1st gen leveling
Discussion in '1st Gen. Tacomas (1995-2004)' started by willy_picksup, Jan 4, 2025.
  1. Jan 9, 2025 at 1:00 PM
    willy_picksup
    willy_picksup [OP] Well-Known Member
    Will
    04’ DC taco 4wd
    nan
    Alright, I’ll bite. Which adjustable front shocks do you think would fit me, based on my original post?
  2. Jan 9, 2025 at 2:50 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
  3. Jan 10, 2025 at 5:22 AM
    Toyota Dude
    Toyota Dude Well-Known Member
    2004 Tacoma 4WD 6-CYL DC
    Or if your on a budget can resuse stock coils. Have swapped coils onto struts before. If go high suggest CV boot swap.
  4. Jan 10, 2025 at 8:53 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    :confused::confused::confused: Not a word of that makes sense.
    "If go high"... put the pipe down.
    Moonrman likes this.
  5. Jan 10, 2025 at 5:06 PM
    willy_picksup
    Will
    04’ DC taco 4wd
    nan
    Red_03Taco[QUOTED] likes this.
  6. Jan 10, 2025 at 5:07 PM
    willy_picksup
    Will
    04’ DC taco 4wd
    nan
    These are more my speed. So I can just slide my coils onto those huh. Pretty simple install?
  7. Jan 11, 2025 at 10:54 PM
    Toyota Dude
    Haven't done this on a Tacoma but have on a Tundra. Currently running 3" lift on the Tundra with OE springs and $225 for both front Eibachs on sale from Wheelers with free shipping.
    https://www.tundras.com/threads/2006-4x4-sr5-leveling-kit-questions.143324/#post-3603413
    https://www.tundras.com/threads/springs-for-bilstein-5100.136288/page-2#post-3475250
    Disconnected sway bar to get flex on the LCA. Some may pop the UBJ or bolts on the LBJ if need more room. Used spring compressors to remove the OE springs from the original shock and yes remounted them on the new Eibach adjustable shocks. Eibach tech support is great to talk with IMHO for advice on this. Putting the clip at a high setting with the OE coils can cause a stiffer preloaded ride, but have found them to ride smoother than a similar setup with the billys. Some will put on different taller softer springs (like OME) to get lift with softer ride....but more $.
    Here's a video but didn't watch it closely to determine if agree with every technique they used:
    https://www.youtube.com/watch?v=vENP9lfqzUM
    Usually if lift the front much ("if go high") many will suggest a boot slide mode / rebooting the CVs or they can split open from the friction of the baffles being continually rubbed. There is a sticky on this.
    https://www.tacomaworld.com/threads/boot-slide-mod-no-more-blowing-cv-boots.146070
  8. Jan 11, 2025 at 11:02 PM
    Toyota Dude
  9. Jan 13, 2025 at 3:27 PM
    sierra_surfer_taco
    sierra_surfer_taco Well-Known Member
    San Diego
    2000 Tacoma TRD
    I didn't use spacers. The Bilstein shocks I mentioned are provided the 2" lift.
