1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Apr 6, 2024 at 11:55 AM
    #1561
    Blue_Ruby
    Blue_Ruby Active Member
    Reuben
    Triangle Area NC
    2000 Tacoma SR5 Manual 4x4 White
  2. Apr 6, 2024 at 12:10 PM
    #1562
    Blue_Ruby
    Reuben
    Triangle Area NC
    @Speedytech7 One other question, do you know which pin on the factory connector triggers the fuel pump?
  3. Apr 6, 2024 at 12:17 PM
    #1563
    Blue_Ruby
    Reuben
    Triangle Area NC
    The truck is trying to light off but won't stay running so I think I may have he wrong fuel pin
  4. Apr 6, 2024 at 12:18 PM
    #1564
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    You have a different ECU connector than I do 95-97, 98-2000, and 01-04 are all different... but I can tell you its label probably.
    Should be FC on the ECU pinout for your truck. E7-18 would be my guess but I could be totally wrong if you have a California spec truck or something
  5. Apr 6, 2024 at 5:53 PM
    #1565
    Speedytech7
    I've been working on my rev limit, it's mildly spicy at a standstill but with load and boost now it turns into a Mac11 mag dump
    https://youtu.be/zJIkPLNwB00
    treyus30 likes this.
  6. Apr 6, 2024 at 6:24 PM
    #1566
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Wow, that needle movement. Yours is as lazy as mine is was.
    Blue_Ruby likes this.
  7. Apr 6, 2024 at 6:28 PM
    #1567
    Speedytech7
    During ignition cut it goes super low because it's not seeing the same amount of pulses as engine RPM. The haltech is reading RPM off of the crank sensor but the gauge gets its signal from the igniter which is having pulses cut to get the rev limit. The stock rev limit is fuel cut so normally this doesn't happen
    unstpible and treyus30 like this.
  8. Apr 6, 2024 at 6:38 PM
    #1568
    Digiratus
    Roaming the PNW
    The RedHead
    I was just referring to the stock behavior of my old dash. The tach had a tendency to be pretty lazy.
  9. Apr 8, 2024 at 4:51 PM
    #1569
    Blue_Ruby
    Reuben
    Triangle Area NC
    You were right, it's running!
    Another question, is there a data sheet anywhere of the stock injector specs? Trying to find the voltage curve and dead times.
  10. Apr 8, 2024 at 4:52 PM
    #1570
    Speedytech7
    I have some data saved for stockers, lemme dig it up
  11. Apr 8, 2024 at 4:57 PM
    #1571
    Speedytech7
    Hope this helps, I haven't tested it but it should be pretty close
    I think they're 240cc/min at 43.5psi
    Blue_Ruby[QUOTED] and unstpible like this.
  12. Apr 9, 2024 at 4:58 AM
    #1572
    Blue_Ruby
    Reuben
    Triangle Area NC
    Does someone have a Haltech tune for the 5VZ they’d be willing to share? Since their software is free to download I should be able to poke around for the values I need, or at least give me a place to start.
  13. Apr 9, 2024 at 6:13 AM
    #1573
    Speedytech7
    There's a few posted in this thread. Not sure there's much of anything useful in the fuel maps for you especially since you'll be running batch fire and your version of throttle pump or transient will be different. Maybe there's something useful in the timing maps, I dunno. You're welcome to poke through this one, its nothing special, just a stripped down version of an old one of my tunes that I use for diagnosis and startup on new 5VZ builds. At least on a Haltech Elite, loading this tune and checking wiring allocations pretty much guarantees a fire up and idle to begin tuning. I don't think the dead times and injector data in that map will help though, that tune is configured for the more common Green 650 cc/min injectors.
    unstpible likes this.
  14. Apr 9, 2024 at 6:16 AM
    #1574
    Blue_Ruby
    Reuben
    Triangle Area NC
    Thanks! Also have you ever used a timing light on a Tacoma? With the stock ecu it appears to be all over the place (FSM says it should be 3-18 degrees) and I’m wondering if my crank position sensor needs replacement.
  15. Apr 9, 2024 at 6:18 AM
    #1575
    Speedytech7
    There's no way to lock the stock computer to 0 to check timing that I know of like the old toyotas. In the Haltech I turn on the timing lock feature and pick 5* and then use a timing light to match the balancer notch to the mark on the timing cover. Get a timing light that either works for wasted spark or 2 stroke since it'll have twice as many ignition pulses as necessary on the #1 coil.
  16. Apr 9, 2024 at 6:22 AM
    #1576
    Blue_Ruby
    Reuben
    Triangle Area NC
    Yes, but the FSM has a range it’s not staying in, and the timing light I had was in 2 stroke mode and screen matched the RPM’s correctly.
  17. Apr 9, 2024 at 6:22 AM
    #1577
    Blue_Ruby
    Reuben
    Triangle Area NC
    The front passenger side is #1 right?
  18. Apr 9, 2024 at 6:24 AM
    #1578
    Speedytech7
    Yes
  19. Apr 9, 2024 at 6:27 AM
    #1579
    Speedytech7
    That range is only applicable on a fully warmed up engine (180 degrees or above) at proper idle (700rpm +/- 50) in neutral with AC and all accessories turned off
  20. Apr 9, 2024 at 6:28 AM
    #1580
    Blue_Ruby
    Reuben
    Triangle Area NC
    That is what my engine was at
