1st Gen or 2nd Gen best for wheeling
Discussion in '1st Gen. Tacomas (1995-2004)' started by Nowhereman04, Apr 16, 2010.
  1. Apr 23, 2010 at 9:45 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There is nothing better than locking the rear and cruising up a particularly tough section.
    They all stand around and mutter, "Wow, how'd he do that!"
  2. Apr 23, 2010 at 10:14 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
    1st gen!!!!
  3. Apr 24, 2010 at 4:56 AM
    h_curtis
    h_curtis Well-Known Member
    That is more driver error than a Jeep issue.
    The main reason I said what I said is because size and weight distribution. To answer the question the 1st generation should be much better than a second. Huge trucks aren't really all that great when it comes to real 4 wheelin. If you are just blasting through mud puddles then any truck is fine, but if you are in tight places, need to get turned around on some cliffside, having a small 4wd is better. The 1st gen is a good choice. Another reason I mentioned about a small jeep is when I had one and was on a very steep hill in the snow, myself and a CJ were the only vehicles that could handle it. A 4wd pickup couldn't stop due to its weight and ended up in a ditch. I think a 1 gen would have been fine.
  4. Apr 24, 2010 at 6:09 AM
    mpgnc64
    mpgnc64 Well-Known Member
    Mike and Denise
    Western NC
    06 4x4 Access cab 4cyl 5spd, 2000 Prerunner
    Tool box, Thule rack, rod holders, 5100s at 1.75 and the TSB
    If its any comparison my 95 4runner out wheels my 06 Tacoma. Maybe I'm just not afraid to do things in the 4runner and its an auto but it does climb and handle side slope great.
  5. Apr 24, 2010 at 10:46 PM
    adiablo420
    adiablo420 Active Member
    HI DESERT CALIFORNIA
    96 TACOMA 4X4 4 CYL
    SUSPENSION LIFT, RIMS AND BFG MUD TERRAINS
    hate to bust your bubbles... 1st Gen.. definitely...
  6. Apr 25, 2010 at 4:20 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Dude, you had a CJ5. That's the shortest damn jeep out there with an 83" wheelbase. Why do you think they made the CJ7 with a 93" wheelbase? The CJ5 isn't sturdy no matter what you do with it.
  7. Jul 6, 2013 at 1:57 PM
    monkeyface
    monkeyface Douchebag, or just douche if we're friends
    Colorado
    '90,'97,'12,'05 Tundra 4.7,'07 T4R 4.7,'08 T4R 4.7
    Comparing stock trucks, 1st Gen obviously has an advantage simply because it's more narrow. And 1st Gen stock came with these things called real skid plates.
    However, the 2nd Gen (2009+ years) added stock traction aids like A-TRAC and auto-LSD to control wheel slippage in 4HI and 4LO on all four wheels. So a stock 2nd Gen acts like it has lockers front and rear. Technically this would make the stock 2nd Gen 'better' in offroad situations.
    My '97 4WD was wearing out, it had to be replaced. I wish the 2nd Gen was narrower but . . . .
    Also, the new Jeep Wrangler is only 1" narrower than the 2nd Gen (73.7" vs. 74.6" for the 2nd Gen), so it's not getting through places a Gen I can.
  8. Jul 6, 2013 at 7:46 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I miss my 2nd gen greatly and prefer it. But my first gen will go places the 2nd cant sadly =(
  9. Jul 6, 2013 at 7:53 PM
    Rucas
    Rucas 1st gen
    Lucas
    1st gen. 4x4
    Custom Aluminum Camper
    PRECISELY why I chucked my second gen to the curb!
