1st gen Tacoma - 3rd gen 4runner - swapping out valve cover gaskets - **Pictures!**
Discussion in '1st Gen. Tacomas (1995-2004)' started by ramonortiz55, Jan 12, 2017.
  1. Jan 12, 2017 at 8:41 AM
    ramonortiz55
    ramonortiz55 [OP] Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    Decided to do a detailed writeup for swapping the valve cover gaskets on my 2001 4runner.
    This job took me nearly two days - It was my first time doing this and I do like to take my time while working on cars. I've been known to start working on a car, leave it alone and come back and finish it a few days later. LOL.
    I know some of you are not as patient as me, I just am never in a rush when working on cars.
    So this it the list of items needed with Toyota Part numbers:
    1. Valve cover gaskets - Part #11213-62020 - 2 Total
    2. Spark Plug Tube gaskets - Part #11193-16010 - 6 Total
    3. Intake Plenum Gaskets - Part #17176-62040 - 2 Total
    4. Washer Seals - Part #90210-05007 - 16 Total
    5. Camshaft Plugs - Part #11188-62010 - 2 Total
    6. Halfmoon Plugs - Part #11183-62010 - 4 Total
    7. PCV Valve Grommet - Part #90480-18001 - 1 Total
    8. Toyota FIPG seal packing - Part #00295-00103 - 1 Tube
    **Throw the PCV Valve Grommet and Spark Plug Tube Gaskets in the Freezer a night before. I will explain why later**
    Mandatory parts picture:
    My research links: http://www.yotatech.com/f2/5vzfe-leaky-valve-covers-fixed-56k-beware-149594/
    Now let's tackle this job!
    First step is removing the airbox assembly, loosen airbox bolts and straps:
    unplug mass airflow sensor and any other connectors in the vicinity:
    There will be a smaller airbox towards the firewall with some airlines connecting into it, remove the airhoses and the small airbox:
    Don't forget the airhoses that run towards the front of the engine towards the piping of the airbox:
    Loosening these thinner clamps will help removing the piping to the airbox:
    Remove another plug, this one is right besides the accelerator cable:
    Three cooling lines will be feeding into the throttle body, these can be removed also:
    Another plug:
    Remove the accelerator cable off the throttle, this can be done by clocking the body of the spring and sliding it out carefully:
    Another picture of everything removed:
    Remove the two top nuts that are holding the throttle in position:
    Now remove the bottom bolts that are holding the throttle in position:
    Pull off the throttle gently, pay real close attention how the metal gasket is oriented. It needs to go back the same way or your truck will explode:
    Next, we will remove the upper intake manifold. Make sure to give it a good stare before you start. Nice, hard, evil stare. You're going to own that intake manifold. It's yours. Touch it. Feel it. Be the Manifold:
    To remove it loosen these brackets that hold the speedometer cable:
    and these other brackets that are on the driver's side of the manifold. (the bracket with the blue paint might need to be removed from the other end if you cant fit a ratchet at the upper bolt):
    disconnect this hose at the far end of the manifold, on top:
    Next, remove all the other bolts that hold down the intake manifold - Not pictured. Manifold should then come off.
    Now time to remove the lower intake manifold -
    If for some reason you couldn't take the speedometer bracket off due to it being too congested, you can take it off now:
    This stainless tubing has hose attached to the ends, take off the hose. I didn't have to remove the tubing itself, just the hose.
    Remove the computer diagnostics port that is attached on the driver's side of the manifold:
    At the back of the lower intake manifold, there is a bolt holding the wiring harness, remove it.
    At this time, the bolts holding the lower intake manifold can now be removed.
    Remove the remaining bolts holding the lower intake manifold down:
    Once the lower intake manifold is removed, cover up the exposed intake chambers with a rag, tape, etc to prevent stuff from falling in there. You do NOT want a bolt falling in there. Might as well jump off a bridge:
    Moving onto the passenger side valve covers, remove the spark plug wires and coil packs:
    disconnect the injectors:
    Remove the bolts holding down a wire bracket - This will not be able to be removed completely, but taking the bolts off will make the job easier. It will give you room to work with.
