1st Gen Icon 2.5 IFP Revalve/Piston Modification
Discussion in 'Suspension' started by PathFinder1776, Jul 9, 2024.
  1. Oct 21, 2024 at 10:18 AM
    PathFinder1776
    PathFinder1776 [OP] Well-Known Member
    Colorado Front Range
    2003 DCSB TRD OR 4WD
    TRD S/C & TRD Boost Gauge Snugtop Topper Chevy 63 Swap, Gen 1 Raptor Shocks Boxed rear frame Aluminum F/R bumpers, sliders AEM 340 Fuel Pump Odyssey 27F Battery Shifted LCAs UCAs Icon 2.5 Ext. Coilovers
    Got them all back together and on the truck. Ended up leaving one bleed hole open instead of two because I drilled and tapped them out to 4-40. That gives .025" of area vs .030" for two #2 holes. Haven't really tested them much yet, but they're definitely firmer. Not a ton, but noticeably. Will post an update when I get to drive it more.
    Also learned that IFPs are not nearly as friendly to rebuild as reservoirs. These coilovers and the Gen 1 Raptor shocks in the rear are the first shocks I've rebuilt and played with valving/tuning on. The Fox reservoirs were far easier to work on at every stage. The small gas volume and having everything all in one cylinder on the IFP makes them a little trickier to deal with.
    AShive92 likes this.
  2. Nov 4, 2024 at 11:20 AM
    PathFinder1776
    Update: They're definitely firmer at low shaft speeds. Not terribly, but next time I have them apart they'll go back to just one bleed screw and two open holes. The high speed valving seems to be pretty good.
