1st gen Tacoma 2nd gen supercharger
Discussion in 'Performance and Tuning' started by Cohbsteq, Jul 17, 2016.
  1. Jul 17, 2016 at 7:46 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I have 8 on 2.2 pulley
  2. Jul 17, 2016 at 7:51 PM
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    If I get the stock pulley I shouldn't have to tune anything right? I can just pull the urd pulley and install the stock one back on? As far as I know the po didn't have a 7th injector kit installed and just switched out the pulley for the 2.2 size.
  3. Jul 17, 2016 at 8:10 PM
    anthony250f
    Anthony
    San Diego, CA
    Yes but the proper fix is the 7th. It still will run lean and may still ping.
  4. Jul 17, 2016 at 8:16 PM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    Okay sounds good, im genna order that new pulley tomorrow, I can live with a noise as long as I know it's somewhat "normal"
  5. Jul 17, 2016 at 8:28 PM
    anthony250f
    Anthony
    San Diego, CA
    Try to avoid it. Don't do low rpm high gear. Downshift if it does it
  6. Jul 17, 2016 at 8:30 PM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    Will do. Thanks again for all
    Your info. It's helps a lot.
    anthony250f[QUOTED] likes this.
  7. Jul 28, 2016 at 4:34 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Wouldn't hurt to change your fuel filter as well. As an additional minimal safety precaution. Unless it has already been done?
  8. Jul 28, 2016 at 9:47 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    not that i know of, thats a good idea to add to the list!
    Torspd[QUOTED] likes this.
