness or something.
    Yes, had a little crimp fitting. Ended up just cutting and soldering the wires. I may not have needed the new sensor, so whoever converts next should split these wires first thing.
  5. Jul 14, 2023 at 3:11 PM
    #805
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    I had the same issue. I went to replace the crank sensor harness from the ecu to the sensor, when I cut the harness open I found the grounds spliced together. This was NOT shown in the factory wiring diagram.
  6. Jul 14, 2023 at 3:19 PM
    #806
    Speedytech7
    You're the whole reason I even thought to check it.on mine. You know all the stock ECUs bridge them internally so I don't know why they'd chose to do it in the harness as well and then not even notate it.
    betterbuckleup and Jon64l like this.
  7. Jul 14, 2023 at 3:23 PM
    #807
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    I have gotten so much support from you guys on this forum, I am glad I could contribute something.
  8. Jul 15, 2023 at 10:33 AM
    #808
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I need to figure out some way to prevent the gear shift lever from flipping to neutral on its own. Twice now it's jumped out of drive when doing a pull - I assume it's instigated from the trauma of the trans downshifting
  9. Jul 15, 2023 at 10:43 AM
    #809
    Speedytech7
    I bet it's from your engine mounts and transmission moving and physically pulling the shifter. It's not uncommon on older tacos
    treyus30[QUOTED] likes this.
  10. Jul 15, 2023 at 11:19 AM
    #810
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I've had this happen too, but not in a hard pull. It did it on a tough rock obstacle at Moab. We later found the trans mount rubber separated on one side of the mount.
  11. Jul 15, 2023 at 12:07 PM
    #811
    treyus30
    Trey
    Mesa / AJ, AZ
    Could be.. Doesn't sound like there's a solution other than solid mounts then..?
  12. Jul 15, 2023 at 12:12 PM
    #812
    Jon64l
    Jon
    Ratchet strap.
  13. Jul 15, 2023 at 12:14 PM
    #813
    Speedytech7
    Less worn out mounts, the engine mounts control roll the most. If you have a torn one that'll be most noticable. I'm replacing mine with the ruff stuff poly mounts for the 22re. I have to get my hands on a 4x innovation trans mount though still.
  14. Jul 15, 2023 at 2:11 PM
    #814
    Digiratus
    Roaming the PNW
    The RedHead
    You can certainly get solid motor mounts but I don't think anyone is making a solid mount for the A340F.
  15. Jul 15, 2023 at 2:19 PM
    #815
    Speedytech7
    I was just thinking about this... It would be pretty easy to get off the shelf poly pucks to retrofit that mount... But honestly the most important ones are the engine mounts since the drive train doesn't move up and down much (what the trans mt deals with most) but it does want to roll from torque (what the engine mounts deal with)
  16. Jul 15, 2023 at 2:28 PM
    #816
    Digiratus
    Roaming the PNW
    The RedHead
    An interesting idea. How would you attach the pucks to the metal brackets? Some industrial strength glue I presume.
  17. Jul 15, 2023 at 2:35 PM
    #817
    Speedytech7
    You might be able to find an adhesive strong enough... Maybe some poly in a tube like Windo-Weld. But I thought simpler, like a bolt through em with a poly pucks on top too so there's room to flex in tension and compression
  18. Jul 15, 2023 at 2:48 PM
    #818
    Digiratus
    Roaming the PNW
    The RedHead
    I have Dan's old trans mount we can play with. I think I threw away my old torn one.
  19. Jul 15, 2023 at 3:22 PM
    #819
    treyus30
    Trey
    Mesa / AJ, AZ
    The trans mount is brand new and it was pretty comparable to poly in stiffness suprisingly. I think it's more to do with the lever force from the shifter itself tbh.
    I might scrap together a little flip down locker for the D position and just screw it into the plastic. If I hold it I'm fine
  20. Jul 15, 2023 at 3:24 PM
    #820
    garetcurry
    garetcurry Well-Known Member
    Oh yeah, what brand? I have a B&M right now and with the Spec Stage 5 Clutch it's a little bit of a bitch to shift at low RPMs.
