1st Gen Lift question on fitting tires
Discussion in 'Suspension' started by MadMtnMikey, Jul 12, 2012.
  1. Jul 12, 2012 at 4:19 AM
    MadMtnMikey
    MadMtnMikey [OP] Well-Known Member
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    A guy at work is selling me some Dick Cepek Mud Country tires. $50 a piece, so I can't pass it up and two of them have 65% tread left.
    Anyhow, they're 285/75-16... Which puts them right at 33", maybe just a hair over if anything... Will these fit with the standard 5100 shock and 880 spring lift in front, and maybe a 1inch body lift ? In the back I'll just do shackles and AAL temporary until I can get new leaf packs.
  2. Jul 12, 2012 at 6:00 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    What wheels are you going to run?
  3. Jul 12, 2012 at 10:36 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Not sure yet... I'll probably go with an 8 inch wide, don't really want to spend more than about $125 per wheel. I'll have to see what my options are.
  4. Jul 12, 2012 at 10:44 AM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    With 285s i think there will be slight rubbing. Thats with the 5100s with ome coils (about 3 inches of lift)
  5. Jul 13, 2012 at 6:03 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Think I'd be alright if I threw a 1" body lift on it ???
  6. Jul 13, 2012 at 6:05 AM
    sirsaechao
    Tim
    Commifornia
    If you dont wheel a full 3" with correct wheels and backspacing you won't rub much and if you do just trim some. If you do 3" suspension and 1" BL then chances are you won't rub and no trimming needed. It all factors in as to what brand tires and wheels you buy. All the tire MFG specs come out a little larger or smaller even tho it maybe be 285's.
  7. Jul 16, 2012 at 5:54 AM
    MadMtnMikey
    Richmond/VaBeach
    03 DC 4x4 SR5 TRD
    Good deal... Thanks for the advice man
