1st Gen Satoshi HELP NEEDED
Discussion in '1st Gen. Tacomas (1995-2004)' started by 747, Jul 7, 2010.
  1. Jul 7, 2010 at 6:03 PM
    747 [OP] function > form
    1st Gen.
    The two tabs at the top of the grille assembly prevent me from doing a true deep dish style grille. However, I'm concerned about removing them because it may affect/effect the stability of the grille assembly once installed; then again, the remaining outer tabs (see "Not to be removed" in photos) may provide enough stability...I dunno.
    If anyone else has done this, please advise me of how you resolved this problem...thanks in advance!
    As seen from the front...
    Driver rear side...
    Passenger rear side...
  2. Jul 7, 2010 at 7:24 PM
    1st Gen.
    premature bump (yeah...it's been a little over an hour, and I know better; but, I'm itching to get this thing going, and I have to decide whether to cut the tabs before I can 'move on' with the build).
  3. Jul 7, 2010 at 7:39 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    just cut it, whats the worst that can happen?
  4. Jul 7, 2010 at 7:45 PM
    matthew5olson
    matthew5olson Well-Known Member
    matthew
    pittsburgh, PA
    04 ext cab 3.4L 5spd 4x4 sr5
    K&N cold air intake, doug thorley headers, rear sensor simulator, flowmaster 40 series, magnecor plug wires, Royal Purple synthetic gear lube, airaid throttle body spacer, Hyperground system, flex-a-lite elec fan.
    i kept all mine. I'll see if I have pics. I did hide them somewhat
  5. Jul 7, 2010 at 7:45 PM
    dwalden2
    dwalden2 HBTFD
    Derick
    Blue Ridge, Georgia
    '05 TRD Offroad V6 6 spd
    SCS Stealth 6 Wheels, 285/70/17 STT Pros, Demello Offroad front bumper, 20" LED Bar, LED Fogs, LED interior lights, Wet Okole Seat Covers, Body Armour Rear Bumper, Smittybilt 10K winch, 3" OME Lift
    I don't see how it would affect the stability of the grille. For the Satoshi or even a billet on the 2nd gens we have to cut everything out of the grille and it doesn't bother it. I think ya should go ahead and chop em.
  6. Jul 7, 2010 at 7:50 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I cut them at an angle to hide them a little more. Remember wwhen your standing in front of the truck your taller than the grille. You don't see those 2. I have one pic so you can see what I did. I'll post a finshed pic and you can decide for yourself if its to noticable.
  7. Jul 7, 2010 at 7:51 PM
    matthew5olson
    matthew
    pittsburgh, PA
  8. Jul 7, 2010 at 7:51 PM
    1st Gen.
    I end up with a sh!tty grille and have to start from scratch...:rolleyes:
    Yeah, I've reviewed your build...it should be one of the links below this thread.:) The issue is, I'm making mine a "deep dish" style grille: The grille material will sit behind those tabs/posts, and if I don't remove them, they'll be an eyesore.
    I'm leaning this way; the "Not to be removed" could provide enough stability to keep the thing from being flimsy once mounted. I can't see any other way to complete it in a "deep dish" style.
  9. Jul 7, 2010 at 7:52 PM
    matthew5olson
    matthew
    pittsburgh, PA
  10. Jul 7, 2010 at 7:53 PM
    matthew5olson
    matthew
    pittsburgh, PA
    mine is a deep dish also
  11. Jul 7, 2010 at 7:55 PM
    matthew5olson
    matthew
    pittsburgh, PA
    you can see in this one better bc of the sunlight. If you look close you can see I cut the mesh around the support.
  12. Jul 7, 2010 at 7:56 PM
    1st Gen.
    To be clear, I'm adding 1"-1.5" to the "dish" by using fiberglass. Yours doesn't look bad at all...maybe those tabs aren't the eyesore I thought they'd be...I just want mine to be as clean as possible.
  13. Jul 7, 2010 at 7:57 PM
    matthew5olson
    matthew
    pittsburgh, PA
    I would recomend keeping them. Otherwise the line where the hood meets the grille may look retarded. The grill won't stick out like it should and the hood will form a lip overtop of the grille. Also you can always go back and cut them off later. gluing them back on is not as much of an option.
  14. Jul 7, 2010 at 8:00 PM
    matthew5olson
    matthew
    pittsburgh, PA
    oh I see. . Like I said. from a standing position the angle at which you look at the grille hides them. But if you want them to be gone I would recomend fabing some sort of spacer between the back of the grille and the hood support. (so if someone leans on the grille it doesn't give and/or crack.
  15. Jul 8, 2010 at 5:21 AM
    jbaguam
    jbaguam Member
    J
    Guam
    195000 miles and still rollin
    took out heater, dont need it on an island
    nice feet
