1st Gen Tacoma 12" OSR Outboard Shock Relocation - Outside Frame Rails
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARCHIVE, Oct 18, 2018.
  1. Jan 23, 2019 at 4:41 PM
    #321
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Rub sorry not run. I have 2.5 triple bypass right now that's why when I install the kit I wanna stick with 2.5
  2. Jan 23, 2019 at 4:43 PM
    #322
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    How are the pipes on your bypasses oriented? You gonna out tis on your tundy axle
  3. Jan 23, 2019 at 4:48 PM
    #323
    1st4x4
    sam
    Torrance
    I'm going to sell the bypasses there 16s I'm currently using to big of a shock for my set up and going threw the bed with a cage and only all pro leafs. Ya when this gets installed the tundra axle will be installed at the same time. Tempted to buy the shocks now but thinking of waiting untill I know exactly what I can fit
    Icon_Adrian and Speedytech7 like this.
  4. Jan 23, 2019 at 5:09 PM
    #324
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    2.5
    Rubbin’s racin’
    Pyrifera, erice and 1st4x4 like this.
  5. Jan 24, 2019 at 10:04 AM
    #325
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Just some observations for those not familiar, your ADS are especially short as they have an "over-the-body" top cap and welded lower ends, both helping to make them short. Normal universal King and Fox 2.5"x10" like Willbeck has are about 18" compressed
    Silver02Taco and Willbeck like this.
  6. Jan 24, 2019 at 10:05 AM
    #326
    ARCHIVE
    Eric
  7. Jan 24, 2019 at 10:13 AM
    #327
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Totally true. Did a bunch of research to end up with the ADS for exactly this reason (which I'll eventually get into a write-up). You can shorten up the Kings a bit (to 17.3" collapsed from 18.3") by getting welded lowers on them as well, but still much longer than ADS.
  8. Jan 24, 2019 at 10:14 AM
    #328
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    You can get the thread over cap as well from King if you want and it'll be closer to 15.5'' collapsed if you want.
    basically a coilover with a welded rod end.
    Reh5108 and Willbeck like this.
  9. Jan 24, 2019 at 10:21 AM
    #329
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    King will make them that way too, but that’s some good leg work to find ways to stuff the shock where you wanted, vs making the mounts around the shock.
  10. Jan 24, 2019 at 10:23 AM
    #330
    ARCHIVE
    Eric
    Cool, in no way am I trying to undermine the validity of your route, just wanted make explicit why it works, and that you can't just get a standard King/Fox 10" and have the same results
    desertjunkie760 and erice like this.
  11. Jan 24, 2019 at 10:36 AM
    #331
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Happy to do it!
  12. Jan 27, 2019 at 2:14 PM
    #332
    tacofor4
    tacofor4 Active Member
    Rob
    2004 TRD 4x4 Tacoma Crew Cab
    Stock - for now
    Loving what I'm seeing so far - so I'm wanting to put together a mid travel kit and more than likely going with King coil overs/TC UCA's but still debating what I should with my rear. I'm currently bone stock and really like the travle that this outboard shock setup allows.
    I'm into slow crawling, needing max articulation and will run 285's for now but eventually wanting 315's. With that in mind, would you guys recommend this setup for me or something different.
    Would love to take full advantage of a 10-12" shock stroke.
  13. Jan 27, 2019 at 2:42 PM
    #333
    Blackdawg
    Monte
    Wyoming/St. Louis
    This might not be the kit for you. Putting shocks inboard and angled will give you more flex travel. This kit won't as much. It's much more geared towards going fast than flexing.
    Willbeck likes this.
  14. Jan 27, 2019 at 3:05 PM
    #334
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    Also you won’t get as much ajustment when it comes to getting you alignment on total chaos arms. If your going 315s just get the spc arms. That will lead to less tubbing
    jubei likes this.
  15. Jan 27, 2019 at 3:28 PM
    #335
    tacofor4
    Rob
    Stock - for now
    Very good info fellas - appreciate it, I'm coming over from the jeep world so still learning a lot off this forum!
  16. Jan 27, 2019 at 6:03 PM
    #336
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Shock location does not affect flex or travel. The springs do as well as the valving of the shock. You can run them outboard and have good results crawling as it makes it more stable and still use all of the travel from the leaf springs. Like stated before the issue becomes rubbing the shock body which can be eliminated by a wider axle or notching the frame.
  17. Jan 27, 2019 at 7:25 PM
    #337
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Your statement is contradictory. If rubbing the shock is an issue through the travel then shock location has a large affect with flex.
    Shock valving doesn’t have anything to do with suspension geometry.
  18. Jan 27, 2019 at 8:06 PM
    #338
    malburg114
    Las Vegas, NV
    A wider axle or notched frame eliminates the rubbing issue which not everyone needs or wants. I'm just talking about leaf springs and suspension in general that the amount of travel you get is from leaf springs not the shocks. The shocks are there to dampen the ride and moving them does not get you more travel unless they where to short and limiting droop or the shock bodies are to long and limiting up travel.
    And you are correct shock valving doesnt have anything to do with the geometry but hes saying that in board and angled shocks will give him more travel which is not true. The spring will travel the same distance whether the shock is in board or out board but the dampening and stability will be different.
  19. Jan 27, 2019 at 9:32 PM
    #339
    Blackdawg
    Monte
    Wyoming/St. Louis
    Inboard will allow more wheel travel then outboard. It's simple geometry.
    If you have a 10" shock outboard the frame vs inboard the fulcrum can move further with it closer to the center point.
    Now, the guy that asked this question did not seem like he was about to cut his bed to pieces and notch his frame to match his sac front or anything like that. Sounded like he was going for mostly bolt ons and stated very clearly he was crawling more. Seeing as how you can fit a 10" under the bed in various ways you can get more flex out of a 10" shock there then outboard.
    Yes of course this is pending all other things that are involved with it including the leafs. But for all we know he wants Chevy 63s too for lots of flex.
    In which case...
    Inboard will merit him more wheel travel with less hassle than outboard.
    Vertical travel it doesn't matter. You can fit 10s in or out but will rub when out this once again limiting your flex likely with tire rubbing ESPECIALLY with 35s on the truck. Wider axle or not. Which is a whole other topic and leap for someone doing a build with these trucks that very rather ever fits in with someone's uses and needs with a 1st gen taco.
    I stand by my statement.
    He'd be better off with in board shocks.
    Willbeck and NcTaco27 like this.
  20. Jan 27, 2019 at 9:39 PM
    #340
    desertjunkie760
    Shane
    Check My Sig.
    What you're saying is the amount of travel is based off of the leaf springs and not other limitations, such as shock location, yet followed up your statement in saying that if the shock is too short/long then it directly limits your suspension travel? o_O
    I think what @Blackdawg is trying to say is that if you go inboard with your shock mounting and use some geometry in their mounting placement then you can yield much better cycling numbers than outboard due to the fact that you will not have a rubbing issue on the shock and limits bump travel.
    Yes, you can do an axle swap or notch the frame but very few individuals want to go that route as its much more of an investment to do so and takes additional work/ability. You are also failing to realize that the point in a kit like this is
    Blackdawg likes this.
