1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jan 23, 2024 at 6:04 PM
    #1281
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Isn't the OEM FPR, 40 psi?
  2. Jan 23, 2024 at 6:06 PM
    #1282
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    43.5psi
  3. Jan 23, 2024 at 6:14 PM
    #1283
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
  4. Jan 23, 2024 at 6:20 PM
    #1284
    Speedytech7
    That's not off in the weeds at all....
    betterbuckleup likes this.
  5. Jan 24, 2024 at 6:40 AM
    #1285
    Speedytech7
    unstpible and betterbuckleup like this.
  6. Jan 24, 2024 at 6:46 AM
    #1286
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    I just ordered one. Thanks for the idea!
    Speedytech7[OP] likes this.
  7. Jan 24, 2024 at 6:47 AM
    #1287
    Speedytech7
    The bolts or the bulkhead I just posted?
  8. Jan 24, 2024 at 6:49 AM
    #1288
    Jon64l
    Jon
    Bulkhead. I tried to order the bolts yesterday but the website said it wouldn't ship here.
  9. Jan 24, 2024 at 7:15 AM
    #1289
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Why is everyone running a 340 LPH pump when a 200 or 255LPH is more than enough without going over the 15amp stock wiring?
    Wouldn't it be easier to fix the connector and swap to a 200/255 LPH pump that only pulls 10-12 amps?
    I've been running a DeatschWerks DW200 for a few years and it's relatively quiet and supplies more than enough fuel.
    https://www.amazon.com/gp/product/B009PJPX40?ie=UTF8
    I had the walbro 190 for many years but it was and was getting louder so I swapped. The DW200 was a direct swap like any aftermarket pump in these trucks.
    1997tacomav6 likes this.
  10. Jan 24, 2024 at 7:21 AM
    #1290
    Speedytech7
    I've been running this same pump (Aero 340) in boosted vehicles since 2017 with 0 failures (from the pump itself at least), at this point it is more a trust thing since you take the truck to nowhere and back. DW was around but lesser known back then and I refused to run a shit grade Walbro that whines and absolutely will burn out. I'd be willing to try a DW200 in the future though. The other popular pump on TW is the AEM 340... neither of my Aero installs or any AEM install I've seen has burned the wiring where John and Ian did but I would love to know if it was a looser connection or something causing the pump to over-amp (restriction or something). On paper, if that stock fuel pump circuit is good for 15a then the Aero should have 2.5ish amps of headroom still. I will just beef the wiring for mine but maybe we will try a DW200 on the next person to cross my operating table.
    unstpible and TMFF[QUOTED] like this.
  11. Jan 24, 2024 at 9:19 AM
    #1291
    1997tacomav6
    Denver
    I had around 100k on my AEM340 before replacing it or so, no issues. And it makes no noise, there are fake ones out there BTW
    I did replace the 4" wire harness in the tank and the connector box on top of the tank to be safe since there are 25 years old wires
    TMFF[QUOTED] likes this.
  12. Jan 24, 2024 at 9:37 AM
    #1292
    treyus30
    Trey
    Mesa / AJ, AZ
    650cc/min = 234LPH; I don't like the idea of having only 8% headroom (in reality it's going to be less) on top of my injector max flow, when it's so cheap to just get the better one.
    ...also I had a Walbro 255. That thing was loud.
  13. Jan 24, 2024 at 9:46 AM
    #1293
    Speedytech7
    If you reach your injector max flow (which you should really only push injectors to around 80-85% of their duty to avoid them hanging) on a 3.4L with pump gas you're nearly 620hp (496hp if you use a sane persons injector duty cycle cap).... with the same duty cycle cap on E85 you're still pushing nearly 400hp. I get the point you're making but unless you're of a select few that are going to fully build their 3.4L (and use E85) that pump Tim recommended will work well I'd think. Certainly the supercharger guys don't need a big pump at least. With the exception of @Empty_Lord and @garetcurry there aren't really any built 5VZs on this site and only one of those will ever run in a vehicle :p
    unstpible and jubei like this.
  14. Jan 24, 2024 at 10:22 AM
    #1294
    treyus30
    Trey
    Mesa / AJ, AZ
    Both are always possibilities too... 400HP was just the starting goal
    but agreed on the duty cycle, I'd just omitted that. It's a contingency avoidance...last thing you want is running lean at max power because your alternator decided it was time to die or some weird particle blocked off part of your pump's filter or something
  15. Jan 24, 2024 at 11:22 AM
    #1295
    betterbuckleup
    Ian
    Concord, CA
  16. Jan 24, 2024 at 11:23 AM
    #1296
    Speedytech7
    I think there's enough room for it to make a gradual curve rather than a tight 90. But yeah definitely a valid concern if there's not enough headroom I won't use it
  17. Jan 24, 2024 at 1:48 PM
    #1297
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    Gotcha, I guess I was thinking more for the supercharger users with stock or slightly larger injectors.
    Mine setup with 295cc Denso injectors, DW200, Elite 2500, 65mm pulley on TVS SC I'm right at 80-81% duty cycle.
  18. Jan 24, 2024 at 1:52 PM
    #1298
    Speedytech7
    That's about all that's in those injectors without raising fuel pressure. Time for some 400s haha, don't leave the high altitude
    treyus30 likes this.
  19. Jan 24, 2024 at 5:53 PM
    #1299
    1997tacomav6
    Denver
    Add An FMU 3:1 will turn your 295cc into 350cc on demand and lower your duty cycle. I’m on stock injectors with FMU 340 AEM 60mm pulley 7.3 boost and duty cycle is around 80 percent + haltech, just got a 56mm pulley made and snout shaved
  20. Jan 24, 2024 at 6:18 PM
    #1300
    Speedytech7
    Is he in a smog zone? No good reason to use an FMU with a Haltech unless you absolutely have to keep your stock injectors.
