1st gen standard transmission problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by 20tacoma02, Oct 20, 2015.
  1. Oct 20, 2015 at 1:28 PM
    20tacoma02
    20tacoma02 [OP] Member
    Jared
    2002 tacoma 5-speed
    hey guys new to the forum but need to figure out whats wrong with my truck. i just noticed driving through some back roads that when i was going up a hill my truck was bucking a little bit. it is a 4cyl. 5-speed and my rpms were right around 2000 in 4th gear. not sure if the little engine was just struggling a bit or this could be clutch or - hopefully not - a transmission issue. please let me know if anyone knows what is wrong here.
  2. Oct 20, 2015 at 4:07 PM
    Bullfrog 75
    Bullfrog 75 Well-Known Member
    Jeremy
    2002 red prerunner
    So for clarification you hit the hill in a high gear and it caused shuttering? Did you try to downshift, and if so did it still shutter? If you tried to reproduce the effect and it did not shutter in a lower gear then you were out of the power band. If when you downshifted and the engine shuttered in the lower gear as well, then yes it could be possible that clutch is slipping.
  3. Oct 20, 2015 at 4:10 PM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
    At 2000rpm there would be no need to downshift.
    Likely not a tranny issue.
    I had the same problem back when my exhaust was leaking.. you ever throw a code?
  4. Oct 20, 2015 at 4:24 PM
    Bullfrog 75
    Jeremy
    2002 red prerunner
    The point of downshifting was to see if the problem persisted in lower gears only.
  5. Oct 20, 2015 at 4:33 PM
    20tacoma02
    Jared
    2002 tacoma 5-speed
    problem still occurred but not as much. check engine light isn't on and i haven't been home to check for a code but thanks for the help guys.
  6. Oct 20, 2015 at 4:51 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    When I go up a pretty good hill at 2000 rpm in 4th gear with my old 4 cylinder, I have to downshift to 3rd or the truck will just wind down. So you might be out of the power band. Mine doesn't buck, though - it just slows to a crawl and RPMs fall off even with the pedal on the floor.
    Bullfrog 75 likes this.
