1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jul 26, 2022 at 4:59 PM
    #141
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    1997tacomav6[QUOTED] likes this.
  2. Jul 26, 2022 at 6:20 PM
    #142
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  3. Jul 26, 2022 at 8:01 PM
    #143
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Digiratus likes this.
  4. Jul 27, 2022 at 5:17 AM
    #144
    Itsgottabeyourbull
    Itsgottabeyourbull Well-Known Member
    Tulsa Oklahoma
    20 Tundra SR5 TSS/ 02 Tacoma DCSB TRD OR
    Digiratus[QUOTED] likes this.
  5. Jul 27, 2022 at 5:21 AM
    #145
    Itsgottabeyourbull
    Tulsa Oklahoma
    A lot of knowledge and experience in this thread… If I’ve got 10 grand of blow, in your opinion, what is the best option…
    - supercharger w/ haltech
    - turbo system
    - engine swap? Tundra v8, TDI diesel, or…
    1997tacomav6 likes this.
  6. Jul 27, 2022 at 6:47 AM
    #146
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    2JZ. BUILT. PERIOD.
  7. Aug 1, 2022 at 4:11 PM
    #147
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    I noticed that if I turn the key to the run position and leaving it there for a second before trying to start, the engine will crank and start very quickly. If I just turn the key from off to start in one motion like normal, it takes longer. Seems like the ecu takes time to completely start up. Wonder if wiring it to ACC would help
  8. Aug 1, 2022 at 4:34 PM
    #148
    Digiratus
    Roaming the PNW
    The RedHead
    Are you sure it isn't a fuel pressure thing?
    On mine, when I first turn the key to on, I can hear the fuel pump pressurize the system. I was told on cold starts (or any start where the truck has sat for a while) to let it cycle (3-4) seconds) before cranking. This is not required on a hot start where the truck has been running recently.
  9. Aug 2, 2022 at 2:35 AM
    #149
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    No not fuel pressure at all, more like the ecu has to boot up for a second.
    Speedytech7[OP] likes this.
  10. Aug 2, 2022 at 7:06 AM
    #150
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    Nice man I am not looking forward to my inspection in two years. I am sure I can make it through, but still dreading it. Plus I have to swap injectors back to stock and hope the old ones still work
  11. Aug 2, 2022 at 7:10 AM
    #151
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    1997tacomav6 and Speedytech7[OP] like this.
  12. Aug 2, 2022 at 7:11 AM
    #152
    Speedytech7
    Gotta love Washington, no more emissions testing here.
    Laxtoy and 1997tacomav6 like this.
  13. Aug 2, 2022 at 7:11 AM
    #153
    Speedytech7
  14. Aug 2, 2022 at 7:14 AM
    #154
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    What does your schematic show? Does it have an input at the ecu for both cam negative and crank negative? I found a tacoma schematic online and it did show the negatives spliced together with only one wire to the ecu after the splice
  15. Aug 2, 2022 at 7:24 AM
    #155
    Speedytech7
    Mine only shows the shielding being tied together.
  16. Aug 2, 2022 at 7:26 AM
    #156
    Speedytech7
    Hmm actually the OE Electrical diag shows it with splices internally at the ECU
    MadTaco461 likes this.
  17. Aug 2, 2022 at 7:30 AM
    #157
    Speedytech7
    To me this looks like the factory wiring has the camshaft sensor using the crank sensor negative as a pull up or a bias
    MadTaco461 and 1997tacomav6 like this.
  18. Aug 2, 2022 at 7:59 AM
    #158
    1997tacomav6
    Denver
    I talked with Gabe about this and he said it can be wired with a dedicated separate wire for both sensors to the haltech and bypassing the stock ECU,
    might be something I will do later on
  19. Aug 2, 2022 at 8:01 AM
    #159
    Speedytech7
    Yeah, the haltech expects them to be separate anyway, should just be a matter of decoupling the splices or running a separate shielded twisted pair cable to the crank sensor, either one can accomplish the goal.
  20. Aug 2, 2022 at 8:07 AM
    #160
    1997tacomav6
    Denver
    Yes, has always been like this, starts immediately regardless of temperature and no need to wait for the fuel pump or anything
