1st Gen Tacoma 12" OSR Outboard Shock Relocation - Outside Frame Rails
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARCHIVE, Oct 18, 2018.
  1. Oct 24, 2018 at 9:23 AM
    #61
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    No and this was an idea and thread started a week ago
    Willbeck and Trident904[QUOTED] like this.
  2. Oct 24, 2018 at 9:42 AM
    #62
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I am a 2nd gen and was trying clarify the difference between the two setups as you did so that possible consumers weren’t misinformed. I have worked with Eric as I run his Hammer Hangers and he’s always been repsonsive and informative. I’m excited that he is giving the 1st gen market something intuitive and have told a few of my 1st gen friends about it!
    I have also seen @Trident904 boast about his rear shock setup in other threads with little support of what makes it so great. Not tying to troll, just trying to make sure that claims are supported. :threadjacked:
    Back to our 1st gen discussions! :taco:
  3. Oct 25, 2018 at 8:05 AM
    #63
    erice
    erice Well-Known Member
    Eric
    San Diego
    Yesir. The 2.5s are just too much for what I do.
    The current plan is an inboard relocation with the flip. However @desertjunkie760 alerted me to this and here I am.
    I also just re checked what I ordered and it's a remote with a bracket. So I'll have mounting options. I can look cool like my ginger coheart @Willbeck but still have options.
    @Speed Freek
  4. Oct 25, 2018 at 8:10 AM
    #64
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    ARCHIVE[OP] and BartMaster1234 like this.
  5. Oct 25, 2018 at 8:14 AM
    #65
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think he’s on the other side of the country, unless I’m missing something.
    BartMaster1234 likes this.
  6. Oct 25, 2018 at 8:30 AM
    #66
    cynicalrider
    cynicalrider #NFG
    Jersey
    PM'ed.
    ToyRyd04, ARCHIVE[OP] and jubei like this.
  7. Oct 25, 2018 at 9:55 AM
    #67
    ARCHIVE
    Eric
    Are you open to mounting your shocks outboard? Seems like fitting 12" under the bed with good uptravel is a hard fit, unless significantly lifted.
    Willbeck likes this.
  8. Oct 25, 2018 at 9:57 AM
    #68
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Inboard with a flip? What does that mean?
  9. Oct 25, 2018 at 9:58 AM
    #69
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Archive is in NY, I’m in CA. The fitting is up to us. That’s why Eric is looking for tester trucks
    ARCHIVE[OP] likes this.
  10. Oct 25, 2018 at 9:59 AM
    #70
    ARCHIVE
    Eric
    Probably u-bolt flip, took my a second
  11. Oct 25, 2018 at 10:07 AM
    #71
    desertjunkie760
    Shane
    Check My Sig.
    Yes, ubolt flip.
    erice likes this.
  12. Oct 25, 2018 at 10:08 AM
    #72
    desertjunkie760
    Shane
    Check My Sig.
    Or significantly angled?
    Ritchie and erice like this.
  13. Oct 25, 2018 at 10:19 AM
    #73
    Crawler Brennan
    Crawler Brennan Well-Known Member
    1999 Tacoma lifted with dual case gears and lockers larger tires
    2wd to 4wd, 4.7 Taco box, 3 inch lift with upper A arm and coilovers, ARB rear Spartan front 4.88 R&P, MC bumpers front + rear and sliders, 35 12.5 tires with walker evans race bead lock wheels, on board air system, lots of cutting in fenders and fire wall.
  14. Oct 25, 2018 at 10:48 AM
    #74
    JKO1998
    Utah
    I thought he wanted someone that come and he’d weld all the shit up, I miss understood.
  15. Oct 25, 2018 at 10:50 AM
    #75
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    It's not too difficult to do. I did it 8ish years ago with some 2.5 SAW's, which were the shortest 12" shocks at the time. Current over the cap with welded rod end Kings would be close to the same Ext/Comp dimensions. Pulled 11-12" vertical with a roughly 50/50 up down split and using J59 deaver springs.
    IMO without seriously recessing into the frame it's not worth the time to try and squeeze a 2.5 outside the frame with a stock axle even with wheel spacers.
    erice, jubei and Squeaky Penguin like this.
  16. Oct 25, 2018 at 10:53 AM
    #76
    desertjunkie760
    Shane
    Check My Sig.
    What does the bold mean?
  17. Oct 25, 2018 at 10:56 AM
    #77
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    travel numbers split. So if you have 12" of travel total it would be 6" up and 6" down
  18. Oct 25, 2018 at 10:56 AM
    #78
    desertjunkie760
    Shane
    Check My Sig.
    :thumbsup:
    Thank you
  19. Oct 25, 2018 at 12:41 PM
    #79
    ARCHIVE
    Eric
    Where did you locate your lower shock tab?
  20. Oct 25, 2018 at 1:27 PM
    #80
    erice
    Eric
    San Diego
    Thats why i'm chiming in. the alcans have 3" and i have toytec lift shackles on 1"
    It will work but i'm open to options.
    flip ya fo real!
    haha, yeah flip kit, like everyone else beat me to.
