1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Aug 2, 2022 at 8:31 AM
    #161
    DrabT100
    DrabT100 Ex-Lexus Tech
    East Coast
    1997 T100 Turbo
    Turbo
    Exactly. Bypass the pnp harness altogether
  2. Aug 2, 2022 at 11:16 AM
    #162
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Thanks to the Excel magic of @turbodb I am starting to compile an idea of what the stock ignition map looks like. This is a preliminary result of 3 separate drive with mixed conditions.
    Gonna try to fill more of it in and get better averages
    devinzz1, jubei, treyus30 and 4 others like this.
  3. Aug 2, 2022 at 6:10 PM
    #163
    1997tacomav6
    Denver
    Is this with the FMU installed?
    Or are you not going to run one?
  4. Aug 2, 2022 at 6:13 PM
    #164
    Speedytech7
    No FMU for me, just gonna run 450cc injectors. This is literally just recorded output from my stock computer as I drive around though
    jubei and 1997tacomav6[QUOTED] like this.
  5. Aug 3, 2022 at 12:34 AM
    #165
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Charged me less then $275 for a piggy back fic6 harness https://www.autosportwiring.com/index.html
    They do stand alone harness's also.
  6. Aug 3, 2022 at 3:14 AM
    #166
    DrabT100
    East Coast
    1997 T100 Turbo
    Turbo
    mechanicjon[QUOTED] likes this.
  7. Aug 3, 2022 at 12:10 PM
    #167
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    I'm assuming that's staying out of WOT/open loop? What are you reading those with?
  8. Aug 3, 2022 at 12:43 PM
    #168
    Speedytech7
    It doesn't discriminate between open/closed loop, frankly that's fine because in that load cell it probably shouldn't be closed if the load is that high. This is done with high polling rate OBDII datalogging.
  9. Aug 3, 2022 at 1:42 PM
    #169
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    Could you expand on this? Just using an OBD2 reader and datalogging to a CSV file and filing in an excel sheet?
  10. Aug 3, 2022 at 1:50 PM
    #170
    Speedytech7
    Yup, I'm using my OBDLinkSX and reading it on my tuning laptop with OBDWiz. In OBDWiz I chose the PIDs I wanted to monitor (the fewer you monitor the faster the polling rate) and literally set it to log those PIDs for the entire length of drives. Then those lists get put into the excel sheet which sorts them my RPM and LOAD % and plots the ignition degrees, obviously theres more than one ignition degree value per cell when youre recording for so long so it averages them. This give a realistic value and keeps it safe so an outlier can't make the list f'd up.
    MadTaco461[QUOTED] and jubei like this.
  11. Aug 3, 2022 at 3:23 PM
    #171
    treyus30
    Trey
    Mesa / AJ, AZ
    Hmm, you might be getting some inconsistencies on the right side and bottom of the table then. If you're feeling up to it, a standard deviation for each cell would be interesting
    jubei likes this.
  12. Aug 3, 2022 at 3:31 PM
    #172
    treyus30
    Trey
    Mesa / AJ, AZ
    For the record, this was my tuning spreadsheet I made a long time ago for the FTC which is basically an extended version of what it looks like turbodb made you
    MadTaco461 likes this.
  13. Aug 3, 2022 at 3:47 PM
    #173
    Speedytech7
    This is more of an @turbodb question. I'm not an excel guru and I'm unsure if that's something that it can generate easily. I'm really concerned with normal driving range to be honest. High load low rpm whole important is pretty easy to tune and to be honest low values are expected. It needs more data and I haven't had time to drive the thing more yet. If anyone wants to try I can give them the Excel sheet. I'm just taking a bunch of rides where I drove like I usually do, a bunch of those averaged seems like it should arrive at a safe enough number
  14. Aug 3, 2022 at 4:00 PM
    #174
    treyus30
    Trey
    Mesa / AJ, AZ
    I guess I'm ultimately a little confused because it was you who originally told me those OBDII values were not absolute timing advance.
  15. Aug 3, 2022 at 4:08 PM
    #175
    Speedytech7
    I don't know when I would have said that, it can be true of the 3RZ and 1FZ. The 5VZ has no adjustable metrics. You can even check base timing by bridging TE1 and E1 if you want to make sure. I guess in a literal sense it may not be absolute, there is drift with higher RPM. If we were talking about it with the FIC that also affects absolute timing advance cause it alters it and the computer is unaware.
  16. Aug 3, 2022 at 5:05 PM
    #176
    MadTaco461
    CA
    Kinda stock
    Think you can shoot me your excel sheet? I'll log up my timing table. Not that I have time to drive my truck right now.
    I can be a bit more aggressive with my timing since I'm going to use a knock sensor.
  17. Aug 3, 2022 at 8:53 PM
    #177
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    @treyus30
    I know XL, but I'm not all that familiar with tuning, so what do you mean by showing a stdev for each cell? You just mean to show the stdev for each bucket, instead of the avg? Essentially, a second table that you'd view to see how consistent each bucket is?
  18. Aug 3, 2022 at 9:18 PM
    #178
    treyus30
    Trey
    Mesa / AJ, AZ
    Yup
  19. Aug 3, 2022 at 10:53 PM
    #179
    turbodb
    Dan
    PNW
    AdventureTaco
    Gotcha. Well, Zane, here's an updated workbook. I also threw in a table of the count of data points per bucket, just to make sure I was getting the right values for the STDEV. Note, calcing STDEV this way is very CPU intensive; took most of a minute with all 20 cores of my i7 12700 CPU pegged.
    @Speedytech7
  20. Aug 3, 2022 at 10:56 PM
    #180
    Speedytech7
    Gonna make my 3770k catch fire then haha
