1st Gen SPC LR UCA's Alignment Question
Discussion in 'Suspension' started by Buckaroo1993, May 24, 2018.
  1. May 24, 2018 at 7:40 PM
    Buckaroo1993
    Buckaroo1993 [OP] Who?? ME??
    Vinny
    Georgia
    2003 3.4L BSP DCSB TRD OFF-ROAD/SR5 4WD
    17x9 HELO HE878 with Hankook RF10 DYNAPRO AT-M LT275/70R17 RCD/Billie's Front and Rear with OME 883's and HS Progressive AAL Resulting in 3"+ Lift LR SPC UCA'S Diff Drop K&N Cold Air Intake LED's Exterior/Interior
    So I can make sure I understand...
    After I install the SPC LR UCA's, but BEFORE I take it to get the alignment, I should:
    1. MAX the caster on the LCA's
    2. Set the UCA's to +1
    3. Set camber via the UCA's adjustment slide (and maybe use a vertical bubble level set against the tire?)
    4. Hope toe is close
    OR
    1. Set the LCA's to neutral
    2. Set UCA's caster to +3
    3. See 3 above
    4. See 4 above
