1st Gen Tacoma 12" OSR Outboard Shock Relocation - Outside Frame Rails
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARCHIVE, Oct 18, 2018.
  1. May 8, 2023 at 11:31 AM
    #481
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    erice likes this.
  2. May 8, 2023 at 7:31 PM
    #482
    erice
    erice Well-Known Member
    Eric
    San Diego
    The part where it tapers down and is welded is ~64.55mm (2.541")
    The section after the weld is about the same as the axle diameter ~78.63 (or roughly 3")
    Believe this was what you were asking correct?!
    ARCHIVE[QUOTED][OP] likes this.
  3. May 8, 2023 at 7:48 PM
    #483
    ARCHIVE
    Eric
    Thank you! I have both plates in the axle tab at 3.09" ID. Originally I designed it to span the knecked down area, but now I'm thinking of landing one tab in the knecked area to move bottom of shock a little further inboard for better tire clearance.
    Anyone know if a 5-lug 1G axle housing is very similar to the 6-lug?
    Here's a pic from will beck's install, they modded the axle tabs, but looks like it could have a little inboard/outboard play.
    https://www.tacomaworld.com/threads...side-frame-rails.573407/page-11#post-19558935
    erice[QUOTED] likes this.
  4. May 15, 2023 at 9:14 AM
    #484
    1stgenkcm
    1stgenkcm Member
    Kai
    California
    1998 Tacoma TRD
    Archive Rear shock relocation kit w/ 12" king 2.5 TC UCA mid travel kit king 2.5 OME Dakar 33" Yoko Geos
    Ordered some king 2.5” 12” on top of this kit. Curious with your knowledge if you think i’ll need a 63 leaf or if it will fit fine at extension with stock leaf’s w/ limiter straps and bumps.
    ARCHIVE[OP] likes this.
  5. May 15, 2023 at 9:33 AM
    #485
    ARCHIVE
    Eric
    I'd see what your current leaf packs can do 1st. 64" springs would definitely use 12" shock travel with shock mounted outboard, as long as you aren't limiting your bump travel like 3 or 4"
    It's been discussed several times in this thread that 10" shocks inboard do fine for articualtion, but that is because you need less shock for articulation. Plus those people often have their bump travel majorly limited.
    I mention that because I figure that is why 1G people think 1G springs only do 10". 2001-2004 springs are 24"/32" which is same 56" overall length as a 2G/3G with which we get 12" shock travel out of
  6. May 24, 2023 at 9:43 PM
    #486
    kmattox
    kmattox Member
    SoCal
    2003 tacoma double cab
    2-3” icon lift, 255/85/16 km3’s, custom bed rack modeled after all pro design to keep bed topper. Cheena rtt. Bought not built for now.
    Looking for outboard and frenched frame options for my 1st gen. Deaver h70’s and fox 2.5x16’s on factory width. I was looking at the Barnes frenched in tower but I’m not thinking they’re long enough and for more clearance thinking of notching the frame itself but there’s a lot of obstructions on drivers side
  7. May 25, 2023 at 4:11 AM
    #487
    ARCHIVE
    Eric
    Bed cage, I'd read up on full LT setups on 1st gens
  8. May 25, 2023 at 6:39 AM
    #488
    kmattox
    kmattox Member
    SoCal
    Yeah I’m trying to avoid a full bed cage and with my wheel offset I’m trying to make enough room to allow minimal spacers. I’ve been reading the long travel threads but a lot of them went to tundra axles.
  9. May 25, 2023 at 7:10 AM
    #489
    ARCHIVE
    Eric
    As a designer with knowledge of shock lengths and SUA fitment, you're going to need a very tall tower up through the wheel wells to stuff 16", even worse with LT SUA springs, the whole point of which is bump travel, axle should bump out at bottom of frame rails. H70 springs means you'll be moving every hanger. There has to be better threads more in line with your project
    Kwikvette likes this.
  10. May 25, 2023 at 12:31 PM
    #490
    kmattox
    kmattox Member
    SoCal
    Yes there are better but this one popped up and was current, most are 10yrs old. I have most of the brackets stripped just need the gas tank side which has slowed me down. I have most of the kit needed just trying to find ideas and saw this one with people trying to fit an outboard 2.5 which is what I have. Going with a minimalist bed cage but think I need to add a little clearance in the frame rail as well.
  11. Jun 30, 2023 at 2:09 PM
    #491
    erice
    Eric
    San Diego
    Package arrived.
    Thanks Eric!
    @ARCHIVE
    Just as beefy as i remember. Like the implementation of the variable OD on the shock mounts for the axle.
    What are the little wrench looking things for?
  12. Jun 30, 2023 at 2:34 PM
    #492
    ARCHIVE
    Eric
    Thank you, those are nut "flags" that you tack weld to upper nuts so you don't need a wrench
    Thanks all for your support, got 4 kits left of the 1G Taco axle tabs, ready to ship
  13. Aug 31, 2023 at 9:24 AM
    #493
    ARCHIVE
    Eric
    Well we just sold out of that recent batch, thanks for the support!
    We are starting another batch
    erice and SoonToBeOn39s like this.
  14. Sep 4, 2023 at 9:12 PM
    #494
    ARCHIVE
    Eric
    "14” shocks...I’m at 13” shaft at full droop. And about 5.5” of up at ride height...7” shackles and 4” all pro leaf pack...flexes well and not alot of axle wrap"
    Reminder: People who say 1G Tacomas only need 10" shocks mounted inboard are probably only judging that based on articulation alone, because inboard shocks can articulate well, while tending to limit travel when axle is horizontal
    PathFinder1776 and erice like this.
  15. Sep 5, 2023 at 8:28 PM
    #495
    erice
    Eric
    San Diego
    nice stock rear end right there
  16. Sep 10, 2023 at 6:53 PM
    #496
    ARCHIVE
    Eric
    Very nice pic of this kit by @erice !
    TRD493 and erice like this.
  17. Sep 17, 2023 at 2:36 PM
    #497
    90yota
    90yota Instagram: 90_yota
    Dixon, CA/Truckee,CA
    88 T4R / 15 F350
    Stock....ish
    I'm looking at this for my 1st gen runner. I haven't found any other upper mounts that will work with outboard shocks. Adding a 67in rear axle while I'm doing this swap so shouldn't need any spacers.
  18. Sep 17, 2023 at 4:26 PM
    #498
    ARCHIVE
    Eric
    Send me some wheel well/frame pics
  19. Sep 18, 2023 at 7:54 AM
    #499
    90yota
    88 T4R / 15 F350
    Stock....ish
    It's hard to get a good idea with the splash guards in the way but I have about 5in from the top of the frame to the body
  20. Sep 19, 2023 at 7:32 AM
    #500
    ARCHIVE
    Eric
    Thanks, I'll DM you about it
    erice likes this.
