1st Gen Tacoma 12" OSR Outboard Shock Relocation - Outside Frame Rails
Discussion in '1st Gen. Tacomas (1995-2004)' started by ARCHIVE, Oct 18, 2018.
  1. Oct 25, 2018 at 1:51 PM
    #81
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    Of the axle, it's fairly low but I have only hit it a few times while wheeling. I could move it up 1" or so since the leaf pack doesn't bump that high when it's all put together VS just the main leaf to cycle it.
    Here is a old pic of when I first finished it.
    Fairly current setup.
    A 10" shock like @Squeaky Penguin is running is more than enough length with bolt in leafs for the rear of a 1st gen. Make it a 2.5 with a resi clicker and your good to go even with an LT front suspension for 95% of the weekend warriors on TW.
    It mostly started in TTORA many years ago.
    blue.yota, Rocan, chrslefty and 4 others like this.
  2. Oct 25, 2018 at 2:10 PM
    #82
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    You have a first gen though, yours is already "flipped" lol
  3. Oct 25, 2018 at 3:16 PM
    #83
    erice
    erice Well-Known Member
    Eric
    San Diego
    Well then, I flipped it back lol
  4. Oct 25, 2018 at 3:21 PM
    #84
    ARCHIVE
    ARCHIVE [OP] Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    Looks good thanks for posting pics and link
  5. Oct 26, 2018 at 9:48 AM
    #85
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Subbed. I needs more shock !!
    LukeCC and ARCHIVE[OP] like this.
  6. Oct 28, 2018 at 3:12 PM
    #86
    ARCHIVE
    Eric
    Thought I would post lotsoftoys 1st gen with TC relocation, because it gives an indication of what to expect with shocks outboard. Specs:
    -285/75-16 on TRD, looks like spacers on the rear
    -Total chaos rear shock relocate with piggyback resi kings.
    -all pro expo leaf packs with u bolt flips and 6 inch shackles
    With the kit I'm working on, I'm definitely trying to build in plenty of bump travel. Looking at the TC kit as installed here with lift springs, 6" shackles, and what appears to be 2.0x10" King, I'm surprised it doesn't have more bump travel.
    Eric
    970btu likes this.
  7. Oct 28, 2018 at 3:29 PM
    #87
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    He’s welded new bump mounts to the frame, in addition to very long aftermarket rubber bump stops. It does appear to have less up travel than mine, which is odd as I don’t have a ton of lift.
  8. Oct 28, 2018 at 3:37 PM
    #88
    ARCHIVE
    Eric
    I'd say the bump tube welded to the frame is a little taller than factory brackets that hang down which he removed. I like the cross brace and boxing
    I'm probably buying a frame to get better acquainted with the 1st gen, and I'm thinking of making a frame boxing kit for inboard side of frame, anyone interested?
  9. Oct 28, 2018 at 3:46 PM
    #89
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    You planning on something for 2nd gens too?? :D:boink:
    erice and ARCHIVE[QUOTED][OP] like this.
  10. Oct 28, 2018 at 3:49 PM
    #90
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    If it's better than the dam trail gear box kit. Hell yess
  11. Oct 28, 2018 at 3:56 PM
    #91
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Yes
  12. Oct 28, 2018 at 4:06 PM
    #92
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    What's wrong with the TG kit? Mine fit perfect.
    Willbeck likes this.
  13. Oct 28, 2018 at 4:09 PM
    #93
    ARCHIVE
    Eric
    @Squeaky Penguin Is Trail Gear's a box kit? I read into the TG as an exterior plate since they call them reinforcement plates
  14. Oct 28, 2018 at 5:04 PM
    #94
    Squeaky Penguin
    Brett
    They have both.
  15. Oct 28, 2018 at 5:42 PM
    #95
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    YES. Mine will need to be boxed and cross braced since I won’t be able to do frame reinforcement plates, and I’ll need the extra strength for when I finally do a swing out rear bumper
  16. Oct 28, 2018 at 6:01 PM
    #96
    ARCHIVE
    Eric
    I was thinking a tube between the factory frame close offs at the bump brackets would be a good addition, if a frame doesn't get boxed. Personally I don't think boxing is critical
    Willbeck[QUOTED] likes this.
  17. Oct 28, 2018 at 6:03 PM
    #97
    Willbeck
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
    Agreed. If I box mine I’ll run an x-brace like @lotsoftoys truck. Better rigidity that way
  18. Oct 28, 2018 at 6:19 PM
    #98
    ARCHIVE
    Eric
    I like that as I said above. The thing that most boxing kits don't do that drives me nuts is they don't go under the cab at least somewhat.
    On 1sties, the frame is actually boxed to behind the cab, I'd try to make boxing plates go down and connect to factory box. The fuel tank cross member would have to be cut and welded to plates.
    erice and Willbeck[QUOTED] like this.
  19. Oct 28, 2018 at 6:52 PM
    #99
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    Was stupid beefy once that was in.
  20. Oct 28, 2018 at 8:24 PM
    #100
    defythemall
    defythemall Well-Known Member
    San diego
    01 RC 4wd, 03 DC 4wd
