1st gen pizza cutter stance 255/85r16
Discussion in '1st Gen. Tacomas (1995-2004)' started by boshak, Mar 23, 2018.
  1. Mar 23, 2018 at 11:50 AM
    boshak
    boshak [OP] Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    First off - yes I've searched but no luck to find an answer to both questions together.
    My questions are specific to 1st gen and for those that run 255/85r16 (aftermarket wheels preferred but stock wheels welcome)
    What width wheel do you run - 7 or 8" for 255/85/r16? Any issues breaking beads when aired down?
    What backspacing or offset do you run?
    Pictures please!!! I'd like to see how far they stick out from the fender.
    surfishjoe and ChadsPride like this.
  2. Mar 23, 2018 at 12:20 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    boshak[OP], rngr and ChadsPride like this.
  3. Mar 23, 2018 at 12:23 PM
    boostedka
    James
    NM
    also check out @nzbrock 's build thread too
    boshak[OP] likes this.
  4. Mar 23, 2018 at 12:23 PM
    ChadsPride
    Sponsored by TacomaWorld.com
  5. Mar 23, 2018 at 12:28 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    4.0" BS on an 8" wheel. Run 15psi when I wheel. Never lost a bead. Not sure if I have a pic that gives a great tire poke reference, but here's a few.
    surfishjoe, Xbeaus, Jay-coma and 7 others like this.
  6. Mar 23, 2018 at 12:57 PM
    boostedka
    James
    NM
  7. Mar 23, 2018 at 4:17 PM
    Misplaced Nebraskan
    Misplaced Nebraskan TTC #007 'First Gen Best Gen'
    Zach
    Austin
    2001 Taco & 16 T4R TPE
    255 85 16
    Stock 07 T4R wheels (7" or 7.5" iirc)
    1.25" spidertrax spacers. Fronts were tucked real bad without.
    MacGyvR, boshak[OP] and ChadsPride like this.
  8. Mar 23, 2018 at 4:20 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    Love the pizza cutters. I had 255s on my 08 taco and they were my favorite tire size.
  9. Mar 23, 2018 at 4:25 PM
    otis24
    otis24 Hard Shell Taco
    Mark
    California
    OtisBound Outdoors Bodonkadonk
    OtisBound Bodonkadonk
    I ran 255 85 16 maxxis bighorns in stock TRD wheels. I ran em down to 12psi with no issues.
    I’m going back to the pizza cutters and an 8” wheel pretty soon.
    DJB1, boshak[OP] and pudge151 like this.
  10. Mar 23, 2018 at 4:39 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  11. Mar 23, 2018 at 7:29 PM
    boshak
    AG
    CA
    Wow. Everyone.. thank you for the quick but thorough replies on this! Sounds like I can go 8" and air down without issues. Based on pictures I like the 4 and 3.5 backspace.
    Are there still wheel manufacturers making 16x7 or 16x8 with 4 backspace? I prefer not to add spacers.
    @otis24 what backspace do you plan to go?
    @turbodb I've been eyeing the scs F5 3.5 backspace. Has the mud fling been an issue? Did you cure your fender rub?
  12. Mar 23, 2018 at 7:41 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    It's definitely muddier than 31" on OEM wheels, but it's not too bad - nothing really gets in the bed, so that's good. I spent a bit more time with a hammer in the pinch weld area, and yes, the rubbing is cured in all but extreme turn+stuff situations (and even then, it's not bad), where it rubs about 2" inboard of the fender flare on the side you're turning towards.
    boshak[QUOTED][OP] likes this.
  13. Mar 23, 2018 at 9:47 PM
    otis24
    Mark
    California
    I got some generic stealies off eBay for like $68 each. They’re 16 x 8 with -12 offset and some minda back space? Maybe 3.75...I forgot.
  14. Mar 24, 2018 at 4:04 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    How much trimming did you have to do??
  15. Mar 25, 2018 at 9:28 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    Wait I watched u (well Gideon technically) blow a bead at AOP??
    I ran my 255/85s on the stock aluminum 16s and had awesome luck with them. I have ran them down to 5 or 6 psi and only blew one bead. I slid down a hill straight into an emababkment, any tire not on a beadlocks would have came off though.
    Loved that wheel and tire combo, worked great and was awesome as a daily driver.
    There are pics of my setup in the first few pages of my build thread.
  16. Mar 25, 2018 at 10:30 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Haha yea.
    For those not in the know, he’s talking about a slashed sidewall.
  17. Mar 25, 2018 at 10:40 AM
    slander
    Hickory, NC
    Ahh yea, never mind, play on!! I.r.dumb
    rngr[QUOTED] likes this.
  18. Aug 14, 2018 at 2:18 PM
    smmarine
    smmarine Well-Known Member
    Melbourne FL
    2020 Kawasaki Vulcan S ABS
    Thanks. You’ve helped me out a bit. I’ve got some Dick Cepek Extreme Country’s in the same size and same wheels I’m going to have installed on Saturday. Was curious what kind of rub issues I may have.
    Also curious what you did to get your CV angle so flat. Just recently did an OME lift, and there’s a pretty good angle up front.
  19. Aug 14, 2018 at 8:52 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Every tire is different, so you may have different rub issues than I did, but I think it's safe to say that you'll have some rubbing with only 3.5" of backspacing and that size tire. I'd be curious to know how the Dick Cepek Extreme Country’s work out for you - both rubbing and performance - they may be my next tire.
    For my CV's - the real answer is that I don't have a ton of lift on the truck. A couple inches max; there's no real need for more 99% of the time (but you do need to pick good lines) since the suspension cycle doesn't change with lift, and it makes the truck last a lot longer if you don't take it up too high.
    Arctic Taco likes this.
  20. Aug 15, 2018 at 1:27 AM
    TambaDoode
    TambaDoode Well-Known Member
    JT
    2000 Tacoma Sr5
    Camper life.
    Pizza cutters dont look so bad! Im thinking about making this change for some better mpg and cheaper tires
