1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jun 6, 2024 at 7:29 PM
    #1641
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Helps the heat a ton but it's not super hearty if you get stuff on it. Like if you let mud set on it it will ruin it's integrity if you don't wash it off fast enough. If I redo this coating I'll get a glossy coat next since they repel better. Also I need to put my engine skirts back on. Wrap will cause most exhausts to either corrode or crack depending on if it's mild or stainless so cea is still the better option for longevity, I just touch mine up with some canned stuff every once in a while. Making a little shield would be the biggest help
  2. Jun 7, 2024 at 8:20 PM
    #1642
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    I think my wideband O2 sensor is also on its way out. It's been just shy of a year but my guage has always struggled a little anyway so it's probably a combination of both. I have a new sensor but I'll install it when I have something else to read it, Until then I'll just consider the dying sensor a plug.
    Good news, I have more time to work on projects
    Bad news, I have less funds for said projects
    Good news, the Haltech show must go on.
    It's getting hot outside and the need for heat management is back. I was thankful for winter keeping my engine cooler and blasting the heater was helpful but
    The truck is still driving awesome but the mercy of cooler air temperatures is almost over. A few weeks ago while on a steep grade the coolant jumped to 216°f and the transmission hit 210°f, it took a while for the temperatures to get below 200.
    I still need to get my downpipe coated, It just didn't exist when everything else got done
    I'm also going to need to find a way to install the Haltech and keep my passenger side air ducting.
  3. Jun 7, 2024 at 8:30 PM
    #1643
    unstpible
    Derek
    Cedar City, Utah
    I did at least get some good Smiles per Gallon this week.
    MadTaco461, treyus30 and jubei like this.
  4. Jun 8, 2024 at 10:20 PM
    #1644
    unstpible
    Derek
    Cedar City, Utah
    What a hot day, 104 in St George. Intake was reading at 118 in the parking lot, it took a while to cool off before shutting it down. On the way home the coolant temp peaked at 231 on I-15 but at least the transmission stayed under 190.
    Less than an hour later my brother called me while heading north on I-15 and said his jeep was having issues with the heat in the same spot I did.
    Lots of blown tires on the road and several big rigs pulled over on the hills with the hoods up.
    I probably over stress the engine temperatures but when I see it getting hot while under "regular operating conditions" this early in the summer it makes me uncomfortable thinking about July and August.
  5. Jun 8, 2024 at 10:25 PM
    #1645
    Speedytech7
    Yeah I would be concerned if you're getting over 210 regularly. There's probably something wrong with your cooling system or perhaps with your head gaskets. That's a lot of heat. I can absolutely hoon mine around on a 90° day, like that's actually the day with it we tuned my boost control. It was just pull after pull after pull and I never got over 205. And when I did it immediately came back down to 194 after a minute
    unstpible[QUOTED] likes this.
  6. Jun 8, 2024 at 11:02 PM
    #1646
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow, that is really hot. Now I'm very curious about what mine will do in similar conditions. I have yet to see any coolant temps higher than 165°F.
    Now intake air temps is a different story. With the 2.2" pulley I have seen 200°F on more than one occasion.
  7. Jun 9, 2024 at 12:12 PM
    #1647
    unstpible
    Derek
    Cedar City, Utah
    I haven't lost any coolant. My thought is possibly an air bubble in the system from when I did the water pump last year I never used one of those big bleeder funels in the radiator cap but I did leave it running on an incline for a while
  8. Jun 9, 2024 at 1:56 PM
    #1648
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    At one point I actually considered making an outer shell of larger exhaust tube over the actual one and pulling a vacuum on it as an insulation experiment, but...too many bends, too much work as it was
  9. Jun 9, 2024 at 2:16 PM
    #1649
    unstpible
    Derek
    Cedar City, Utah
    I also haven't put my engine skirts back on. They are a little weathered and cracking
  10. Jun 9, 2024 at 2:33 PM
    #1650
    Speedytech7
    Some vehicles come from the factory with double wall exhaust piping for insulation sake and to reduce nvh. I don't think you'd be able to pull a good enough vacuum on it anyway for it to be worth vacuuming it down. That sounds like some kind of crazy shit Koenigsegg might do haha. Be cool, but I'd only bother if it was like a nice stainless setup or something. Mild will develop a leak pretty quick from corrosion I'd think.
  11. Jun 9, 2024 at 3:45 PM
    #1651
    unstpible
    Derek
    Cedar City, Utah
    @GoJo, I see you lurkin are you going to beat me on installing a haltech like you beat me on the Turbo install?
  12. Jun 10, 2024 at 8:32 AM
    #1652
    GoJo
    GoJo Well-Known Member
    Utah
    haha nope, just like keeping current on things :)
    I am currently trying to get past emissions... damn po420! Tried to clear the codes and drive around enough for most the ecu emission checks to 'complete' but when I took it in last Friday the system was still in a Not Ready state that they failed it and told me to drive around more... so got some solutions coming this week to try out, otherwise might be welding up a test pipe from my stock exhaust and hopefully passing that way
  13. Jun 10, 2024 at 9:13 AM
    #1653
    unstpible
    Derek
    Cedar City, Utah
    Damn, what have you done to check for exhaust leaks? I know I still have at least one on the turbo side somewhere
  14. Jun 10, 2024 at 9:53 AM
    #1654
    GoJo
    Utah
    I have stethoscope all my joints and haven't heard an major clicking but that is about it. I don't think its from exhaust leaks, but rather the high flow single cat system vs the stock double cat system from before. ODBII readings are just over the max values, so I am close but still through code that pops the CEL and will fail emissions test straight away.
  15. Jun 10, 2024 at 11:27 AM
    #1655
    unstpible
    Derek
    Cedar City, Utah
    I still think this might be worth a try. If your exhaust still has that little heat shield for the rear O2 sensor they might not notice with it being up on top so far away from the Cat:notsure:
    I've had that P0420 for a while. Started with the DT headers. I tried adding new cats didn't work. Tried installing turbo manifolds, didn't work.
  16. Jun 10, 2024 at 11:29 AM
    #1656
    GoJo
    Utah
    yea that is what I got coming this week, that and some resistors and capacitors :)
    They already took the picture of my system (stupid change to emission here in SLC county), so if the extension works, I may be able to get away with that.
  17. Jun 11, 2024 at 11:11 AM
    #1657
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    unstpible and Digiratus like this.
  18. Jun 11, 2024 at 11:56 AM
    #1658
    treyus30
    Trey
    Mesa / AJ, AZ
    TMFF[QUOTED] likes this.
  19. Jun 14, 2024 at 7:38 AM
    #1659
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    Has anyone installed an aftermarket fuel pressure regulator and noticed an improvement or more consistent fuel pressures over the stock unit?
    I already have an upgraded fuel pump and larger injectors so this would be the last item to address on the fuel delivery system. Not that the stock FPR is showing any signs of malfunction or anything.
  20. Jun 15, 2024 at 1:17 PM
    #1660
    Speedytech7
    Recently did it on an RX7 and we added a Syltech pressure/temp sender too back to the Haltech. Just nice to know exactly what the FP is on a car that's extremely sensitive to change like that
