1st gen rear axel swap to 2nd possible?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by tw200, Oct 28, 2016.
  1. Oct 28, 2016 at 8:32 AM
    tw200
    tw200 [OP] Member
    Calgary AB
    2008 SR5
    Hello Tacomaworld. I was wondering if anyone has had experiences swapping a 1st gen rear axel to a 2nd gen truck. Are there any modifications required for fitting? I am interested in this because there is an axel with 4.10 gears and lockers that I want to put on my 2008. Thank you.cor your replies.
  2. Oct 28, 2016 at 8:44 AM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    Are you 4wd, if yes what are you gonna do about your front diff?
  3. Oct 28, 2016 at 12:51 PM
    tw200
    tw200 [OP] Member
    Calgary AB
    2008 SR5
    The 1st gen truck is only 2wd so I'm still trying to source front gears. Not too interested in ordering online yet.
  4. Oct 28, 2016 at 4:37 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Just saying :)
    MrCrowntown and DaveB.inVa like this.
  5. Oct 28, 2016 at 4:41 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    I would think that if it's an elocker the wiring on the 08 would have to be changed out or modified.
  6. Oct 28, 2016 at 5:59 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    You sure they are around the same width? I would think the 1st gen would be a bit skinnier since the 2nd gen is a wider truck.
  7. Oct 28, 2016 at 8:24 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    i just put a 1st gen third member in my truck, It bolted right in to my second gen rear end, but that is because they were both elocker rear ends... If I recall there was some differences between the two housings but it is raining and I dont want to go out and look, If you are still wondering tomorrow, send me a pm and I can measure the two and see if all of the mounting locations are the same.
