1st Gen Rearview Mirror Help
Discussion in '1st Gen. Tacomas (1995-2004)' started by EV831, Apr 1, 2012.
  1. Apr 1, 2012 at 5:57 PM
    EV831
    EV831 [OP] Active Member
    ETHAN
    Bay Area
    00 PreRunner TRD
    I unscrewed the screw on the backside of my rearview mirror trying to take it off but it is still connected to the top somehow. Now with the screw loose it just hangs there and won't hold a position. Can someone help me figure out how to screw it back in?????
  2. Apr 2, 2012 at 9:02 AM
    natemoore2088
    natemoore2088 Well-Known Member
    Nate
    Idaho
    '97 Tacoma 2.7
    2" lift Pre-runner bumper Deck Plate Doug Thorley header Cherry Bomb
    Take off the cover for your dome light and there should be one or two more screws holding it on. Did you unscrew the mirror from the stem or the stem from the roof? Does your mirror have any electronics like temp/compass that would have wires holding the mirror on?
  3. Apr 2, 2012 at 9:08 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    if its the same as my 97 you should pop a little cover off and then theres 3 screws under it.
