1st Gen Haltech ECU Discussion
Discussion in '1st Gen. Tacomas (1995-2004)' started by Speedytech7, Jul 19, 2022.
  1. Jul 31, 2024 at 11:40 AM
    #1921
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I think in the context of 80s/90s turbos and control equipment maybe. I think we've done better in modern times without it, hence no one doing it anymore.
  2. Jul 31, 2024 at 11:42 AM
    #1922
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    worst case is I remove the valve if it sucks lol
  3. Jul 31, 2024 at 11:45 AM
    #1923
    Speedytech7
    What's your plan for wastegate duty cycle management since you control both turbos with one valve but the turbos are spooling at different times. This all gets weird without precontrol I think.
  4. Jul 31, 2024 at 11:59 AM
    #1924
    unstpible
    unstpible Well-Known Member
    Derek
    Cedar City, Utah
    03 4x4 boosted V6 Auto 341k miles
    CX Racing Turbo kit. TransGo shift kit. All Pro Apex bumper and skids. Smittybilt XRC 9.5 winch. All Pro Upper control arm's. Bilstein 6112's with 600lb coils. Eimkeith's lower control arm reinforcement plates. Perry Parts bump stops. All Pro spindle gussets and alignment cam tabs. All Pro standard 3" leaf springs. Bilstein 5125's rear. Extended rear brake lines. Rear diff breather relocation. MagnaFlow catback with resonator. Bluetooth stereo. Memphis 6x9 door speakers. Diode Dynamics SS3 Pro Amber fog lights. Single piece headlights. aftermarket grille. Anzo taillights. LED 3rd brake light. 4runner sunglass holder and dome lights. Master Tailgaters rear view mirror with 3 directional cameras, G shock sensors, and anti theft system. Honda windshield washer nozzles. Stubby antenna. Scan Guage II. 2nd Gen Snowflake wheels powder coated black. Cooper Discoverer ST Maxx 235-75/16 Denso 210-0461 105 amp alternator. Speedytech7's big wire harness upgrade. Aeromotive 340 fuel pump. Haltech Elite 2500. Tacomaworld sticker. Tundra brakes with Adventure Taco's hardline kit
    NSP had another update apparently
  5. Jul 31, 2024 at 12:08 PM
    #1925
    treyus30
    Trey
    Mesa / AJ, AZ
    If I set activation psi sufficiently above the bypass threshold (lets say 4psi), there shouldn't be noticeable interference. So the control sequence would be something like:
    1. Ride turbo 1 up to WG pressure - 14psi -> WG control active at 10psi, open at 14psi, spool assist prior to 10psi
    2. Load limit (MAF) of turbo 1 approaches -> turbo 2 flap starts opening via ECU, psi wants to drop due to lost exhaust pressure on turbo 1 but we control opening via PID to maintain around 10psi combined until fully opened -> WG inactive
    3. Turbos 1 and 2 now fully coupled and WG reactivated at 10-14psi
    What would be interesting is the feeling around the transition and tuning it. Would there be a lull due to the psi drop and recovery, would it be linear because psi drops but mass airflow is still increasing? Could I push turbo 1 to much greater psi up to a torque limit and gradually drop pressure over the whole RPM run as turbo 2 kicks in (MAF -> torque)? Imagine a torque plateau at 2k-redline.
  6. Jul 31, 2024 at 12:10 PM
    #1926
    treyus30
    Trey
    Mesa / AJ, AZ
    Anything good?
  7. Jul 31, 2024 at 12:21 PM
    #1927
    unstpible
    Derek
    Cedar City, Utah
    I can't tell a difference but that's not saying much
  8. Jul 31, 2024 at 12:49 PM
    #1928
    Speedytech7
    In my experience there is a weird lull/pressure drop as second turbo comes online, it can be minimized but not removed. Torque management would be tough without the 2500T since all your methods of torque output control would have to be hand jammed to some degree, none of the canned features exist in the regular 2500. What's the goal here? Or is it just throwing science at a wall and seeing what sticks, I'm all for that just not on something I drive regularly haha.
    treyus30[QUOTED] and unstpible like this.
  9. Aug 1, 2024 at 7:02 AM
    #1929
    Speedytech7
    To demystify things and since I seem to be doing a large amount of 2RZ/3RZ/5VZ initial setup, basemapping, and initial tuning I have decided to make a video series on setting up a new Haltech PnP install and getting it ready to be drivable. I have a 2RZ scheduled in a couple weeks so I can cover the 4 bangers too. Not that anyone in here really needs this, but I figure new folks will find this thread and it may help them decide if the whole thing is for them if they can see all the steps and what will continue to need work or a final tune from someone else.
  10. Aug 1, 2024 at 9:59 AM
    #1930
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    That'll be a great help for the community! Would be great to have some sort of video coverage on that to sort of demystify the initial setup tuning part of getting into a standalone setup on these trucks. I know I sure would have appreciated it starting out
  11. Aug 1, 2024 at 10:13 AM
    #1931
    unstpible
    Derek
    Cedar City, Utah
    :spy: definitely nobody in here would need that...
  12. Aug 1, 2024 at 6:09 PM
    #1932
    unstpible
    Derek
    Cedar City, Utah
    Thanks to Zanes wizard skills the truck is running. It was a little rough when we first started it but as soon as I started it up the second time it smoothed right out.
    First this I noticed is that the blower motor only turn on if it's on high so it's all or nothing for the air conditioner/heater at the moment
    Digiratus, Jon64l and Speedytech7[OP] like this.
  13. Aug 1, 2024 at 6:11 PM
    #1933
    Speedytech7
    I think that's unrelated. There shouldn't be any intervention in that system from the haltech
  14. Aug 1, 2024 at 6:31 PM
    #1934
    unstpible
    Derek
    Cedar City, Utah
    I think the coolant and intake temperatures are a little off now too. The intake is trying to convince me it's 46° and the coolant temperatures is reading around 112°
  15. Aug 1, 2024 at 6:49 PM
    #1935
    Speedytech7
    We can try turning off the Pull-Ups on those inputs I'm seeing if the value changes
  16. Aug 1, 2024 at 7:08 PM
    #1936
    unstpible
    Derek
    Cedar City, Utah
    The coolant and intake temperatures appear to be reading correctly in NSP but it's definitely wrong on the Scanguage.
  17. Aug 1, 2024 at 7:11 PM
    #1937
    Speedytech7
    Yeah I think it it's because the pull-up is on. Maybe @treyus30 will comment cuz he's one of the only other people I know that runs the haltech as a piggyback. I can't remember if the pull-up should be on or if the stock computer provides it
    unstpible[QUOTED] likes this.
  18. Aug 1, 2024 at 8:22 PM
    #1938
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    As having an auto myself, you will be finding several things like this. With the ScanGauge connected to the OBDII port, there will be some things like coolant temps, that the OEM computer will have no clue as to what's actually happening.
    unstpible likes this.
  19. Aug 1, 2024 at 9:50 PM
    #1939
    unstpible
    Derek
    Cedar City, Utah
    Hopefully that Scanguage will just be removed like the Innovate guage here pretty soon.
    IC7 :drool:
  20. Aug 1, 2024 at 9:52 PM
    #1940
    unstpible
    Derek
    Cedar City, Utah
    The only pull-ups I know of involve hanging from a metal bar or come with a warm moist feeling in the middle of the night
