1st Gen Pseudo Satoshi Grille Assembly
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Jul 8, 2010.
  1. Jul 8, 2010 at 7:21 PM
    747 [OP] function > form
    1st Gen.
    Total Anticipated Cost: (+/-) $150
    Investment to date:
    Time: 12.5 hours [through 08/17/2010]
    Cash: $106.87
    Purchased to date:
    07/15/2010 (TW Member: trdracing5)
    Hella Supertone Horns: <undisclosed>
    XX/XX/2008: (ebay)
    Perforated Aluminium Sheet: $20.00
    06/29/2010: (partsgeek)
    Grille Assembly: $34.84
    06/30/2010: (menard's)
    Respirator: $4.47 -- HIGHLY RECOMMENDED; the fiberglass resin is no bullsh!t.
    Bondo Fiberglass Repair Kit: $10.88
    Bondo Body Filler Kit: $5.54
    3-pk. Spreader: $1.95
    3-pc. Brush Set: $1.29
    400 Grit Sandpaper: $1.99
    150/100/60 Grit Sandpaper: $1.78
    Dremel Cutting Wheel: $5.77
    Sandable Primer (RO): $3.62
    Self Etching Primer (RO): $4.05
    Semi Gloss Auto Paint (RO): $4.22
    Mineral Spirits: $5.48
    Tack Cloth: $.99
    Materials photo...
    Fins removed photo...
    First layer of fiberglass - lower (photo 1)...
    Fiberglass - lower (photo 2)...
    Fiberglass - lower, sanded (photo 1)...
    Fiberglass - lower, sanded (photo 2)...
    Fiberglass - upper, sanded...[grateful for bondo]
    Bondo'd and sanded...[sorry for the photo quality; very humid here today]
    Anticipated Addt'l. Investment:
    Time: :censored:
    Cash: (+/-) $45.00
    Anticipated Addt'l. Purchases:
    Screws & Nuts: (+/-) $3.00
    Credits:
    Thanks to:
    TW Member, Tallyman89 - "T" Emblem
    TW Member, trdracing5 - Supertones
    TW Member, KPT - http://www.tacomaworld.com/forum/2nd-gen-tacomas/98465-hella-supertones-horns-install-guide.html
    TN Member, lwyattl - http://www.toyotanation.com/forum/showthread.php?p=2414825&posted=1
  2. Jul 8, 2010 at 9:55 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 v6 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Looks like fun :popcorn:
  3. Jul 8, 2010 at 9:58 PM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
  4. Jul 8, 2010 at 10:02 PM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    fine!
    I'll stick to my chinese food
  5. Jul 11, 2010 at 2:26 PM
    1st Gen.
    This thing is a real pain in the a$$...I'm done 'til next weekend.
  6. Jul 11, 2010 at 7:41 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
  7. Jul 12, 2010 at 12:27 PM
    SRQ TACO
    SRQ TACO Well-Known Member
    Damon
    Sarasota, Florida
    2000 Tacoma 5lug Lowered & 2008 Tacoma 4x4 Lifted
  8. Jul 12, 2010 at 12:33 PM
    FightFire48
    FightFire48 Taco Monster
    Will
    Spokane, WA
    04 Taco dbl cab
    3" Toytec lift AEM BruteForce CAI Gibson exhaust 2 - Rockford Fosgate 8's
    Do you have any final pics of the build
  9. Jul 12, 2010 at 12:45 PM
    RPain
    RPain I drink, and I break things
    Chandler, Arizona
    2016 Tacoma DCSB 4x4 TRD Sport
    Link to build in sig
    x6
  10. Jul 12, 2010 at 12:46 PM
    derekabraham
    derekabraham Living vicariously through everybody
    TW'S Hippy Liberal
    Portland, OR
    2002 4x4 4Runner
    Stick on hood scoop from Autozone.
  11. Jul 12, 2010 at 6:17 PM
    1st Gen.
    Not yet...I'll get back to it this weekend...the top of the thing (see last photo) really pissed me off, so I wanted to take a break and not screw it up.
  12. Jul 30, 2010 at 8:34 AM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    ill have an order of what this guy is eatin. dam that looks good
  13. Aug 17, 2010 at 5:09 PM
    1st Gen.
    it's so close to being done. it should be complete by the end of this weekend.
  14. Aug 17, 2010 at 8:55 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I sure hope so.... Been waiting a long time too see this thing.... :D
  15. Aug 18, 2010 at 6:01 PM
    1st Gen.
    you and me both...1 more 600 grit sanding, 1 more coat of paint, trim the perforated aluminium, clear coat over grille assembly and aluminium, attach aluminium to grille assembly, and install (if everything goes according to plan).;)
    100th post [sort of]....
  16. Aug 18, 2010 at 6:06 PM
    Taco76087
    Taco76087 Well-Known Member
    Robert
    Weatherford,Texas
    04 Tacoma prerunner TRD SR5
    Rockford Fosgate p2 10'', Q-Logic Enclosure, JVC KD-PDR30 Ipod Connection, Rockford p200.2 Amp, Clear Corners, KING Coilovers, Rancho Rear shocks FJ TRD Trail Teams Wheels with 285/75/16 Duratracs
    How do you attach the aluminum to the grille?
  17. Aug 18, 2010 at 6:10 PM
    wtbthree
    wtbthree Give 'er
    Will
    Colorado Springs, CO
    SC'ed 2010 DC
    3" Revtek lift, 17" FJ rims, 285 BFG KO's, sunroof, TRD piping, Wickedflow muffler, Avid step rails TRD supercharger,
    ^^^ Hope you dont mind, I don;t mean to thread jack, but I have a quick question on sanding... I was at the hardware store today and picked up materials for a satoshi project (just waiting for the grill to come in). As far as sandpaper goes, I have 320, 400, 600, and 1500. Are those levels acceptable for the prepwork I'll need to do before painting ( I have a grill surround to do as well as the bondo'ed portion of the satoshi)? Or do I need some 800, 1000, and 2000 to do the job right?
    Thanks
  18. Aug 18, 2010 at 6:24 PM
    747
    1st Gen.
    I "plan" to bond (epoxy) nuts around the inner lip of the grille assembly (engine compartment diagram [:eek:] below), then attach the aluminium to the grille assembly with screws (again, from the engine compartment side of the grille assembly)...
  19. Aug 18, 2010 at 6:32 PM
    747
    1st Gen.
    first, I'm using this to edit my previous post of 08/18/10, as follows: 1 more 1200 (or 1300...I forget) grit sanding to go on the grille assembly.
    reply to wtbthree's question: I went from 100 grit, to 150 grit, to finer and finer (don't remember...I'll edit this later), down to 1200. imo, you'll be good w/320, 400, 600, and 1500...but you may want to start w/100 or 150 depending on how generous you are with the bondo. this was my first time using the stuff, and i recommend using it sparingly as it's just going to take more time to sand it down if you use too much initially (i.e., if you lay it on too thick initially, you'll be sanding it off/down for awhile)...the 100/150 cuts into the bondo much quicker than the less coarse grits.
  20. Aug 18, 2010 at 6:37 PM
    toytacoma22
    toytacoma22 Well-Known Member
    COS
    3" Icon Lift, TC UCA, OME Dakars, Allpro front and rear bumpers.
