1st Gen Noise/Vibration
Discussion in '5 Lug' started by austin1346, Oct 31, 2023.
  1. Oct 31, 2023 at 10:48 AM
    austin1346
    austin1346 [OP] Active Member
    1999 Tacoma Reg. Cab Short Bed 2WD 5spd
    I'm a new 1st gen 5 lug owner and I've never had a vehicle this old before (1999). Is it normal to have quite a bit of noise/vibration while the engine is running?
    I know it has a mechanical fan so that's likely where the noise is coming from, but the cab is a little loud and the truck has a good amount of vibration at idle. It's not rocking the truck back and forth or anything like it has bad motor mounts, it's just the engine vibration is traveling through the frame and into the seat/floorboard. It does quiet/calm down after it's warmed up but not a whole lot.
    I'm almost certain that this is normal but I just wanted to be sure it's not an issue. Thanks.
