1st Gen Taco Brake Upgrade Help Request
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bouvierman, Aug 1, 2012.
  1. Aug 1, 2012 at 1:43 PM
    Bouvierman
    Bouvierman [OP] Member
    Brian
    Nashville, tn
    04 Tacoma, Access-cab, Supercharged
    Supercharged, 7th injector, Topper
    Hi,
    I'm new to the Tacoma WOrld Board and have a 2004 Tacoma extended cab with 50K miles. It has a supercharger (V6), a camper shell, XM radio and I just had the 4 Wheel Parts Shop in Nashville install $2,700 in Icon suspension upgrades. The improvement in handling and ride is significan (it should be :)
    My next opportunity for improvement is the brakes: I find the brakes take a little longer to stop than feels comfortable. Specifically, those times are when I'm going a little too fast and need to stop unexpectedly. Is there an off-the-shelf upgrade that will reduce stopping distance that I could have 4 Wheel Parts install? Any recommendations are appreciated. I do little-to-no off roading. I just like the truck and want to trick it out as much as reasonable.:cool: Any help you can provide is appreciated in advance.
    Thanks!
    Brian
  2. Aug 1, 2012 at 1:47 PM
    rushr
    rushr Well-Known Member
    04 DC TRD 4X4
    OME 883 Coils, Dakar Leaf Packs/D6XL AAL, Nitrocharger Sport Shocks, ARB Bumper, Warn M8000 w/Synthetic Line, BAMF Sliders, Odyssey Battery, ProComp 7069 15x8, BFG KM2 33x10.5x15, Frame End Cap Mod, Hayden Transmission Cooler
    Do a search for Tundra brakes. Plenty of info
  3. Aug 1, 2012 at 1:47 PM
    1998tacomaowner
    1998tacomaowner Well-Known Member
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    What size rims do you have??
  4. Aug 1, 2012 at 1:53 PM
    MapleMoose
    MapleMoose Drunk Canadian
    Ian
    West Kootenays
    1996 Tacoma SR5
    3" Eibach Coils, 3" AP Springs, AP 6" Shackles Toytec Diff drop, BAMF Sliders, Deck plate mod,Volt meter, Highbeam mod, PIAA fogs, 18" Magnaflow, LED dash swap, Color matched Satoshi Grille, Custom Rear Plate Bumper
    big brake mod
    aka Tundra caliper and rotor swap
  5. Aug 1, 2012 at 3:35 PM
    1998tacomaowner
    chris
    clarkston WA
    98 toyota tacoma
    3in lift,33s
    The reason why I was asking what size rims you have was cause to do the tundra calipers and rotors you have to have biggger than 15 inch rims and this is pretty easy to do you could probably save some $ and do it yourself
  6. Aug 1, 2012 at 4:22 PM
    Grousehunter 12
    Grousehunter 12 Well-Known Member
    Ted
    Central Kentucky
    TRD 4x4 Off Road
    Tundra brakes on front
  7. Aug 1, 2012 at 7:27 PM
    Bouvierman
    Brian
    Nashville, tn
    Good info on the Tundra brake conversion. Can anyone give me a rough estimate what a shop may charge to do the job....including all parts and labor? Thanks! Btw...my wheels are 16".
  8. Aug 1, 2012 at 7:31 PM
    Madjik_Man
    Colorado Front Range
    My brother has a bouvier named Dudley.
    One of the coolest dogs ever.
  9. Aug 2, 2012 at 8:07 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    parts can be had for around 400 if you buy new. then ask your shop labor price
  10. Aug 2, 2012 at 8:30 AM
    pittim
    Pennsyltucky
    Boujee Prius
    Also,
    from my experience with tundra brakes, there wasn't really any noticeable improvement in stopping power. from what I read before putting the parts on, the bigger brakes are really only noticeable while towing.
    ps.
    if you want to drive your truck like a sports car, probably should have bought a sports car in the first place.
  11. Aug 2, 2012 at 8:36 AM
    Brandon9402
    Brandon9402 uncoordinated dirtbox
    Brandon
    Mississippi
    02 prerunner sr5
    Kenwood headunit, 4 kicker 5x7 coaxials,2 memphis 1.5" tweeters, 2 12" memphis subwoofers, memphis 500w amp, chrome grille guard, kc fog lamps, chrome side steps, chrome tool box, and window visors
    try getting new brakes to start off with. I got new brakes about 2 or 3 months ago and I can practically stop extremely fast if I need to. that's not any kind of upgrade just had my rotors and pads replaced.
