1st Gen How-To: Change your belts (P/S, A/C, Alternator) 2.4/2.7L
Discussion in '1st Gen. Tacomas (1995-2004)' started by The Parts Whore, Dec 29, 2009.
  1. Oct 27, 2013 at 5:41 AM
    #41
    JSFoster75
    JSFoster75 Well-Known Member
    Scott
    Bluff City, TN
    2018 Wrangler JLU Sahara
    Too many to list.
    Not sure what the life is, but the ones I just purchased came with a 3 year warranty, so, if I still have it in 3 years, I plan to change them again. :) Easy to do, doesn't cost much, and beats sitting beside the road broken down. :)
    All 3 belts cost me $32 after 30% discount at Advance Auto Parts (online) using a coupon code. An updated list of Coupon Codes can be found here: http://www.retailmenot.com/view/advanceautoparts.com
  2. Oct 27, 2013 at 10:10 AM
    #42
    Plugger812
    Plugger812 Member
    Keith
    So. NM
    02 Base Truck w/Snugtop
    I just bought my Taco, it has 104k on it and I changed the belts just because. They were original, dried and cracked so I'm glad I did it. Cheap insurance....... Here's a link that may help. http://www.gatesprograms.com/beltwear/inspection Good luck!
  3. Dec 12, 2013 at 5:36 PM
    #43
    boetschy
    boetschy New Member
    kip
    union
    2003 tacoma toyota
    none
    great pic. and steps..thanks for the info.....big help...kip
  4. Jan 4, 2014 at 3:41 PM
    #44
    cfree5119
    cfree5119 Well-Known Member
    What size is the tensioner bolt that adjusts tension on the alternator? My bolt rattled out... Thanks
  5. Feb 1, 2014 at 5:53 AM
    #45
    Shikkapow
    Shikkapow Active Member
    Sunny Florida
    01 sr5 4x4
    did this last night, it was a 2 beer job. (2001 2.7L with A/C)
    no need to take off the fan shroud bolts other than the top two for the airbox line (just take the top 2 off and move the line above the throttle.)
    I took the skid plate off and it was super easy to get it all done
  6. Mar 28, 2014 at 10:34 PM
    #46
    7luis60
    7luis60 New Member
    Escondido CA
    02 Tacoma Lowered
    Thanks so much. You're a saver, belt broke off and replaced it in no time thanks to you.
  7. Jun 30, 2014 at 9:35 AM
    #47
    Tribull
    Tribull Have more than you show. Speak less than you know.
    Little Rock, AR
    2021 Toyota Tacoma TRD Offroad 4x4
    Bone stock. For now.
  8. Jul 5, 2014 at 12:33 PM
    #48
    usmcmcc
    usmcmcc New Member
    RI USA
    Tacoma 4X4
    Thank you for this post.
    I had no problems following this and changing the belts.
    Thanks Again.
  9. Jul 5, 2014 at 5:10 PM
    #49
    elgato8905
    elgato8905 New Member
    Orange County, California
    2003 2.4 Tacoma
    So I went to Autozone to pick up all three belts for my 2003 2.4L Tacoma and two of them are different than the part numbers that the OP posted in the beginning of this thread. They gave me the correct one for the alternator according to the original post (304K5), but for the power steering they gave me a Duralast 437K4 (the OP lists it as the 440K4...), and for the air conditioner/idler they gave me a 343K4 (OP lists it as 342K4 which Autozone says they don't even carry...).
    Does anyone know if the belts they gave me will work? I'm thinking it's been a while since the OP made this thread so maybe the manufacturer changed what it thought should be used on the truck or something? Having said that though, I would tend to trust the OP on his recommendation as he seems to know exactly what he's doing with this job. I already called two different Autozone stores to double and triple check that the ones they gave me were the right ones for the job. According to all of them, the ones they gave me are the correct part numbers in their system for my truck. Any help here would be GREATLY appreciated! This will be my first attempt at changing belts in anything and I'm already going to be tripping over myself to get the job done even if I have the right parts. The last thing I need is to start the job only to find out halfway through that I have the wrong ones. That would definitely be a bummer.
    Hopefully someone can help... Thanks in advance!!! :confused:
  10. Jul 5, 2014 at 5:19 PM
    #50
    oldblue1968chevy
    oldblue1968chevy Well-Known Member
    Spokane WA/Viola TN
    2000 Toyota Tacoma V6 TRD
    Stock
    Seems like I used the op # on my 2.7 and one was too short/long end up going back for a different belt.
