1st Gen Tacoma 12" OSR Outboard Shock Relocation - Outside Frame Rails
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARCHIVE, Oct 18, 2018.
  1. Feb 4, 2019 at 6:43 PM
    #361
    erice
    erice Well-Known Member
    Eric
    San Diego
    @Prayn4surf has some on his rear. they are solid plates so you really can't tell they are there. vs i think trail gear has the holes in the middle.
  2. Feb 4, 2019 at 6:44 PM
    #362
    552Jrider
    552Jrider Well-Known Member
    Jeremy
    Norcal
    2002 DC 4x4
    How long of a shackle are you running with your alcans?
    erice[QUOTED] likes this.
  3. Feb 4, 2019 at 6:46 PM
    #363
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    What @Blackdawg said. But I think both is pretty legit, maybe overlill, but our fames are weak back there
    erice likes this.
  4. Feb 4, 2019 at 6:48 PM
    #364
    erice
    Eric
    San Diego
    i have the adjustable toytec ones i think running at 1" + 3" lift on the alcans.
  5. Feb 5, 2019 at 3:06 AM
    #365
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    @erice whats the final back spacing, spacers included?
  6. Feb 5, 2019 at 9:40 AM
    #366
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    those 2" spacers are what's saving you. Lose those and even your 1/4" advantage from the 2.0's is gone.
    LukeCC likes this.
  7. Feb 5, 2019 at 11:54 AM
    #367
    erice
    Eric
    San Diego
    4.5" bs on the wheel + 2" on the spacers. Don't remember the ofset on the wheel but it might be 0. at work so that info eludes me currently.
    :rolleyes: indeed it is. Not that 1/4" is much of an advantage. At full gnarly articulation there WILL be rub.
    Solution to that is to swap the axle for an FJ or Tundra if we want to eliminate the spacers and run less BS.
    What width tire are you running again @Willbeck?
  8. Feb 5, 2019 at 1:23 PM
    #368
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Swapping to a tundra axle is a bit extreme for most. 6'' wider over all.
    FJ is only 2.5'' wider total. So barely better than some spacers.
    erice likes this.
  9. Feb 5, 2019 at 1:49 PM
    #369
    Bandido
    Bandido Engine...er
    Alex
    Lexington, KY
    2003 Tacoma DC
    I know you guys moved past this already, but I'm catching up on this thread right now, and want to participate lol.
    I'm assuming @Blackdawg meant articulated flex travel vs true vertical of the axle... maybe you guys understood this without anyone explicitly saying it, so sorry for this if it is redundant for anyone.
    With outboard mounted shocks the amount of travel at the wheel during flex is much closer to the travel of the shock.
    With inboard shocks mounted at an angle... ]_/_o_\_[ the amount of travel at the wheel during flex can be more than the travel of the shock (similar triangles).
    The same concept is why outboard mounted shocks behave favorably in roll scenarios, because the motion ratio of the shock to wheel is closer to 1.0 in roll and bump, whereas inboard mounted shocks have a motion ratio that is composite of roll and bump, and the MR can vary quite a bit during travel depending on the installed angle of the shock, resulting in a divergent relationship when trying to tune bump and roll.
  10. Feb 5, 2019 at 5:53 PM
    #370
    erice
    Eric
    San Diego
    Yeah it would be to eliminate and or scale down the spacer. But yes.. extreme. Unless that was your plan all along
  11. Feb 5, 2019 at 6:47 PM
    #371
    Blackdawg
    Monte
    Wyoming/St. Louis
    You need fiberglass bed sides to do the tundra/t100 axle swap. 3" per side is just too much.
    Fj you wouldn't. But you probably still be running a 1" spacer at least
    LukeCC and erice[QUOTED] like this.
  12. Feb 5, 2019 at 9:28 PM
    #372
    erice
    Eric
    San Diego
    Or.. a flatbed? o_O
  13. Feb 6, 2019 at 4:08 AM
    #373
    Trim taco
    How many different axles will accept our 8.4 third? I know the early Tundy/t100 do, what about the FJ, 2nd gen, etc?
  14. Feb 7, 2019 at 9:03 AM
    #374
    Blackdawg
    Monte
    Wyoming/St. Louis
    2nd gen axles will. but only 1'' wider per side more than ours. Of course not the elocker axle. Though the elocker diff from ours is the same as theirs too.
    3rd and 4th gen 4runners too non elockers.
    LC will not. they run a 9.5'' diff. Im not a LC guru so there might be some out there that run it but I don't think so. Pretty certain they all have a 9.5 since early 90s.
    The newer FJ also runs a 8.4 with no elocker.
    Trim taco[QUOTED] likes this.
  15. Feb 7, 2019 at 6:03 PM
    #375
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    265 on mine
  16. Feb 11, 2019 at 8:49 AM
    #376
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    NcTaco27 and chrslefty like this.
  17. Feb 14, 2019 at 8:00 PM
    #377
    Dessertjunkie858
    Dessertjunkie858 Well-Known Member
    Madison
    2011 Tacoma
    If anyone is looking for a pair of Fox 2.5x12” that will work with this relocation , HMU.
    erice likes this.
  18. Feb 14, 2019 at 8:48 PM
    #378
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why are you swapping?
  19. Feb 14, 2019 at 9:24 PM
    #379
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    Price and location?
  20. Feb 14, 2019 at 10:56 PM
    #380
    Dessertjunkie858
    Madison
    2011 Tacoma
    Not. I’m always lookin for good opportunities.
    San Diego.
    Still working on a price. Depends on if I have to put anything into them.
    Pm me if interested. Don’t want to thread jack
    malburg114[QUOTED] likes this.
