1st Gen Tacoma 3.4L Code P0441
Discussion in '1st Gen. Tacomas (1995-2004)' started by sandersgtn, Oct 17, 2024.
  1. Oct 17, 2024 at 5:56 PM
    sandersgtn
    sandersgtn [OP] Active Member
    I've seen several posts on code P0441. Here's mine.
    - Bought the Double Cab 4wd 3.4L last May with code P0441. Dealer said hose was missing from gas tank to EVAP system.
    - When replacing exhaust system I spotted missing hose and replaced. Code did not go away.
    - Looked for other cracked or missing hoses. None found.
    - Replaced gas cap with new OEM cap from local dealer. $32. Code did not go away.
    - Noticed that gas tank had vacuum when removing cap. Decided to replace pressure sensor from eBay. BINGO! P0441 code gone. New code P0420 appears.
    - New code apparently related to upstream air/fuel sensor. Purchased new upstream 02 sensor from eBay. BINGO! No codes.
    In hindsight, since the gas tank had vacuum when I removed the old gas cap, I probably didn't need to replace with new gas cap.
  2. Oct 17, 2024 at 6:13 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Nice
    better to replace gas cap now than failing inspection and shop charges you $45 for a AM one!
    Money well spent.
    1 Limited Toyota likes this.
  3. Oct 17, 2024 at 6:25 PM
    sandersgtn
    No inspections here in TN...
  4. Oct 17, 2024 at 7:05 PM
    ControlCar
    Steven
    Sugar Land TX
  5. Oct 18, 2024 at 12:44 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Caps are a common issue. Not bad insurance
  6. Nov 21, 2024 at 6:04 PM
    Brangus
    Brangus Member
    Do you have a part number for that "pressure sensor"?
  7. Nov 22, 2024 at 5:50 AM
    sandersgtn
    Purchased on eBay. $55.99
    Brangus likes this.
  8. Nov 22, 2024 at 9:00 AM
    Glamisman
    Glamisman Well-Known Member
    Did you clear all codes and they reappeared or are you expecting them to self clear?
  9. Nov 22, 2024 at 9:11 AM
    sandersgtn
    I disconnected the battery. No codes reappeared.
  10. Nov 22, 2024 at 9:21 AM
    sandersgtn
    Correction - I had the upstream O2 sensor "heater circuit" code appear after fixing the emissions code with the pressure sensor. I replaced the upstream 02 sensor and no more codes.
    In all cases as chasing codes, I disconnected battery to reset.
    Good luck!
  11. Nov 23, 2024 at 1:18 PM
    Glamisman
    Some codes, especially evap codes are 2 trip codes meaning that the truck has to complete 2 cold start cycles.
  12. Nov 24, 2024 at 6:45 AM
    sandersgtn
    Didn't know that. I did have a "check engine" light after replacing pressure sensor. Restarted several times and light didn't reset. Went to local Advance Auto to check code and discovered new upstream 02 sensor code. EVAP code was gone and replaced with new. Proceeded with O2 sensor replacement and now good.
    Thx
