1st gen parts
Discussion in '1st Gen Tacoma Parts Marketplace (1995-2004)' started by Sperrunner, Oct 21, 2019.
  1. Nov 2, 2019 at 11:39 PM
    #101
    TwerkWrench
    TwerkWrench Member
    Joe
    2004 DCSB Prerunner
    2019 S-Works Stumpjumper Evo in the bed
    Do you happen to have a transfer case, front driveshaft, 4wd rear drive shaft, and misc interior trim pieces around the shifter.
  2. Nov 2, 2019 at 11:43 PM
    #102
    Sperrunner
    Sperrunner [OP] UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Rear shaft no. I might have slme trim. Have a front shaft and 2 cases off 4cyl
  3. Nov 3, 2019 at 11:26 AM
    #103
    Trokuis96
    Trokuis96 Well-Known Member
    Luis
    Toyota Tacoma
    N/A
    what city you from?
  4. Nov 3, 2019 at 11:26 AM
    #104
    Trokuis96
    Luis
    Toyota Tacoma
    N/A
    and do you have the gas cap lock
  5. Nov 3, 2019 at 11:44 AM
    #105
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    1995-2000 has the locking gas door cover. He’s from Berkeley, CA.
  6. Nov 3, 2019 at 11:44 AM
    #106
    BartMaster1234
    Tyler
    Flux Capacitor
    You trying to do the 4WD swap? Hope you know about the ETCS-I transmission issue on 2003/2004 v6’s. You can’t use any other transmission.
  7. Nov 3, 2019 at 1:36 PM
    #107
    Trokuis96
    Luis
    Toyota Tacoma
    N/A
    how do I get it I'm from California in the 805 area
  8. Nov 3, 2019 at 1:51 PM
    #108
    BartMaster1234
    Tyler
    Flux Capacitor
    I don’t think he has any, but he can correct me. I’m just a friend of his.
  9. Nov 4, 2019 at 7:39 AM
    #109
    GreatChopps
    GreatChopps Member
    01 Taco
    rear camera, DVD In-dash TV
    Do you have the Front right (passenger side) spindle/Knuckle?
  10. Nov 4, 2019 at 8:42 AM
    #110
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I think so. Its add
  11. Nov 4, 2019 at 3:42 PM
    #111
    CedarPark
    CedarPark Master of Destroying CVs
    Dylan
    Cedar Park, TX
    '04 TRD V6 Taco, '11 2WD 5.7 Tundy
    Lights & Lockers & Duals
    I have the stock front and rear drive shaft out of my 2004 auto 4wd access cab, if ya need em feel free to shoot me a PM
    Sperrunner[OP] likes this.
  12. Nov 5, 2019 at 7:59 PM
    #112
    cast718
    cast718 Well-Known Member
    New Jersey
    2004 4WD Standard Cab 4 Banger
    got a power steering pressure hose? Return hose? Intermediate shaft no. 2 that attaches to the steering rack?
  13. Nov 6, 2019 at 8:07 AM
    #113
    zp3design
    zp3design New Member
    Do you have the transfer case extension housing for the auto?
    Thanks
  14. Nov 7, 2019 at 7:17 AM
    #114
    TenMill
    TenMill Member
    J
    Happen to have a rear 02 sensor, b1 s2 behind the cat for a 2003 3.4?
    Running Board Man likes this.
  15. Nov 7, 2019 at 6:43 PM
    #115
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    Any V6 airboxes? Need one that hasn't been invaded by a deckplate...
  16. Nov 8, 2019 at 9:06 AM
    #116
    RattleTractor
    Harry
    VT
    I don't have the cover for this one. Previous owner did the mod and I never found the plate in the bin of spare parts that came with the truck. Also going to put a snorkel on the truck, so it seems to make more sense to use an airbox that hasn't been deckplated.
    I need to pull out the existing airbox to either replace the deckplate with a new one that has a cover, or to replace the airbox entirely. May as well find a stock airbox at that point and save myself a little time.
  17. Nov 9, 2019 at 4:00 AM
    #117
    TenMill
    TenMill Member
    J
    Well thats what im trying to do with a used one, i bought the truck catless and without that sensor, and now the 02 bung is gone and replaced with a straight pipe as well,so even more work....ive got loose wires comin down for that sensor, so im tryin to find a cheap one, thanks for the heads up on the superceded parts though and the 02 sim trick advice.
    Do you happen to know if I could pull off an 02 sim without that sensor? Everything i read says one has to plugged in. Im sayin is it possible to run a 12v or a 5v reference to the other wires too, to simulate a sensor actually being there, and also to simulate that its good...thats a lot of simulatin' haha
  18. Nov 9, 2019 at 8:06 AM
    #118
    SpinyNorman
    SpinyNorman New Member
    Northern Virginia
    Black 2003 Tacoma DBL Cab off road
    I'm new here (first post), and trying to locate the alarm part for a 2003 Tacoma DBL TRD -- the so-called "free alarm" part # 08586-04820. I have keyless entry already, just not the alarm part. Do you happen to have it? Thanks!
  19. Nov 9, 2019 at 12:26 PM
    #119
    Sperrunner
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    No horns just this
  20. Nov 9, 2019 at 12:29 PM
    #120
    BartMaster1234
    Tyler
    Flux Capacitor
    This one?
