1st Gen RETROFIT groupbuy #1 FXR HEADLIGHTS
Discussion in 'Group Buys' started by ambiguous, Jan 8, 2015.
Thread Status:
Not open for further replies.
  1. Jan 8, 2015 at 8:59 PM
    ambiguous
    ambiguous [OP] Master Retrofitter @RECHELON/AESTHETICS Vendor
    Burt
    Portland, OR to SoCal
    2012 DCLB TRD
    Members In!
    1. paquu
    2. pdxpuddle
    3. Digiratus
    4. AustinDeh
    1st Gen Retrofit groupbuy
    Stage 1 $600 SHIPPED (Aftermarket Headlights)
    What is included?
    -Brand new aftermarket headlight housings
    -Brand new FXR 3" Projectors
    -Shroud of your choice (http://www.theretrofitsource.com/com...s/shrouds.html)
    -Blacked out housings
    (I can leave parts chrome as well)
    -brand new 35W Morimoto ballasts
    -brand new XB35 Morimoto bulbs (I recommend 4300k or 5000k)
    -brand new Morimoto H4 wiring harness
    Options:
    -Passive demon eye (color of your choice) +$50
    -LED demon eye (color of your choice - red, blue, green, amber purple) +$80
    -Halos (white or amber / front or rear mounted) +$100
    -RGB color changing halos +$140
    -OEM bulbs are available (pricing varies)
    Stage II $840 shipped
    (OEM Headlights)
    What is included?
    -Brand new OEM headlight housings
    -Blacked out housings + smoking of the orange reflector
    Options:
    Here's some of my work!
    LusoSoccr - brand new aftermarket headlights, Apollo 3.0 shroud w/ white halo in rear, flat black paint, smoked reflector
    Jerez - Magnetic Gray OEM paint, Apollo shroud, passive red demon eye
    Flat black paint, Apollo shroud, White Halo (front mounted), passive red demon eye, smoked orange reflector
    Flat black paint, Apollo 3.0 shroud, amber halo (rear mounted), smoked orange reflector
    TACOMAA6 - Brand new OEM headlights, Apollo 3.0 with white front mounted halo, red passive demon eye, smoked reflector, flat black paint
    Toyota Technical - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    Apollo shroud, amber halo (front mounted), smoked orange reflector
    Bullet shroud, smoked orange reflector
    Apollo 3.0 shroud, smoked orange reflector, flat black paint
    Datsik - Apollo shroud, amber halo (front mounted), orange reflector not smoked
    Datsik - Apollo shroud, white halo (front mounted), orange reflector not smoked
    sect0r - brand new OEM headlights, G37R shroud with white halo in rear, flat black paint, smoked reflector
    temper - Brand new OEM headlights, G37R shroud w/ RGB halo, flat black paint, smoked reflector
    Idaholandho - brand new OEM headlights, anodized blue demon eye, bullet shroud, flat black paint, smoked reflector
    w/ flash on
    Dave P - Brand new OEM headlights, Panamera shroud with front and rear mounted amber halo, flat black paint, smoked reflector
    almoss - brand new OEM headlights, DTRL and Apollo 3.0 shroud left chrome, smoked reflector
    iHacker - Brand new OEM TRD Pro headlights (black chrome finish), Apollo shroud, everything left alone for an OEM look
    Flat black bezel, Shroud, Bowl, DTRL, and corner bowls all left chrome, amber halo, Apollo shroud
    RAD - G37 shroud w/ white halo (rear mounted), DTRL/corner areas left chrome, smoked orange reflector
    Panamera shroud, DTRL, main bowl, and shroud left chrome, orange reflector not smoked
    Apollo shroud w/ white halo (rear mounted)
  2. Jan 8, 2015 at 9:03 PM
    PcBuilder14
    PcBuilder14 Well-Known Member
    Brent
    Nor Cal
    2018 Tacoma TRD Off Road 4x4
    How long will this be going?
  3. Jan 8, 2015 at 9:11 PM
    ambiguous
    Burt
    2012 DCLB TRD
    I'll run it until end of the month. Hopefully we can get enough interest :D
  4. Jan 8, 2015 at 9:13 PM
    PcBuilder14
    Brent
    Nor Cal
    Got it. Tempting....
    Have you already gotten a donor to retrofit a pair of 1st gen headlights?
  5. Jan 8, 2015 at 9:16 PM
    ambiguous
    Burt
    2012 DCLB TRD
    I have a local truck willing and waiting to go!
  6. Jan 8, 2015 at 11:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I'm still in
  7. Jan 9, 2015 at 11:16 AM
    Lava rocks
    Lava rocks Well-Known Member
    Hilo,Hi.
    2000 Sr5 xcab 4x4 v6 auto
    Any pic's of 1st gen retro?
  8. Jan 9, 2015 at 11:22 AM
    ambiguous
    Burt
    2012 DCLB TRD
    Sorry no 1st gen retrofit pictures.
  9. Jan 9, 2015 at 12:31 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    There's a few bits of information missing:
    What's the expected delivery?
    When will you start work? (When someone says they want it / when they give you money / when you get X number of people?)
    It would probably help to just do the work on that local truck and post photos - this will help convince more people to commit.
  10. Jan 9, 2015 at 12:35 PM
    ambiguous
    Burt
    2012 DCLB TRD
    Jason,
    I would like to get 10 members committed. After everyone either puts down their deposits, I expect to have everything built and completed in 3 weeks or less. 1 week to get parts, 1 week to paint/aiming, 1 week to close up and seal.
  11. Jan 10, 2015 at 3:52 PM
    brother moses
    brother moses Well-Known Member
    Brandon
    Washington
    02 Double Cab Supercharged
    Light Bars, deck plate mod, Camburg 2.5 coil overs, Dakars, AP sliders, NWTI Bumpers
    I am so tempted. I've found a couple tacos the build forums with these and they look amazing.
  12. Jan 10, 2015 at 5:44 PM
    Digiratus
    Roaming the PNW
    The RedHead
    I know there are at least 7 more 1st gens guys that want to do this.
  13. Jan 11, 2015 at 5:42 PM
    DougDeBonet
    DougDeBonet Well-Known Member
    Doug
    Long Island, NY
    2014 TRD Off Road
    Omg if the prices are similar with '14 head lights I'll bite. Obviously would have to PM you since this is gen1
    Disregard I found the gen2 one I'm not very observant
  14. Jan 13, 2015 at 8:25 AM
    ambiguous
    Burt
    2012 DCLB TRD
    Anyone?
  15. Jan 13, 2015 at 8:39 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Feeling a little desperate bump :eek:
  16. Jan 17, 2015 at 9:40 PM
    paquu
    paquu Well-Known Member
    RI
    02 doublecab fj trm rims, roof led bar
    42" LED bar
    X2 BUMP!!! lets get this going guys
  17. Jan 19, 2015 at 8:39 AM
    AustinDeh
    AustinDeh Well-Known Member
    Austin
    SoCal
    04 SR5 TRD 4x4
    BUMP, Interested as well!
  18. Jan 20, 2015 at 9:36 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Good to hear Man! One more for the list?
  19. Jan 23, 2015 at 8:18 PM
    paquu
    RI
    42" LED bar
  20. Jan 29, 2015 at 9:07 PM
    paquu
    RI
    42" LED bar
Thread Status:
