1st Gen Head Unit Recommendations
Discussion in 'Audio & Video' started by mockwarrior39, Mar 14, 2024.
  1. Mar 14, 2024 at 9:24 PM
    mockwarrior39
    mockwarrior39 [OP] Member
    Hey all,
    I just bought an '02 Xtracab and the radio doesn't work (i'm thinking its just straight dead, no lights on it and no dead fuses or bad wiring from previous owner) so I'm looking to get something modern.
    What do y'all use? I'd like a double din with a touchscreen, but I'm not opposed to single din's that are cheap, decent quality and easy install. Looking to stay under $300, but quality options over that I won't ignore.
  2. Mar 19, 2024 at 12:47 AM
    TruckGuy63
    TruckGuy63 Well-Known Member
    Gilbert
    New York
    2019 Barcelona Red Dbl Cab TRD Offroad
    Pioneer , Kenwood, Sony
    Look on Crutchfield
    ZMan2k2 likes this.
  3. Mar 19, 2024 at 5:05 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    weirder things have happened-- i would check behind your current radio to make sure it's plugged in. and if it is, verify you have power on that radio plug with a volt meter.
    it's not so bad to still want change, but i've seen some people right before they go to sell, swap out all their aftermarket gear, but just never connect the old factory gear they put back in.
  4. Mar 19, 2024 at 5:12 PM
    TruckGuy63
    Gilbert
    New York
    I agree , I’ve seen that many times .
  5. Mar 19, 2024 at 6:23 PM
    Memeplayer1
    Memeplayer1 Lifted beetle
    Omar
    Sacramento, CA
    2003 Black PreRunner, AT, 3.4l
    Flowmaster muffler, 3 inch lift kit, SPC UCAs, Magnecor 7mm Plug Wires, NPBoosted Coil Packs, 4.56 ratio change
    I use an ATOTO S8 Premium. It works pretty good so far. You have to buy a harness adapter in order for it to plug in properly
  6. Mar 24, 2024 at 10:52 PM
    mockwarrior39
    I beat you to that, I pulled the radio and verified that i’m getting power (both the always hot pin and the hot on “ON” pin). I actually dissected the unit while I had it out to see if I could see anything obviously wrong internally, but I did not find any issues there. I did scrub some corrosion away but nothing changed so unless I have some other weird issue going on, looks like it’s time for a new unit.
    soundman98[QUOTED] likes this.
  7. Mar 27, 2024 at 5:54 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
