1st Gen suspension advice needed
Discussion in '1st Gen. Tacomas (1995-2004)' started by WRO, Oct 25, 2019.
  1. Oct 25, 2019 at 7:47 PM
    WRO
    WRO [OP] Well-Known Member
    Portland OR
    2016 Taco DCLB Sport
    Scratches
    My boss whom I guide hunters for has a first gen (crew cab short bed) that needs all new suspension, I know 3rd gens well but am a noob on 1st gens.
    Truck will be run 30% of life off road (gravel, shit dirt roads, etc) both front and rear squeak like bugger now so ending that is important as well.
    Thoughts on a good full replacement?
    GQ7227 likes this.
  2. Oct 25, 2019 at 8:33 PM
    whitetaco01
    whitetaco01 Well-Known Member
    So Cal
    01 Prerunner
    Mid Travel Stuff
    What’s the budget?
  3. Oct 25, 2019 at 8:38 PM
    WRO
    Portland OR
    Scratches
    Under 2500 if possible for parts.
  4. Oct 25, 2019 at 8:39 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    The OME kit is a great place to start at about $1200 for all new shocks, springs, and about 2.5" lift. You can customize the coils for an aftermarket bumper/winch setup.
    What year is it? the (rear) suspension changed in 98.
    Something like this perhaps... I'd still suggest all new front bushings, possibly poly bushings. Ball joints, too.
    If you're on a slightly tighter budget, get a set of 5100 shocks (all four) for around $350, then you'll likely want to replace all the bushings and a longer shackle or an add-a-leaf for the rear.
    Hamer95USA likes this.
  5. Oct 25, 2019 at 8:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    either bilstein or OME would work for ya id say.
    would highly reccomend replacing the ball joints with new OEM ones, the ball joints are known to fail
    GQ7227 likes this.
  6. Oct 25, 2019 at 10:52 PM
    WRO
    Portland OR
    Scratches
    2002
  7. Oct 26, 2019 at 7:55 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i hear the L ball joints are known to 'wear' and is very 'rare' to fail :confused:
    and by fail i mean to just blow apart with Absolutely no warnings whatsoever
    ... just a concerned and confused long time tacoma driver with too many questions lol
  8. Oct 26, 2019 at 8:11 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    The OEM ball joints fail at the end of their life, can happen above 100k miles and beyond. The issue is that most people completely forget about them and they don’t show wear signs until it’s too late. Then they catastrophically fail and cause way more damage, not to mention potentially bodily damage to you and others on the road. This is related to the design of them and the fact that people ignore them as a maintenance item.
    GQ7227[QUOTED] and jbrandt like this.
  9. Oct 28, 2019 at 9:43 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Bilstein 5100 shocks all around and replace all bushings with polyurethane ones :thumbsup:
  10. Oct 29, 2019 at 10:01 AM
    jbrandt
    Justin
    Didn't you read my balljoint soapbox on my build thread? :D
    They are absolutely known to fail, and when(if) they fail, it is generally catastrophic because of the way the BJs are designed (the coil spring puts tension on the ball/cup socket, so it has a tendency to pull apart.
    You are more or less correct though; that it seems the failures are usually from neglected maintenance and ignoring warning signs.
    GQ7227[QUOTED] likes this.
  11. Oct 29, 2019 at 10:46 AM
    jbrandt
    Justin
    If you beat on your truck, then the BJs won't last as long. But as far as just a "lift" is concerned, IMO the BJs don't really see any more forces than "normal", with maybe a little added stress from larger tires (assuming that's why you have a lift).
    Leaking is ONE sign of a worn out, or soon to wear out BJ. But this just means that dirt and grit CAN get in there and wear it out quicker. If you see a leaking/torn boot, just go ahead and replace.
    But that's not the only sign.
    The MAIN sign is that the BJ becomes loose/sloppy. This is where I think most people fail to see the warning signs. The problem is that the amount of "slop" according to the factory manual is so small, that if you can feel the slop using the "pry-bar test", it's WAY out of spec and should be replaced immediately.
    Under "normal" wear and tear, an OEM BJ "should" last 100k(ish) miles, if not more. You'll hear people talk about how their BJs have lasted 200k+ miles. But that doesn't mean you can ignore your Balljoints until you hit 100k miles. Off-roading puts a LOT more wear/tear/abuse on them, so they won't last as long.
    As I said in my soapbox, I plan to replace my 555 balljoints FAR sooner than that, probably every 5-10k miles. That's probably overkill, but lower BJs are super easy to replace, and they aren't that expensive. Even OEM BJs aren't all that expensive, considering the alternative (a 'sploded front suspension).
    cruiserguy and GQ7227[QUOTED] like this.
  12. Oct 29, 2019 at 10:50 AM
    jbrandt
    Justin
    Poly bushings will have a more precise steering feel, but will tend to be a little harsher because rubber bushings have a little give to them.
    cruiserguy likes this.
  13. Oct 29, 2019 at 10:59 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    To add to this, if using Poly Bushings, I suggest a high quality grease (better than the stuff manufacturers include).
    cruiserguy and G59 like this.
  14. Oct 29, 2019 at 11:22 AM
    Hamer95USA
    Hamer95USA Well-Known Member
    1999 Toyota Tacoma 4x4 SR5 extended cab reborn!
    Complete OME suspension kit, Used low mileage V6 engine swap, black powder coated Chou Seiki T15x7JJ, ARB deluxe bumper, Smitty Bilt nerf bars, Weathertech floor liners, Torklift tiedowns
    @OP: I would recommend the OME complete suspension kit with the 883 front coils/Dakar leaf springs/D43XL add a leaf/extra hardware plus installation for your boss' truck. You'll be hauling yourself, your clients & their hunting gear in some adverse conditions and you'll probably be heavily loaded.
    orcoastjosh likes this.
  15. Oct 29, 2019 at 2:30 PM
    G59
    G59 Stock af
    Torres
    SoCal
    03’ Long Travel DC
    Yes good point!
  16. Oct 29, 2019 at 2:34 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Hmmm! My 02, 400k on the original lcas and lower ball joints before I got my 2015. Oh wait the uppers were original too.
    GQ7227 likes this.
  17. Oct 29, 2019 at 3:32 PM
    Empty_Lord
    Dan
    Uppers are never really a issue. Lower control arms won’t really go bad. Typically have issues aligning because the cam bolts seize into the bushings. Lowers on mine at 275k had no play but were very sloppy.
    Stock suspension they last a long time.
    G59 and GQ7227 like this.
  18. Oct 29, 2019 at 7:39 PM
    orcoastjosh
    orcoastjosh Member
    Ivan
    1996 3.4L V6 4x4
    none
    Yeah that’s a really nice kit and well worth the money. 883 coils are too much for me but perfect for a loaded down taco
    Hamer95USA[QUOTED] likes this.