    At this time, the valve cover can be removed:
    So beautiful, so clean. Thanks to frequent oil changes :)
    At the end of the engine heads there will be a wiring harness attached to a bracket, close to where my hand is at. If you feel around, you will find it. This will need to be removed:
    Looks like this:
    There are two halfmoon plugs per side:
    one in the front:
    one in the back:
    one camshaft plug in the back that is being held down by two bolts:
    The halfmoon plugs can be removed with some channel locks. Gently pry upward. UPWARD. You may wiggle a little. Just not much. Don't want to crack the head. :anonymous:
    Removed:
    Remove the camshaft plug:
    At this time, make sure your supervisor approves your work:
  2. Jan 12, 2017 at 8:42 AM
    ramonortiz55
    Ramon
    Texas
    stock
    After you have received supervisor approval, clean off the old gasket material using any scraping tool. Make sure to scrape well in the areas where the halfmoon and camshaft plugs go:
    After that is done get your valve cover and flip it over. The spark plug tube gaskets will now be replaced:
    Grab a small screwdriver and tap the gasket from the other side:
    Pull out the PCV grommet:
    Now remove the old washers seals:
    I did this by tapping it from the other end with a small flat head screwdriver:
    At this point, go back to the freezer and grab the THREE replacement gaskets and the PCV grommet:
    Pop the new PCV grommet in:
    Pop the new replacement gaskets in. Some people use a large socket to get them to sit right. Since I froze them, they were able to shrink. Making my job easier:
    Sit the new valve cover gasket carefully:
    Notice the areas that will need seal packing, this is where the FIPG goes. Be generous. Don't skimp out, you want a nice noticeable ooze when you sit it on the head:
    Install with new camshaft plug:
    Now goes the halfmoon plugs:
    Same procedure, a nice noticeable ooze:
    The Toyota manual indicated to add extra FIPG to the indicated locations:
    I made sure it was on there :D
    Set the cover on carefully:
    Torque the valve cover bolts down to
    The procedure for the driver's side is the same as the left, with the exception of a wiring harness section going above the valve covers:
    I didn't chase down the harness to see what it was for, I just worked around it.
    Once the driver's side is done, install everything as it was removed. Replace the plenum gaskets between the manifolds.
    Done!
  3. Jan 12, 2017 at 8:47 AM
    ramonortiz55
    Ramon
    Texas
    stock
    Special thanks to @JWaldz for making me do this :(
    Pyrifera, Tundra2 and JWaldz like this.
  4. Jan 12, 2017 at 8:59 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    Well.
    Hmmmm...
    There's another excellent procedure!
    Thank you very much! :thumbsup:
  5. Jan 12, 2017 at 9:01 AM
    JWaldz
    JWaldz It puts the Joe Dirt in the hole
    Waldo
    Colo Springs
    99 4Runner LTD
    You're welcome... But you still didn't take my advice on pulling the injectors to be cleaned while you were in there lol
  6. Jan 12, 2017 at 9:02 AM
    ramonortiz55
    Ramon
    Texas
    stock
    meh.
    02_SC_Dbblcab likes this.
  7. Jan 12, 2017 at 9:10 AM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Good job . Aim ready for this project this weekend. . :thumbsup::fingerscrossed:
  8. Jan 12, 2017 at 9:47 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    Yes. Sticky.
  9. Jan 12, 2017 at 9:51 AM
    TooMuchToDo
    TooMuchToDo Well-Known Member
    2002 Gold Tacoma XtraCab with 192k
    ...we'll get there.
    now that's a write-up...
  10. Jan 12, 2017 at 9:58 AM
    bowyer2002
    bowyer2002 always tinkering
    NE Missouri
    01 Taco SR5 D-cab 4WD
    OME 882s, OME shocks all around and OME Dakar spring packs, ARB, Warn 8000, ARE shell, Custom rear bumper w/ reciever, 5-235/80R17 Cooper Discoverer ST MAXX on FJ wheels, grey wire mod, Hi-Lift, Hellas, Red-Line hood lifters, Scion radio, sliders, Safari snorkel & LED Ditch lights on CBI mounts.
    Nice write up, pictures are always helpful too.
    BTW - how many miles on your engine when you did this? Was is preventative maintenance or did you have leaks?
  11. Jan 12, 2017 at 9:59 AM
    ramonortiz55
    Ramon
    Texas
    stock
    the camshaft plugs were leaking. im at 191k
    GQ7227 likes this.
  12. Jan 12, 2017 at 10:06 AM
    bowyer2002
    NE Missouri
  13. Jan 12, 2017 at 10:12 AM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    wow very impressive write up! The freezing technique is such a "pro-tip"
    Thanks
    Jimmyrace likes this.
  14. Jan 12, 2017 at 11:27 AM
    Looiz
    Looiz Well-Known Member
    Los Angeles
    95.5 RegCab
    ...blank canvas...
    what?... no bloody finger on this one? :notsure:
    cool write-up, especially the parts list with part numbers.
  15. Jan 12, 2017 at 11:27 AM
    ramonortiz55
    Ramon
    Texas
    stock
    no, there was a safety supervisor around. couldn't mess up on this round
  16. Jan 12, 2017 at 12:40 PM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Nice write-up and cool cat
    Pyrifera, opteron and Jimmyrace like this.
  17. Jan 12, 2017 at 12:43 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    ramonortiz55[OP] likes this.
  18. Jan 12, 2017 at 1:13 PM
    mwrohde
    mwrohde Well-Known Member
    Sugar Hill, GA
    2003 Tacoma 4x4 5-speed 3.4 TRD SR5
    Nicely done. Good write up. I'll use it some day. One question . . .
    Were there replacement washer seals?
  19. Jan 12, 2017 at 1:15 PM
    ramonortiz55
    Ramon
    Texas
    stock
    Yes. 16 of them. 8 per cover. part numbers are on the list
  20. Jan 12, 2017 at 6:51 PM
    tony2018
    tony2018 Well-Known Member
    Thanks for this, it will be useful to me soon.
