1st Gen. RPM Flucuation when Idle. Not A/C related and not stalling. Help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Milkman14, Jul 17, 2022.
  1. Jul 17, 2022 at 3:15 PM
    Milkman14
    Milkman14 [OP] Well-Known Member
    2004 Toyota Tacoma 3.4L 4x4 M/T
    Hello,
    I have a 2004 Tacoma 3.4L M/T. I looked at other threads for this similar problem but every thread I saw seems to be slightly different. Sometimes when driving (not all of the time and usually not when I first start up the truck), the RPM's begin fluctuating between 1000-500 ONLY when idling. There is never any flucating when giving the car gas, the car never has stalls (although a couple times it felt like it may). This will happen when the A/C is on or off.
    I pulled the MAF Sensor and cleaned it, and it didn't seem to make a difference. If anyone has any ideas or a link to another thread I may have missed I would appreciate it.
  2. Jul 17, 2022 at 6:45 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Do you have the electronic or mechanical throttle body?
  3. Jul 17, 2022 at 7:42 PM
    02hilux
    Planet: EARTH
    04 will be electronic
  4. Jul 18, 2022 at 9:36 AM
    Milkman14
    Could it be something to do with the Idle Control Valve? I'm not sure how to check that for issue.
  5. Jul 18, 2022 at 10:11 AM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    If you have the electronic throttle body I don't believe it has an idle air control valve.
    Do you have an engine light on?
    Any codes?
  6. Jul 18, 2022 at 10:45 AM
    Milkman14
    I keep getting a small EVAP system leak (p0442 I think) but I think that's just a problem with the gas cap..I currently have a check engine light so I will read the code and see if it's the same or something different when I get home.
  7. Jul 18, 2022 at 11:08 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    Wouldn't hurt to check all of your vacuum lines.
  8. Jul 18, 2022 at 12:33 PM
    Milkman14
    Allright will do..I'll run the code and check the lines...is a visual inspection usually efficient or is it best to check by spraying starter ether?
  9. Jul 18, 2022 at 1:21 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    welcome to my world the past 7 years. I've had it stall a few times when just touching the gas and letting it off. had a multi-crank issue a few times (like 8-10 cranks)
    never any codes for the idle (codes for other things sometimes). I've just dealt with it and figure if it still runs and doesn't cost me anything I don't want to throw money at random parts
  10. Jul 18, 2022 at 2:46 PM
    Milkman14
    Just ran the codes, it was P0442. Checked all vacuum hoses and didn't see anything loose. When I get a chance I will check with starting fluid.
    Thats too bad to hear that you haven't been able to find the solution to the problem. Right now for me it is just a bother. I am worried if it gets worse hill starting will be hard at low rpms. If it gets to the point of it stalling when idling I will throw parts at it.
    If an MAF sensor failed it would give a code? Appreciate the help and any ideas.
  11. Aug 2, 2022 at 1:49 PM
    Milkman14
    Update for anyone who is interested:
    I took it to a shop bc it made my truck stall. They said it was simply carbon built up in the fuel injectors and throttle body. They also changed out my spark plugs. I have not had the issue since. Before bringing it to the shop I had ran some Lucas in my gas but I may have been too far gone. Hopefully this helps someone.
    Madjik_Man and Kevins60 like this.
  12. Aug 2, 2022 at 3:04 PM
    Madjik_Man
    Colorado Front Range
    Thank you for checking back in with the update.
    Always helps with future researchers.
