1st gen roll bar endlink busted...
Discussion in 'Suspension' started by brelandt, Aug 29, 2010.
  1. Aug 29, 2010 at 3:20 PM
    brelandt
    brelandt [OP] Well-Known Member
    Terry
    Dublin, CA
    04 Prerunner reg cab SR5
    3" lift front and back
    I have a 3" spacer lift on my 2004 prerunner. I have had them on for years. However, the last time I changed my oil I noticed that the upper portion of my swaybar endlink has a busted rubber seal and has thrown grease on to the suspension.
    Is there a fix for this that will keep this from happening again. I have seen a spacer kit for the 2nd gen that lowers the bar to relieve the tension on the endlinks, but haven't seen one for the 1st gens.
  2. Aug 29, 2010 at 3:23 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    i may be wrong but i think you are mistaken. The only thing i have seen for the swaybar is it shifts it forward away from an adjustable coilover. A lift will not affect the swaybar.
  3. Aug 29, 2010 at 3:52 PM
    brelandt
    Terry
    Dublin, CA
    you're right I was thinking that the kit was for lowering the bar. my sway bar is pulling my endlinks up and towards the rear which is placing a straain on the endlinks. I am thinking about adding a spacer inbetween the frame and the sway bar to see if this will relieve this strain.
  4. Aug 29, 2010 at 4:02 PM
    Yoytoda
    Roland
    completely stock
    it shouldnt. there should be no strain on the sway bar on level ground. the swaybar only has tension when one wheel is higher than the other.
