1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Oct 6, 2023 at 1:34 PM
    #1081
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    New feature released. It appears to do some kind of correction to fuel based on 1. how long you estimate it stays on intake value before evaporating, 2. what % pools on in the first place.
    Edit: Technically speaking, normally it wouldn't be a problem in a steady-state environment because the next cycle of fuel just replaces the previous pool. But in the transient state, we're injecting so much more fuel that it can be viewed as an independent event. Therefore, I think it's effectively going to be an overcompensation number working with the MAP Prediction table. eg: 20% pool ~= 20% more fuel than MAP-P table says since 20% will stay behind. Though I'm still not sure what effect evaporation rate has since that fuel should still be in the intake floating around somewhere. Perhaps it does look at the time since previous cycle (RPM) and calculates what % of fuel is still sitting there when a transient event is activated.... I would still think the charge air would bring nearly the full evaporated volume back in though.
    jubei[QUOTED] likes this.
  2. Oct 6, 2023 at 1:44 PM
    #1082
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Fuel injectors rarely spray directly into an open valve for their whole duration. The film is the fuel that wets the walls of the port and runner and back of the valve. It's fairly important to estimate properly for reaction and to avoid jerkiness on and off the throttle due to starvation or richness.
    unstpible and jubei[QUOTED] like this.
  3. Oct 6, 2023 at 3:52 PM
    #1083
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    That is super interesting!
    Thanks, gents!
  4. Oct 6, 2023 at 4:15 PM
    #1084
    Jon64l
    Jon64l Well-Known Member
    Jon
    2000 4runner, 1996 Tacoma
    jubei likes this.
  5. Oct 6, 2023 at 10:14 PM
    #1085
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    Maybe we could make a deal and get you into the Nexus and me learning on the 750. I remember talking a little about this a while ago but I kept telling myself that when I do a Haltech I'd want to spring for complete standalone capabilities and buy once cry once even if I don't set the throttle and transmission up right away.
    Maybe I should do the 750, learn a few things then sell it to the next guy when it's time to upgrade like your doing
  6. Oct 6, 2023 at 10:19 PM
    #1086
    treyus30
    Trey
    Mesa / AJ, AZ
    Just get the 2500 then put a grand in the SN(&)P500.
    unstpible[QUOTED] likes this.
  7. Oct 6, 2023 at 10:26 PM
    #1087
    Speedytech7
    2500 is likely a month or two from getting discontinued with the rest of the Elite line
  8. Oct 6, 2023 at 10:28 PM
    #1088
    treyus30
    Trey
    Mesa / AJ, AZ
    Wow, why?
  9. Oct 6, 2023 at 10:32 PM
    #1089
    Speedytech7
    For the Nexus S line that's soon to be unveiled. The Elites are over a decade old and Haltech just purchased a new manufacturing facility to ramp up production... writings on the wall
    jubei and treyus30[QUOTED] like this.
  10. Oct 6, 2023 at 10:34 PM
    #1090
    treyus30
    Trey
    Mesa / AJ, AZ
    Ack, I'm obsolete already
    Wifi programming would be nice though...
  11. Oct 11, 2023 at 6:26 AM
    #1091
    Speedytech7
    Went on an abruptly shortened wheeling trip but everything performed perfectly, hell even cold starts in Montana were easy, 1-2 seconds and it came right to life.
    @treyus30 Was thinking about your boost response, had a lot of hours driving this weekend, have you had Spool Assist turned on the whole time? On mine if I don't have it setup properly it will bring it in on the attack like crazy and overshoot pretty much if it isn't configured right.
  12. Oct 11, 2023 at 9:27 AM
    #1092
    treyus30
    Trey
    Mesa / AJ, AZ
    Ya I have spool assist set to follow 4psi behind the target (15). No overshoot, but it probably could help get the right DCs if I lengthened that gap a bit for the time being
  13. Oct 11, 2023 at 9:29 AM
    #1093
    Speedytech7
    When you're setting up your DCs initially that feature must be off, and with how violent your spool is described, I'd just have it off in general. Shouldn't be coming in so hard with the throttle barely open.
    treyus30[QUOTED] likes this.
  14. Oct 11, 2023 at 11:48 AM
    #1094
    unstpible
    Derek
    Cedar City, Utah
    My truck has been loving the cooler mountain air
    GoJo and Speedytech7[QUOTED][OP] like this.
  15. Oct 11, 2023 at 12:09 PM
    #1095
    GoJo
    GoJo Well-Known Member
    Utah
    Ditto!!! mid 60s to 70s intake temperature lately and loving it. Fried my first Innovate AFR Bosch sensor this past week... only 5 months in so a little concerning/disappointing but apparently not uncommon per reviews. Got that replaced, and some vBands tightened back up yesterday and she is running quite lovely.
    garetcurry and unstpible[QUOTED] like this.
  16. Oct 11, 2023 at 12:55 PM
    #1096
    unstpible
    Derek
    Cedar City, Utah
    I got some replacement Vbands for the crossover yesterday and I've still got a small exhaust leak somewhere as well (P0420 came back).
    surprisingly I haven't fried the bosch 02 sensor yet but I suppose there's still time since you were faster at getting it installed. I thought it was going to be dead after it lost power an hour or so away from home
    GoJo[QUOTED] likes this.
  17. Oct 11, 2023 at 1:45 PM
    #1097
    GoJo
    Utah
    Think your still leaking out of that manifold/crossover connection? You only sanded down the manifold vband right? Not the crossover portion?
  18. Oct 11, 2023 at 2:26 PM
    #1098
    unstpible
    Derek
    Cedar City, Utah
    Correct, that's a high possibility spot. If I had an extra set of hands to hold a rag on the tail tipe it would make pin pointing the leak(s) easier.
  19. Oct 11, 2023 at 5:09 PM
    #1099
    Jon64l
    Jon
    Hose clamp or similar device?
    unstpible likes this.
  20. Oct 11, 2023 at 9:54 PM
    #1100
    unstpible
    Derek
    Cedar City, Utah
    I thought about that or even just jamming a balled up rag in there. It doesn't have to be perfect just something to create a little pressure and not melt
