1st gen Tacoma 3.4 l 4x4
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tsean, Apr 12, 2025.
  1. Apr 12, 2025 at 9:44 AM
    Tsean
    Tsean [OP] Well-Known Member
    Tsean
    On the highway maintaining 65 it feels like something in the transmission is slipping, like it loses pull for a split second - any ideas?
    I have replaced the fuel filter and canister Scan gauge code gives me p1135
  2. Apr 12, 2025 at 3:09 PM
    Glamisman
    Glamisman Well-Known Member
    One idea... Lift up on the brake pedal and/or check the brake light switch. The torque convertor clutch (TCC) is disengaged on brake application and if the switch is on/off/on/off due to misadjust/bad the TCC is on, off, on, off.
  3. Apr 12, 2025 at 4:03 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    There is also about a 500 rpm difference between a locked and unlocked torque converter.
  4. Apr 12, 2025 at 6:11 PM
    Tsean
    Tsean
    OK, I am willing to take a look is a specific component
