1st gen single cab to early '90s P/U cap/topper fitment?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Pbfender15, Mar 22, 2024.
  1. Mar 22, 2024 at 2:52 PM
    Pbfender15
    Pbfender15 [OP] Well-Known Member
    multiple 1st gens
    Hey all:
    Beds are same dimmensions but does a 1st gen single cab cap/topper fit a '90s pickup? Mainly asking about fit of cap lines to back of truck cab...? (I know 1st gen xtra-cab does not fit single cab...)
    thanks --
    1997tacomav6 likes this.
  2. Mar 22, 2024 at 4:06 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    I had a pickup shell on my 1st gen for a while, it fit okay not perfect though. The main problem I had with mine was that it had the gasket-tube cab seal, which never fit my ext cab so it leaked in the rain/car wash. I bet it would've sealed on a single cab though.
    Pbfender15[OP] likes this.
  3. Mar 22, 2024 at 8:34 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    The 89-94 trucks are a couple inches lower to the top of the cab measured from the top of the bed rails than first gen Tacomas so toppers from trucks are short on Tacomas, bed dimensions are the same so they fit, as long as you’re cool with the height not a problem
