1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Sep 22, 2023 at 5:50 PM
    #981
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Backfired today around 12PSI too. Lambda (now that my gauges are up) was at 0.5. I'm starting to see why some vehicles run a MAP and MAF sensor. There's no way for it to know if I'm at 40% or 100% throttle at 12PSI. Mass is probably completely different
  2. Sep 24, 2023 at 1:55 PM
    #982
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That don't sound right, what did you do to get what's essentially a 7.4AFR? People can tune boosted vehicles no problem on just MAP or even alpha-n (TPS), it's not the tuning solution, it's the tune. Why are you getting 12psi at partial throttle though? Why isn't your boost control scaling to demand?
    Torspd and unstpible like this.
  3. Sep 24, 2023 at 7:24 PM
    #983
    treyus30
    Trey
    Mesa / AJ, AZ
    Because I don't have TPS on a 4D axis?
  4. Sep 24, 2023 at 9:46 PM
    #984
    Speedytech7
    I don't either, I'm actually a bit stumped as to how yours is demanding so much. When your throttle isn't open much. What's you minimum boost amount? Is it just unable to wrangle the two turbos with a single wastegate and creeping hardcore?
  5. Sep 25, 2023 at 7:30 AM
    #985
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Have you tried calling Haltech Tech support?
  6. Sep 25, 2023 at 5:20 PM
    #986
    Speedytech7
    unstpible and Jon64l like this.
  7. Sep 26, 2023 at 12:08 PM
    #987
    Speedytech7
    jubei, treyus30 and Torspd like this.
  8. Sep 26, 2023 at 5:10 PM
    #988
    treyus30
    Trey
    Mesa / AJ, AZ
    It's doing what it's supposed to, it's just able to generate a lot of boost at low throttle. I could set the boost control on a TPS axis instead of an RPM axis since I basically have it asking for 16PSI the whole range of RPM so the axis is basically unused rn. But I don't have an issue with it generating the boost as long as it can handle it which makes me lean towards adding it elsewhere. 6PSI spring pressure, to answer that question
    Well holy shit
  9. Sep 26, 2023 at 5:14 PM
    #989
    Speedytech7
    I wouldn't even necessarily add a TPS axis, I'd probably just make a target boost pressure curve. Pretty easy to define and it makes it nice and repeatable.
  10. Sep 26, 2023 at 5:18 PM
    #990
    treyus30
    Trey
    Mesa / AJ, AZ
    Somebody today asked if I could make the module send inputs to the HT. I was like it's possible on my end, but idk if the HT can receive them and interpret them. He basically wants to send sensor data over CAN externally and have the Haltech read it in since there's not enough pins on the HT itself for NOS, traction control, and everything else he wants
  11. Sep 26, 2023 at 5:24 PM
    #991
    Speedytech7
    There's already a bunch of IO extenders on the market, I'm sure you could do it, but is it worth it. Can you hit the same feature set (sensitivity and smoothing adjustment and delay) as the ones on the market. I don't think the haltech IO12 is a very good product but I think the CAN Checked MCE18 is hard to beat
    https://www.vadpro.com/products/can...ltifunction Can,the flexible Can Bus protocol.
  12. Sep 26, 2023 at 5:27 PM
    #992
    treyus30
    Trey
    Mesa / AJ, AZ
    So I need the IO Expander CAN addressing added to those datasheet pages haha
  13. Sep 26, 2023 at 5:29 PM
    #993
    Speedytech7
    I think it's coming, a lot of this has been added to the site recently, probably some Aussie intern typing it all up now ahead of the CAN feature set improvement launch.
    treyus30[QUOTED] likes this.
  14. Sep 26, 2023 at 5:38 PM
    #994
    treyus30
    Trey
    Mesa / AJ, AZ
    Oh man, now I need to parse words down to individual bits for further processing it looks like.... aggh so much things to do so little time
    Speedytech7[OP] likes this.
  15. Sep 26, 2023 at 5:43 PM
    #995
    Speedytech7
    How's this alter what you've been doing?
  16. Sep 26, 2023 at 5:45 PM
    #996
    treyus30
    Trey
    Mesa / AJ, AZ
    It looks like it adds the X:Y options where it's Byte:Bit to mean something, whereas before it was all 2 bytes together (Byte 1-Byte2), or 1 word (8 bits), was a single sensor data.
    Basically I need to add handling & displaying boolean types now.
    (sorry for all the edits, it's been over a month since I worked on it)
  17. Oct 1, 2023 at 12:39 PM
    #997
    Speedytech7
    Looked through some of my logs when I was hard on the pedal... I somehow got 102% throttle position haha.
    unstpible likes this.
  18. Oct 1, 2023 at 12:41 PM
    #998
    treyus30
    Trey
    Mesa / AJ, AZ
    Probably just a tad off on the 100% voltage calibration point
  19. Oct 1, 2023 at 12:44 PM
    #999
    Speedytech7
    Yeah must be, it's not doing anything up there anyway, pretty much only manages my transient. I have the old 4 wire TPS that has a separate circuit for idle too and I've been told it has a more condensed range of variability.
  20. Oct 2, 2023 at 6:41 AM
    #1000
    Speedytech7
    Popped a poll up just to take some stock and see if we are really ignoring something important
    Torspd likes this.