  11. Jul 5, 2014 at 5:29 PM
    #51
    elgato8905
    2003 2.4 Tacoma
    Well the odd thing is that having read through this whole thread, the one belt that some people seem to have trouble with being too small would be alternator belt. Strangely that's the only belt that the OP and Autozone have as being the same. Do you remember if that's the same one you had trouble with???
  12. Jul 24, 2014 at 3:45 PM
    #52
    nboone
    nboone New Member
    glencoe, ky
    02 tacoma 4x4
    do you have to torque the pivot bolts? the haynes manual says nothing but hand tightening
  13. Aug 7, 2014 at 8:55 AM
    #53
    talltreesandmoss
    talltreesandmoss New Member
    New England
    '03 2wd
    Hey, my ac belt broke because the tensioner pulley was jammed against the tensioner housing. After I took off the pulley, I noticed there was no washer or bushing to hold the pulley away from the housing. Does anyone know what the ac pulley assembly should include? I think the mechanic I took it to may have forgotten to reassemble things correctly when I had him replace ac pulley a couple weeks ago. (It's no good asking because he was a backroad mechanic I happened to pass by on a road trip). Thanks for any help or suggestions.
  14. Aug 15, 2014 at 10:44 PM
    #54
    97TacoNM
    97TacoNM Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    I realize this is an older post, but I just did this for the first time on my 97 4x4 2.7L Ext Cab. There are 7 bolts holding on that front skid plate. About the middle, on each side, are holes that have bolts up in them. That may be packed with road grime and mud, making it impossible to see there are bolts there, but there are. You remove those and it comes off. I removed the rear plate that has 2 bolts as well to get it all out to clean up a world of uck that was gummed up in there.
  15. Aug 15, 2014 at 10:46 PM
    #55
    97TacoNM
    Jim
    NM
    I just did this tonight. I will take a pic of my AC pulley in the morning and post it for you.
  16. Aug 15, 2014 at 10:47 PM
    #56
    97TacoNM
    Jim
    NM
    I got the recommended belt from Autozone, and if you do not really swing that alternator in you will never get that new belt on. Just back that tensioner bolt way off and push that bad boy up/in to get maximum play. You'll get that belt on, then can pull that alternator back out no prob.
  17. Nov 9, 2014 at 1:38 PM
    #57
    TacomaEastBay
    TacomaEastBay New Member
    East Bay, San Francisco Bay Area
    2.4L
    Thanks, this was really Helpful. I got belts from CarQuest:
    Power Steering: K4254 (fit nicely)
    Alternator: K3405 (fit nicely)
    Water Pump/AC: K3454 (kinda small - had to get the idler pulley all the way down to get it on).
    Would like some advice on how to correctly set the belt tension. I just did it by "feel" and things seem great but...
    Gwen02prerunner likes this.
  18. Nov 9, 2014 at 6:50 PM
    #58
    97TacoNM
    Jim
    NM
    Timing belt...that is a different creature. This thread does not include anything about the timing belt, just FYI. Only the accessory belts.
  19. Jan 11, 2015 at 5:22 PM
    #59
    tacomatt602
    tacomatt602 Well-Known Member
    Phoenix, AZ
    1997 5lug Regular Cab 2.4l
    Doetsch spindles, V6 coils, Fabtech AAL, 4Crawler 2" body lift, Daystar coil spacers, Bilstein 5100s (rear), 15x7 U.S. Wheel Stealth Stars, 225/70r15 Firestone Destination LE2s, '00-04 side mirrors, Prerunner/4x4 grille, Kobalt low-profile toolbox, fucked steering rack D:
    I didn't know how much to tighten the adjusting bolt for the PS so I just tightened it 'til the surface of the head of the bolt met the surface of the bracket itself. I started my truck and heard no squeaking but I wasn't content. I loosened it PRETTY far then started it again... no squeaking, so I tightened it back to where it was... still no squeaking, then I tightened it some more for some reason. One thing led to another and I broke the bolt. So it is no longer adjustable... but there is still no squeaking.
    Does this mean that it doesn't matter how tight the PS adjusting bolt is? Or if it even needs to be there in the first place?
  20. Jan 11, 2015 at 5:33 PM
    #60
    Speakerboy
    Speakerboy Well-Known Member
    Jim
    Center Valley, PA
    '02 Xtracab 5 lug manual
    There is actually a spec for belt deflection. I tightened it until I could wiggle it back and forth about 3/4". If you tighten the belt too much, you will wear out bearings and such by having too much of a side load.
