1st Gen Subwoofer Install Options
Discussion in '1st Gen. Tacomas (1995-2004)' started by ryancorbett3, Oct 1, 2015.
  1. Oct 5, 2015 at 5:44 PM
    WildLand
    WildLand Does Ursus arctos defecate in deciduous forest?
    Josh
    NM
    16T4RSR54WD
    I know you aren't really looking for underseat but I have one of these and it bumps hard with the right tuning. It was cheap and comes with everything you need. Also powered so don't need an amp, also its under my driver seat so no one sees it and wants to break into my truck.
    http://www.ebay.com/itm/like/390971120616?ul_noapp=true&chn=ps&lpid=82
    jammer and Fernando like this.
  2. Oct 5, 2015 at 5:50 PM
    Minnetacoma
    Minnetacoma Well-Known Member
    Elliott
    Minnesota
    96 tacoma sr5 with oe sunroof
    3.5 fabtech suspension lift with dirt logic shocks, Wheelers Alcon 8 pack rear leafs with extended brake line All pro rock sliders Cbi DIY front bumper with m8000 winch Cbi bushmaster 1.0 non swing arm 33x10.5 BFG mud terrains Skid row front skid plate Trs headlight retro fit fxr 2.5in projectors with rbg halos Audio/electrical upgrades K2 73ah lithium battery Big 4 upgrade 300a Ohio generator alt Alpine type r 6.5 coaxials in front Alpine type s 6.5 coaxials in back Alpine double din touchscreen Digital designs z3 15” subwoofer Digital designs m4 amp Alpine ktp 445u behind the dash amp for speakers 152db
    I don't live in a metropolitan area
  3. Oct 5, 2015 at 5:54 PM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Well that's good you can keep that big ol thing in the open then
  4. Oct 5, 2015 at 6:27 PM
    Madjik_Man
    Colorado Front Range
    I have this under my passenger seat.
    If you go in with the expectations of an 8" underseat powered sub, you will be more than satisfied. Really fills out the sound nicely... but don't expect it to boom.
  5. Oct 5, 2015 at 6:37 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    That's why I added 2 for twice the power.
  6. Oct 5, 2015 at 6:53 PM
    Minnetacoma
    Elliott
    Minnesota
    Lol it's only gonna get bigger
  7. Oct 5, 2015 at 7:00 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    Go big or go home
    1997tacomav6 likes this.
  8. Oct 5, 2015 at 7:02 PM
    Minnetacoma
    Elliott
    Minnesota
    Lol why do the sea gulls fly upside down in Newfoundland?.....
    Cause there's nothing worth a shit there
  9. Dec 17, 2016 at 8:00 PM
    RhettSims
    RhettSims Tacoma4Life
    Rhett
    Ft Walton Beach, Florida
    2004 Red Tacoma TRD SR5 Limited 4x4
    ToyTec Bilstein 3" lift K&N air filter Grey Wire Mod Mickey Thompson Baja Lock 16x8 BS:3.625 BFG KM2 285/75/16 Turn signal/running light swap 2X10 RockfordFosgate P3 1200 Wat RockfordFosgate Prime Amp Regear 4.88 CV boot mod ABR front locker Custom Fabricated bed rack CVT Mt. Ranier High lift 60" Hella FF
    Super old dead thread but I'm running 2 10" Rockford fostgate P3
    1200 watt amp
    It's a 9" deep box sitting on the back bench. Works great super sound quality and I can move the seat all the way back still.
  10. Aug 16, 2018 at 10:24 PM
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    I got this same sub and was not able to get it to fit under my driver seat. The seat slide cable hangs down too far and hits the top of the sub preventing the seat from sliding all the way back. How did you fit this?
  11. Aug 16, 2018 at 10:56 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    You can add a seat lift for more under seat clearance.
    http://4crawler.com/4x4/CheapTricks/index.shtml#SeatHeight
  12. Aug 16, 2018 at 11:15 PM
    betterbuckleup
    Ian
    Concord, CA
  13. Aug 17, 2018 at 4:57 AM
    WildLand
    Josh
    NM
    16T4RSR54WD
    Did you use the rubber feet provided? I did not. Also my wires are all facing towards the back of the cab. I can take a pic when I get back into the states on the 21st
  14. Aug 17, 2018 at 4:58 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Always the option of center console
  15. Aug 17, 2018 at 7:41 AM
    #35
    betterbuckleup
    Ian
    Concord, CA
    When I test fitted it under the seat, I slid it under the seat without the rubber legs and it wouldn't slide all the way to the front and was sticking out the back a good amount The top grille was also almost hitting the bottom upholstery of my seat too. This was without me sitting on it so I figured it probably wasn't the best idea to be sitting on top of the woofer grille.
    Is it the same way in your truck?
  16. Jul 11, 2021 at 3:27 AM
    #36
    Rldanie
    Rldanie Punisher78
    Colorado
    2002 Supercharged, 2” pulley, FIC, Methanol, Transgo Shift Kit
    Engine Performance upgrades: Supercharged (Magnuson) FIC/6 Champion Radiator Toyota Corolla thermostat 168° JBA Headers JBA cat back exhaust Upgraded fuel pump Volant Cold Air Intake With custom plexiglass cover TransGo Transmission A340F Valve Body upgrade B&M Transmission cooler Methanol Injection 2 inch pulley Future Plans Supra Injectors Light weight crankshaft pulley Leather seats Off-road upgrades 3” rough country lift 33x12.5” Dick Cepeks Other upgrades: JL Audio 12W6 Sub in custom box JL Audio C5 Mids and tweets all the way around Sound dampened whole cab Transmission temp sensor Gen Tex rear view mirror (temp and compass) Blue instrument panel, a/c control panel lights, shifter, ashtray, glove box. Blacked out badges Blackout bumpers and grill MariMoto Projectors with demon eyes LED Taillights Second generation leather steering wheel with audio controls Custom leather wrapped automatic transmission shifter 3rd gen 4 Runner key ring light (blue) 3rd gen 4 Runner hood scoop
    likely going to be selling this box soon.
    Sub not included
