1st Gen swap opinions
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacoma0Josh, Mar 13, 2013.
  1. Mar 13, 2013 at 9:46 PM
    Tacoma0Josh
    Tacoma0Josh [OP] Well-Known Member
    The Colony, Tx
    2013 Reg Cab 4x4
    3" spacer lift, with procomp 16"s and 32.5" kelly safaris
    Well now that i have my new '13 regular cab its time to turn the old regular cab 1st gen in to something more fun than just a daily driver. The engine in it 2.4 2rz is on its last leg, i was originally going to replace it with a rebuilt 2rz and turbo it. After doing some research ive found i can get a 1uz or a 1jz or 2jz for less than a rebuilt turbo 2rz and do the swap, for a little more i could get a turbo 2rz.
    Swaps come with engine, trans, ECU and harness. Done some reading and if i swap in a 1jz or 2jz i can utilize the W58 transmission as it will bolt up to the W59 bell housing. Anyone have any experience with either swaps? Im leaning towards which ever would require the least amount of fabrication, and if there are any adapter mount kits for either swap.
  2. Mar 13, 2013 at 9:48 PM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    Cummins swap! lol
  3. Mar 13, 2013 at 9:51 PM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
    If the truck was 4x4 then a diesel would be at the top of the list, but since its 5 lug 2wd it will be low and fast.
  4. Mar 13, 2013 at 10:22 PM
    YotaOverAll
    Jessie
    Panama City, FL
    02 Prerunner SR5
    Gotta point. Hmmm...
  5. Mar 13, 2013 at 10:23 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    2JZ. That's all I got. And that I want one in my Pickup too.
  6. Mar 13, 2013 at 11:37 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    A 2jz with a r154 tranny housing will bolt up strait to a r150f 5soeed and t case.
    Or..I'd look int doing a 1uz or 3uz swap. Small v8 :cool:
  7. Mar 13, 2013 at 11:43 PM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
    I guess im leaning more towards the 2jz if its more of a bolt up swap, a 1uz or 3uz would be sweet but the fabrication is throwing me off. Also no transfer case, 2wd truck.
  8. Mar 13, 2013 at 11:44 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Yea saw that after I posted.
    Well you'll have to make new mounts either way..
    But if you going with that I'd just get an r154 tranny and custom drive shaft.
  9. Mar 14, 2013 at 9:45 AM
    low boy
    low boy 4wd Toyota Enthusiast
    Maryland
    2001 Tacoma TRD Xtra-cab
    lift, tires, wheels, some interior stuff
    the v8 is a lot of fab work or it will lead to cooling issues, if a 2jz is what you want you still have to fabricate mounts and move the engine 6" forward... either way in my opinion it's not worth it. go bolt ons with your current engine, port & polish the heads, add new valves and injectors, chip, etc. but swapping the motors sucks. this is my opinion of course, just trying to save you some ass pain... good luck.
  10. Mar 14, 2013 at 10:15 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
  11. Mar 14, 2013 at 10:20 AM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
    The engine is coming out no matter what, its going to crap out on me soon and I would rather be ahead of it. If im taking it out and replacing id rather but a better engine back in if it wouldnt be too big of a hassle. I can also get a 3rz at an affordable price, if that will bot in place to the transmission and mounts in the same as 2rz I could do that.
  12. Mar 14, 2013 at 10:49 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    pretty sure a 3rz will go right in.
    then turbo it.
  13. Mar 14, 2013 at 8:29 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    1uzfe, do a full build and that thing will rip!
  14. Mar 15, 2013 at 1:02 PM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
    Looks like its going to cost the same amount to buy used or rebuilt 2rz/3rz as it would to swap in a bigger engine. Id like to hear from someone who has done a 2jz or 1uz/3uz swap in to a 1st gen. So far the biggest hurdles are finding out of the transmission already in will bolt up to the 2jz and fabricating engine mounts. Not to mention all of the 1uz/3uz swaps I find are auto trans/ecu, finding a stardard one is looking pretty tough.
  15. Mar 15, 2013 at 1:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Like I said.
    R154 will bolt up to the 2jz or the 1/3uz with adapters.
    2jz bell housing is about 300.
    Adapter kit for 1/3uz is about 1600
  16. Mar 15, 2013 at 1:33 PM
    BuzzardsGottaEat
    Some Toyotas
    Round tires
    Unsubbing haha. Making me want to go through with the 2JZ swap on the 93.
  17. Mar 15, 2013 at 1:45 PM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
    Blackdawg do you know of anyone who makes mount adapters for the 2jz? P
  18. Mar 15, 2013 at 1:58 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
  19. Mar 15, 2013 at 3:02 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
  20. Mar 15, 2013 at 4:21 PM
    Tacoma0Josh
    The Colony, Tx
    2013 Reg Cab 4x4
