1st gen tacoma 2jz swap help??
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dr.dre, Jul 30, 2023.
  1. Jul 30, 2023 at 8:57 AM
    Dr.dre
    Dr.dre [OP] Member
    Anyone who's done a 2jz swap on 1st gen tacoma single cab 2wd with stock manual transmission? According to my research it comes stock with w59 transmission and I just need to to swap the bell housing to the w58 with out any other mods?
    Also what clutch and flywheel will I need to use? Tia
  2. Jul 30, 2023 at 11:30 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    You need the clutch kit and fly wheel for what the w58 transmission came from.
    You also need to make sure the lengths of the input shafts and the bell housings are the same length.
    Not having the information in front of me always good to double check.
