1st gen taco write up thread
Discussion in 'Technical Chat' started by fireturk41, May 15, 2010.
  1. May 15, 2010 at 1:43 PM
    fireturk41
    fireturk41 [OP] I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    heres a thread for write ups on first gens, from simple repairs to mods.
    i posted something earlier asking for help and got the response of google it, i used google and ran into problems because of a lack of visual image
    ill start first gens only though
  2. May 15, 2010 at 1:52 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    Materials : 9mm socket, socket extension, ratchet, drain pan, rags, brake cleaner, star sockets, transmission fluid, and idk what size drain bolt is, mines afte market
    first pull drain plug on trans. pan and let fluid drain
    then undo all bolts and pry pan off with a screw driver
    you will have to undo the pan from the dipstick
    (black thing)
    once pan is removed take out magnets and clean in pan and magnets
    scrape all toyota gunk outta pan and transmission
    undo filter and wash off with brake cleaner (optional)
    check for any large metalic particals
    bolt filter back on
    bolt pan back on and put fill tube back on
    fill with trans fluid (mine took bout 4qts)
