1st Gen Rear Shock Relocation
Discussion in 'Northern California' started by Kwikvette, Jun 17, 2020.
  1. Jun 17, 2020 at 10:05 AM
    Kwikvette
    Kwikvette [OP] Well-Known Member Vendor
    Fresno County
    4 run, 2 don't
    Any leads for someone to do this close to the Monterey County?
    I can go back to So Cal and get it done but that'd be a bit much for such a mod :burp:
  2. Jun 17, 2020 at 10:33 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How do you want it relocated? Just to fit a longer 10” shock? Moved to the outside of the frame?
  3. Jun 17, 2020 at 10:37 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I am aiming for a 10" shock.
    I'm ok with either direction; outboard will require spacers and a kit offered by only 1-2 companies that I don't mind getting.
    Under the bed just requires a cross member welded in, and shock tabs on the axle. This method will be easier I would assume for anyone that welds, plus cheaper.
    I don't weld, and if I did I wouldn't be able to anyway as my home's wiring isn't up to snuff for the current required.
  4. Jun 17, 2020 at 2:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I think I had messaged him, I'll check my other phone. We weren't sure which way to go and he was unfamiliar with a 1st gen?
    I could be confusing him with someone else altogether.
    Figured I'd upgrade something on my truck since 4x4 parts aren't as readily available nearby.
  5. Jun 17, 2020 at 2:31 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I'll call him up tomorrow and get his opinion on what'd be easier to do.
    I just want a bit more travel, and my off road needs exclude rock crawling, etc. which means I don't need a specific application.
    Taco-Obsessed and Silver02Taco like this.
  6. Jun 17, 2020 at 3:10 PM
    Rames
    Rames Well-Known Member
    James
    Oakland, CA
    OME 3" lift, BAMF sliders, Demello front bumper
    I know Milo has done shocks towers in a first gen. When I dropped of my truck, a first gen was getting the bed pulled off to replace the broken rear shock towers.
    edit: he’s also done my shock relocation on my 2nd gen.
  7. Jun 17, 2020 at 3:12 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Go through the bed you Lil bitch
    otis24 and Kwikvette[OP] like this.
  8. Jun 17, 2020 at 3:16 PM
    eon_blue
    Azusa, CA
    Kwikvette[OP] likes this.
  9. Jun 17, 2020 at 4:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Who let you out of your box :burp:
  10. Jun 17, 2020 at 4:08 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Your photoshop skills have improved
    eon_blue[QUOTED] likes this.
  11. Jun 17, 2020 at 4:15 PM
    JKO1998
    Utah
    I would really go to someone that knows how to do it, it’s not really just welding this bar here and a couple mounts.
    well I guess it kind of is
  12. Jun 17, 2020 at 4:25 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I wouldn't mind going through the bed myself, but since I don't weld, I'm looking for the easiest option.
    But with the camper shell idea, going through the bed is less appealing.
    JKO1998[QUOTED] likes this.
  13. Jul 2, 2020 at 3:31 PM
    Taco-Obsessed
  14. Jul 2, 2020 at 6:33 PM
    Slo_mo831
    Slo_mo831 Member
    Moises
    2011 tacoma trd offroad
    If you have Instagram check out @ mobworthy .he is in aromas area
  15. Jul 2, 2020 at 6:43 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    There's been a change of plans lol
    Since posting this, I've committed to getting my co workers 4Runner so I'm not doing a 4x4 swap on my Tacoma anymore; no more mods for the Taco
    I'll check it out
    Good to see you again Mo!
    We should go wheeling together again sometime
    Taco-Obsessed[QUOTED] likes this.
  16. Jul 2, 2020 at 6:45 PM
    Taco-Obsessed
    Rad. I'll take a day off and meet you at hollister mid week (your days off) to christen your new 4x4 with you.
    Kwikvette[QUOTED][OP] likes this.
  17. Jul 2, 2020 at 6:46 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Really can't wait to get my hands on it already; extra parts I didn't install on the Tacoma are going onto the 4R (King 2.5 and Icon UCA)
