1st Gen HID HELP
Discussion in 'Lighting' started by YotePower, Mar 18, 2013.
  1. Mar 18, 2013 at 12:22 PM
    YotePower
    YotePower [OP] yotepower
    Dillon
    Louisville, TN
    96 Ext Cab 3.4L 5 speed 4x4
    Fixing the previous owners mistakes.
    I would like to order a set of HID headlights. I drive a lot and it seems like my headlights have a lot of room for improvement. I would like to get the brightest headlights I can for a decent price. I know nothing about HID systems so any words of wisdom yall can throw my way would be much appreciated.
  2. Mar 18, 2013 at 12:31 PM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    1st and foremost do a lot of research on the topic. I was in the same situation and drove a lot at night, 3rd shift. HID's helped me a lot.
    The higher the K rating the bluer/greener/pink the color gets, that doesn't refer to brightness. Lookup a Kelvin scale.
    You have 35watt, 55watt, etc bulbs similar to normal halogen headlights, this is brightness. These wattage ratings are not the same between HID and Halogen, a 55w halogen is about as bright as a 35watt HID.
    Check out Slim cubby for a plug and play kit. The proper way to put in HID's is with Projector housings and not the reflector housings that are stock.
  3. Mar 18, 2013 at 6:22 PM
    YotePower
    Dillon
    Louisville, TN
    Thanks man ill check it out for sure
