1st Gen Pre Runner sway bar question?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbimm, Oct 27, 2017.
  1. Oct 27, 2017 at 5:40 AM
    Tbimm
    Tbimm [OP] Well-Known Member
    Tom
    Belle Chasse La.
    2000 Tacoma Prerunner
    Bilstein 5100's front and back. OME 880 front coils. General HD rear springs. Fuel 16x8 Enduro rims. Dick Cepek Extreme Country 285/75/16's Some kind of headers. K&N cold air intake.
    So I need to replace my sway bar bushings and links. No big deal except that a previous owner installed an after market sway bar on the truck. The upgraded bar is an 1 1/8 inch bar. The bushings that are on it are rather thin. ( 1 3/4 inches from frame to top of the bracket hoop. ) This doesn't leave much room for bushing material. Wondering what some of you guys with 1 1/8 sway bars are using for bushings? This bar is still using stock links if that plays any roll here.
  2. Oct 27, 2017 at 8:24 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    What brand sway bar? I would contact the manufacturer who made the swaybar for a replacement.
    If that falls through, I have a stock swaybar and links just laying around you can have for free, might be a bit of a drive to pick it up, tho... ;)
  3. Oct 27, 2017 at 9:04 AM
    Tbimm
    Tom
    Belle Chasse La.
    Yeah if I knew what brand it was this wouldn't be any problem. I would just order the bushings that went with this kit. I am thinking any 1 1/8th bushing would work as long as I can get the brackets for that bushing. The existing brackets just leave so little room for bushing material.
    As far as the drive? Well I am not planning to head out west till next summer after the 4X4 swap is complete. I need the clunking noise from the sway bar to disappear much sooner than that.
  4. Oct 27, 2017 at 9:26 AM
    Glamisman
    Glamisman Well-Known Member
    there arnt that many aftermarket manufacturers of sway bars, Hellwig comes to mind immediatly. I looked through their online catalogue and I see where they do have offerings for Tacomas and I do see where they list the diameter of the sway bar... maybe you can get lucky there.
  5. Oct 27, 2017 at 6:19 PM
    kgt0001
    kgt0001 Well-Known Member
    Kyle
    San Antonio, TX
    2003 Toyota Tacoma PreRunner, 1997 Tacoma 4wd
    Addco is that diameter
