1st gen problems
Discussion in '1st Gen. Tacomas (1995-2004)' started by 01 Runner, Mar 18, 2017.
  1. Mar 18, 2017 at 3:16 PM
    01 Runner
    01 Runner [OP] Well-Known Member
    San Marcos,Texas
    (Old Man Tan) 2001 Pre-Runner
    2001 Tacoma Build (Started 03/17) Mods done- Wheels- -method nv's 16x8 4.5bs 0 o/s -Bfg a/t 285/75r16 Suspension- -king coilovers 2.5 (non resi) -total chaos uca -bilstein 5100 rear shocks -ome dakkar leaf springs Tech/Lights/Cool Mods- -HELLA lights mounted on bumper -Righid D2s mounted inside bumper -CB radio with rear tailgate mount -deck plate mod (actually worth it) Armor- -Relentless Fab “Predator” bumper Winch- WARN m8000 (steel cable) ————————————————————————— Mods to come- -rear bumper (relentless fab) -arb air rear locker -4x4 conversion (way down the road) -new exterior window trim -fender flare delete & 35’s -new tint -new headlights -full size spare tire -tire carrier/hi-lift/jerry-can mount
    Why is my Tacoma shaking? My Tacoma shakes while in park and around 75mph on the freeway. I just replaced the spark plugs and carrier bearing. Please give me any and all suggestions. Maybe I'm overlooking something obvious! I went to the dealership the other day and the tech said he wasn't sure why it was doing it. Thankyou! -Ryan
  2. Mar 18, 2017 at 3:31 PM
    Clearwater Bill
    Billy
    Largo Florida
    Could be two different shakes. Idle engine related, (or engine/transmission mounts), at speed wheel/tire related.
    If you have no CEL codes, it *almost* has to be mechanical (not ECU controlled) related.
    01 Runner[OP] likes this.
  3. Mar 18, 2017 at 3:49 PM
    SellyKlater
    SellyKlater Well-Known Member
    Ponce Inlet, Fl
    2004 Tacoma 3.4L Double Cab TRD
    3" ome lift 883. Fnfx pros.
    Old Spark plug wires? Tire rotation?
  4. Mar 18, 2017 at 4:52 PM
    Fuergrissa
    Fuergrissa If you build it, trails will come.
    Devin
    San Jose
    2000 T4R Limited
    My vote is for the mounts.
  5. Mar 18, 2017 at 5:42 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    I second that! My mounts are bad as well, just have to find the time to change them out.
  6. Mar 18, 2017 at 6:56 PM
    01 Runner
    San Marcos,Texas
    -So the mounts that secure the transmission wear out and can cause vibration over time? Is there anyway to test this so I can see if that's the cause? My truck is 15 years old so this wouldn't surprise me.
    -I thought tires for awhile cause I'm due for new ones but it does it even when parked so that can't be the cause...i will be getting new tires next month tho.
    -I thought my drive shaft coukd be causing the issue cause it feels like it's right under your feet/seat but it still does it in park. I had misfires with the spark plugs and you could feel that it was coming from the front/the steering wheel would shake. This doesn't feel like it's from the front of the truck.
    -it was throwing a catalytic converter code but that was it...:annoyed:
  7. Mar 18, 2017 at 7:25 PM
    Clearwater Bill
    Billy
    Largo Florida
    you might reread, slowly, post #2
    Which cat code?
  8. Mar 18, 2017 at 8:54 PM
    01 Runner
    San Marcos,Texas
    P0420
  9. Mar 18, 2017 at 10:12 PM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    You could start by replacing the O2 sensors
  10. Mar 18, 2017 at 11:35 PM
    butsack
    butsack Well-Known Member
    SW WA
    1997 Reg cab 3rz auto
    aftermarket cassette player
    better yet, use an obd scan tool to see if they are working correctly.:thumbsup:
  11. Mar 19, 2017 at 9:33 AM
    Clearwater Bill
    Billy
    Largo Florida
    If that was set to to an O2 sensor (most common cause), that will not cause any shaking. However, it is important to correct by replacing the offending sensor.
    If the cat itself has failed, of course it needs to be replaced too. But it generally I've only seen a failed/clogged cat either obstruct higher RPM running or even prevent vehicle starting, like putting a potato in the tailpipe.
    I still wager you have two different issues.
    01 Runner[QUOTED][OP] likes this.
  12. Mar 19, 2017 at 9:54 AM
    01 Runner
    San Marcos,Texas
    And it's very intermittent. One day it'll feel 100% and have so much more power then some days it feels like a snail running down the road.
  13. Mar 19, 2017 at 10:43 AM
    Fuergrissa
    Devin
    San Jose
    2000 T4R Limited
    Ok so we got the p0420 issue but the shaking....
    @01 Runner when did you get your kings and ucas? Did you get an alignment? And did the shaking occur before the lift?
  14. Mar 19, 2017 at 4:08 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    look at your rpm when it's shaking, mark it down, low idle can cause a "vibration"
  15. Mar 19, 2017 at 4:29 PM
    01 Runner
    San Marcos,Texas
    I had shaking before the lift. I just put it on last week but haven't noticed any increase since. And yeh I had the alignment done that day. It's just weird how intermintment it is....:l
  16. Mar 19, 2017 at 4:31 PM
    01 Runner
    San Marcos,Texas
    When I did the carrier bearing is it possible that I messed with the alignment of the driveshaft? Should I look at getting that balanced? The shakes really aren't bad when in park just at 75mph ishhhhh
  17. Mar 19, 2017 at 4:33 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    Driveshaft doesn't move in park, so I doubt that's the idling issue.
  18. Mar 19, 2017 at 5:41 PM
    Clearwater Bill
    Billy
    Largo Florida
    I keep trying to tell you its two different issues, based on your description of conditions they occur under
    Its fine not to believe a stranger on the interwebz, and i dont care if you prove me wrong. But at least start the elimination process by examining things that folks have suggested, not just doing more keyboard guesswork.
    Best of luck!
  19. Mar 19, 2017 at 5:53 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    I have the same code throwing and mine shakes at idle a lot too.
  20. Mar 19, 2017 at 5:57 PM
    x2468
    Have you had your tires balanced properly? I got my tires aligned and rotated and from 55-75 it was shaking so much I thought I was going to lose a filling. The shop "road force" balanced my wheels and that fixed it.
