1st gen prerunner stock ride height.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dirty White, Nov 5, 2017.
  1. Nov 5, 2017 at 6:39 PM
    Dirty White
    Dirty White [OP] Well-Known Member
    02 DC Prerunner and 03 ext can prerunner
    2002: 2.5" ome lift springs, 2.5" lift bilstein 5100 front shocks on oe coils and 5100 rear shocks. Topper. 285 75 16 toyo at2s. K&N intake. 2003: super spring progressive aal. Slide master 1000lb bed slide. Custom utility bed with lumber rack. Diamond aluminum 6ft boxes.
    I have a 2002 tacoma prerunner quad cab. When I bought it, it had sagging oe leafs with a 1" block and stock struts with a 1.5" block. I just replaced the oe spring pack with ome dakar springs, took the 1" block out and put bilstein 5100son. In the front I took the 1.5" top spacer out and put bilstein 1.25-2.5" adjustable 5100s (set at 2.5") in the oe coil. My measured ridea height in the back went up a full 2.5" . The front reduced about 1". I am not sure what lift from stock I am getting in the front because there was already a block. Any one know the stock front ride height so I can tell if my front 5100s are giving me the 2.5" they advertise? Also anyone had a set of these dakar springs for a while that can tell me how much they settle out. Trucks a little stink bugged right now. Thanks for the help.
